Wob76 22 Posted April 19, 2016 Posted April 19, 2016 Hi, I am trying to work out how to refresh my Metadata for a movie, when the movie was added to my Library it had a higher star rating 7.3, this has since dropped but even if I do a full refresh it won't update the Community Rating. It is showing in Emby as 7.3, yet on themoviedb.org and imdb it has 5.8 and 5.5 respectively. It also didn't match up to rottentomato, even with an update, I ended up having to manually update the ID for that to work, should this not update with a full refresh or an Identify? The movie is "The Trust (2016)" for reference. Thanks, Wob
Happy2Play 9800 Posted April 19, 2016 Posted April 19, 2016 (edited) OMDB lists it as 7.3 which is probably an old rating from IMDB. What is your fetcher order? Metadata-Services-Select Content type Edited April 19, 2016 by Happy2Play
Wob76 22 Posted May 11, 2016 Author Posted May 11, 2016 Hi, Thanks for the response, sorry for the slow reply, I have been moving house . My Metadata downloaders are as follows; The Open Movie Database TheMovieDb How do I pull that screen that you have there? Thanks, Beau
Happy2Play 9800 Posted May 11, 2016 Posted May 11, 2016 Hi, Thanks for the response, sorry for the slow reply, I have been moving house . My Metadata downloaders are as follows; The Open Movie Database TheMovieDb How do I pull that screen that you have there? Thanks, Beau It is a beta plugin. http://emby.media/community/index.php?/topic/32984-new-plugin-metadata-viewer/
