reapola 0 Posted March 26, 2016 Posted March 26, 2016 Hi, I've just migrated from a shared mysql server to emby after a complete format and reinstall of kodi. I've just installed and paid for Emby and I'm really keen to get cinema mode working but so far no luck. I have the emby kodi plugin set to 'plugin' and not direct paths but it still continues to play the main feature/movie and no trailers before. I've checked that 'cinema mode' is set for the server under 'playback' and also under user preferences too. Does anyone have any idea? Cheers, Colin
Angelblue05 4132 Posted March 26, 2016 Posted March 26, 2016 (edited) Post your Kodi log. Check the link for how to set up your log: http://emby.media/community/index.php?/topic/17599-how-to-report-a-problem/ Repeat the playback that creates the bug, thanks! Also grab a screenshot of your cinema settings under the emby dashboard > playback > cinema mode. Edit: What is your emby server version? I seem to be facing this issue, but my server version is not up to date on the beta branch. Edited March 26, 2016 by Angelblue05
bluemonkey07 590 Posted March 28, 2016 Posted March 28, 2016 Do you have local trailers stored with your movies, or the emby server trailers plugin installed?
