goldsworthy1 5 Posted February 23, 2016 Posted February 23, 2016 Whenever i try to launch Emby Theatre i get to a black screen, no options in the top right, no folders, nothing and it wont go any further. Has anyone else had this problem?
Luke 42241 Posted February 23, 2016 Posted February 23, 2016 Hi, can you provide the emby theater log? http://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
goldsworthy1 5 Posted February 23, 2016 Author Posted February 23, 2016 Will provide these when i get home tonight.
goldsworthy1 5 Posted February 23, 2016 Author Posted February 23, 2016 Ok i may be missing something, but i cant find a log file for Emby Theatre, which folder should it be in?
goldsworthy1 5 Posted February 23, 2016 Author Posted February 23, 2016 Think ive found them... see attached. theater-63591768314.txt theater-63591768329.txt theater-63591768395.txt theater-63591768654.txt theater-63591768825.txt theater-63591768986.txt theater-63591839925.txt theater-63591840946.txt
Solution Luke 42241 Posted February 23, 2016 Solution Posted February 23, 2016 what version of windows? the one thing i would check on is that video drivers are up to date, and that Windows DWM (Aero) has not been disabled. Thanks. 1
goldsworthy1 5 Posted February 23, 2016 Author Posted February 23, 2016 Disabled Aero Peek and it worked straight away
Luke 42241 Posted February 23, 2016 Posted February 23, 2016 well done we need to improve our detection of that so that it will alert you of it. Thanks.
goldsworthy1 5 Posted February 24, 2016 Author Posted February 24, 2016 Hey Luke, Have another problem now. The Windows task bar displays all the time...
Luke 42241 Posted February 24, 2016 Posted February 24, 2016 Hm, i've not seen that before. did you try the maximize button in the upper right?
Guest asrequested Posted February 24, 2016 Posted February 24, 2016 Hm, i've not seen that before. did you try the maximize button in the upper right? It looks like these guys are having that issue, too: http://emby.media/community/index.php?/topic/31572-windows-10-taskbar-displayed-in-front-of-any-video/
Luke 42241 Posted February 24, 2016 Posted February 24, 2016 It looks like these guys are having that issue, too: http://emby.media/community/index.php?/topic/31572-windows-10-taskbar-displayed-in-front-of-any-video/ Then let's move into that discussion, thanks.
