Ianmcw 0 Posted February 23, 2016 Posted February 23, 2016 Hi All i am new to the comunity and having a few issues with playing my movies on my Note 4 also same issues appear on my kindle fire hdx, i have searchd forum over last few days but couldnt find answer to resolve my issues. I have a deditcated htpc with win 8.1& WMC with media browser classic server and client on same machine all my rips are ISO or IMG files and are 1 to 1 rips 1. when i press play on my phone it asks to seclect player and when i press external player nothing happens 2. If i select Play movie loads and starts but i cannot select menu on dvd to start movie 3. other movies load ok then they are no sound All the movies play perfect on pc/htpc/dvd player etc. but they will not work via android app Any help would be appreciated
Luke 42243 Posted February 23, 2016 Posted February 23, 2016 Hi, that's very odd. I don't have your exact devices available for testing but on the devices I do have I'm able to launch external players. Can you pull a log from the app: http://emby.media/community/index.php?/topic/15638-how-to-report-an-android-problem/ Thanks.
Ianmcw 0 Posted February 24, 2016 Author Posted February 24, 2016 see the attached log from android310110b4-1e08-4064-b2ce-825612f0d8c1.log
Ianmcw 0 Posted February 26, 2016 Author Posted February 26, 2016 hmmm well seems like ive wasted $99 if i cant watch my movies on phone or other devices
Luke 42243 Posted February 26, 2016 Posted February 26, 2016 Ok, let's start with the external player and get that resolved first. Can you please try this build and then provide the app log? if you need a google play version let met know, thanks. android-amazonarmv7-release.zip
Ianmcw 0 Posted February 27, 2016 Author Posted February 27, 2016 Luke thank you for reply and other build, this build worked for selecting player, now i can select vlc palyer when i hit external player. Please see attached log Still issues with sound some no sound others wrong track and still i am not able to select on sceen menu to play movie ae6b5c02-32c0-4409-94cb-85cbcb28b4bd.log
Luke 42243 Posted February 27, 2016 Posted February 27, 2016 Ok, let's go over the menu. Can you elaborate on this: i am not able to select on sceen menu to play movie Thanks.
Ianmcw 0 Posted February 27, 2016 Author Posted February 27, 2016 my rips are 1.1 so they have everything on them including menu to start movie or pick extras etc. so i cant press play as it pause movie or use othe functions to press play to start movie it will just sit there playing intro as i cannont select play Thanks
Luke 42243 Posted February 27, 2016 Posted February 27, 2016 Ok, I understand. That's not supported by the internal player as of yet. We do use libvlc and libvlc does support it, so it is possible, but we haven't implemented it yet. You'd have to use an external player for that right now.
Ianmcw 0 Posted February 27, 2016 Author Posted February 27, 2016 maybe i am missing something here but isnt vlc an external player
Luke 42243 Posted February 27, 2016 Posted February 27, 2016 Ok, I see what you mean. Please try external players again with this build. Thanks. android-amazonarmv7-release.zip
Ianmcw 0 Posted February 27, 2016 Author Posted February 27, 2016 Hi Luke isnt that the same build you gave me earlier? update: I tried streaming my iso via vlc over my LAN itself also via file explorer and it works fine, I can start movie can select chapters and extras all works fine sounf works good but with emby it doesnt
Luke 42243 Posted February 27, 2016 Posted February 27, 2016 Ok, I think what's happening is we're sending a streaming url to the external player. i should be able to fix this by sending the original network path to the file to the external player. (or adding an option to do so).
Luke 42243 Posted February 28, 2016 Posted February 28, 2016 Hi, can you please try this build and then provide the log? it's going to send the original media path to the external player. thanks. android-amazonarmv7-release.zip
Ianmcw 0 Posted February 28, 2016 Author Posted February 28, 2016 see attached log Update: After clicking external player i get another box saying i am done click that nothing happens 0c137644-f8f4-47ff-916c-b192f20f71181.log
Luke 42243 Posted February 28, 2016 Posted February 28, 2016 Ok, your iso path on the server is E:\Kids Movies\Bambi.ISO Add a path substitution on the server to convert that path to a network path that the device will be able to access. For instructions see the bottom of this wiki page: https://github.com/MediaBrowser/Wiki/wiki/Library%20Setup Set that up, try to play again, the provide the log. thanks.
Luke 42243 Posted February 28, 2016 Posted February 28, 2016 And here's another build that adjusts the way the path is formatted when it goes to the player, prefixing it with file:// to make it a valid uri. thanks. android-amazonarmv7-release.zip
Ianmcw 0 Posted February 28, 2016 Author Posted February 28, 2016 see attached log Update: it opens vlc now but get error vlc encountered error with this media try refreshing media will try your latest build Thanks 919c7f69-31b5-4c65-bc01-b364a56df1c21.log
Ianmcw 0 Posted February 28, 2016 Author Posted February 28, 2016 Latest build the same get the error, vlc encountered error with this media try refreshing media
Ianmcw 0 Posted February 28, 2016 Author Posted February 28, 2016 sorry forgot toattach last time f83ffb0a-cb9f-4234-b2eb-eaa1c4e8adf61.log
Luke 42243 Posted February 28, 2016 Posted February 28, 2016 Are you sure you used the external player? the log mainly speaks of playback attempts with the internal player.
Ianmcw 0 Posted February 28, 2016 Author Posted February 28, 2016 Yes tried multiple players but mainly VLC clicked external player choose VLC got the error
Luke 42243 Posted February 28, 2016 Posted February 28, 2016 Ok, try this one. I added another logging statement right before launching the external player. it should have what i need thanks. android-amazonarmv7-release.zip
Ianmcw 0 Posted February 29, 2016 Author Posted February 29, 2016 this build doesnt work it freezes when you open it cant use menu on app nothing, frooze mt phone had to take battery out then restart uninstall this build and go bak to the last build
