Darkjeje 11 Posted August 29, 2016 Author Posted August 29, 2016 So if I understand, it's a problem with my box which don't return correctly if she can play my movie ? What type of solution could you propose me ? Do you want to test my platform ? It is possible to force live play with a parameters in emby server or in emby for android TV ? I think of an available option for Beta tester only, for example
solabc16 379 Posted August 29, 2016 Posted August 29, 2016 Hello @@Darkjeje Can you post a screen shot of the 'Media Info' section from the WebUI, for the title you are testing with. We can compare that with what @@ebr has, and identify/eliminate any probing related issues. - James
Darkjeje 11 Posted August 29, 2016 Author Posted August 29, 2016 (edited) Is it this what can you need ? Edited August 29, 2016 by Darkjeje
solabc16 379 Posted August 29, 2016 Posted August 29, 2016 Hello @@Darkjeje It's this screen, which you can find by browsing to the movie using a web browser and scrolling to the bottom of the page. - James
Darkjeje 11 Posted August 29, 2016 Author Posted August 29, 2016 (edited) Ok sorry @@solabc16, this is better Edited August 29, 2016 by Darkjeje
solabc16 379 Posted August 29, 2016 Posted August 29, 2016 No worries @@Darkjeje, that's the one. Let's see how that compares to @@ebr, so we can determine if probing is an issue here. - James
ebr 16337 Posted August 29, 2016 Posted August 29, 2016 Media info looks fine but I forgot you were on an off-brand device. I was thinking you were on a Fire TV. Still, that device is running the same basic version of Android as a Fire (5.1.1). (long shot) Luke, is there any possibility there is a casing issue on the audio codec (MP2 vs mp2)? Never mind, that can't be it since it direct streams for me.
Darkjeje 11 Posted August 29, 2016 Author Posted August 29, 2016 If you want I can delete the audio track to test only the movie whitout sound.
Darkjeje 11 Posted August 30, 2016 Author Posted August 30, 2016 I tested this morning with no audio track, the movie is transcoding but with a better quality 40 fps. I had not seen that the movie was .ts, because all my movies are transcoding in .ts. I change all my playlist to .mp4. This evening I shall test the same movie but there .mp4 and I hope to be directplay.
solabc16 379 Posted August 30, 2016 Posted August 30, 2016 Hello @@Darkjeje Thanks for the feedback, could you send me your logs across please. (https://github.com/MediaBrowser/Wiki/wiki/Synology-:-How-to-Send-us-Support-Logs) Was the sample file you provided in TS format as well? If so, then there still appears to be a discrepancy between how it behaves across platforms. - James
Darkjeje 11 Posted August 30, 2016 Author Posted August 30, 2016 Hello @@solabc16, This evening I send you my log I'am sorry, but I don't understand your second sentence,... I'am French and not very good in english. Could you reformulate your question please ? Thank you. Jérem
solabc16 379 Posted August 30, 2016 Posted August 30, 2016 Hello @@Darkjeje No problem, let me try again. I was asking if the movie you sent across here (http://emby.media/community/index.php?/topic/33780-how-to-see-a-movie-without-transcoding/?p=360385) was in .TS format as well? - James
Darkjeje 11 Posted August 31, 2016 Author Posted August 31, 2016 Hello @@Darkjeje No problem, let me try again. I was asking if the movie you sent across here (http://emby.media/community/index.php?/topic/33780-how-to-see-a-movie-without-transcoding/?p=360385) was in .TS format as well? - James Thank you James for your reformulation. Yes it was. I didn't have the time yesterday, but this morning I tested the same movie in .mkv and it was not transcoding. But, because there is a but, I don't have any sound, and I don't know why. So I have a problem with my platform to detect if she can directplay or not the movie .TS. James, this evening, if I have the time, I send you my log. Thanks Jérem
RanmaCanada 502 Posted September 1, 2016 Posted September 1, 2016 At this point I would suggest just getting a cheap android box, as the box you are using may never get proper support. http://www.gearbest.com/tv-box-mini-pc/pp_366821.html Then load this firmware on it, and you are good to go. http://kodiloaded.com/smf/index.php/topic,1567.0.html Google Translate À ce stade, je dirais simplement obtenir une boîte android pas cher, comme la boîte que vous utilisez peut jamais obtenir un soutien adéquat. http://www.gearbest.com/tv-box-mini-pc/pp_366821.html Puis charger le firmware sur elle, et vous êtes bon pour aller. http://kodiloaded.com/smf/index.php/topic,1567.0.html
solabc16 379 Posted September 1, 2016 Posted September 1, 2016 Hello @@Darkjeje Do you have the possibility to setup a minimal Emby Server on Windows, so you can test playback of the same file on your Freebox/Android device? The assertion appears to be that this should work, so it would be good to know if this is a platform specific issue. - James
Darkjeje 11 Posted September 1, 2016 Author Posted September 1, 2016 Hello @@Darkjeje Do you have the possibility to setup a minimal Emby Server on Windows, so you can test playback of the same file on your Freebox/Android device? The assertion appears to be that this should work, so it would be good to know if this is a platform specific issue. - James Ok James, I test that this week-end.
Darkjeje 11 Posted September 1, 2016 Author Posted September 1, 2016 Hello @@Darkjeje Thanks for the feedback, could you send me your logs across please. (https://github.com/MediaBrowser/Wiki/wiki/Synology-:-How-to-Send-us-Support-Logs) - James My log James sendlogs_DiskStationJR_synology_evansport_214play_20160901T191349UTC.tgz
Darkjeje 11 Posted September 3, 2016 Author Posted September 3, 2016 Hello @@Darkjeje Do you have the possibility to setup a minimal Emby Server on Windows, so you can test playback of the same file on your Freebox/Android device? The assertion appears to be that this should work, so it would be good to know if this is a platform specific issue. - James Hello James, No change with emby server windows. I have just tested the same movie but in AAC for audio track and it was directplay. So with the MPEG audio layer 1/2 in .mkv, the movie is directplay but without sound, With the MPEG audio layer 1/2 in .TS, the movie is transcoding and the movie is cut in 2 part in the diagonal, so impossible to see.
Luke 42244 Posted December 7, 2016 Posted December 7, 2016 Hi @@Darkjeje The latest beta version of the Emby app offers improved playback, refresh rate switching, and all the HD Audio pass-through you need. Check out the beta thread for more details: https://emby.media/community/index.php?/topic/42239-android-tv-beta-13x/ We think you'll enjoy the next update to the stable channel. Thanks !
Darkjeje 11 Posted December 7, 2016 Author Posted December 7, 2016 Yes thank you Luke. I install the last beta for syno 3.1.248
