mata7 45 Posted February 22, 2016 Posted February 22, 2016 is anyone having this problem, if i play MKV Movie with Dolby True HD or Atmos the file play fine the audio is perfect, if i play a Bluray Folder it only play The AC3 Code and no the TrueHD, i use the last beta of emby and last server official update if i play the bluray folder direct from my server to kodi, everything play fine, so i think the problem in my case have to be emby plugin thanks in advance for any help
Angelblue05 4132 Posted February 22, 2016 Posted February 22, 2016 Can you post the Kodi log? Test sending from the server to kodi, and played via kodi directly. Thanks. http://emby.media/community/index.php?/topic/17599-how-to-report-a-problem/
mata7 45 Posted February 22, 2016 Author Posted February 22, 2016 (edited) i will tomorrow, just to make sure cause my English is no that good, you want me to send you the log from my playback from my server to kodi, no EmbyServer or Emby plugin, btw thanks for you help Edited February 22, 2016 by mata7
Angelblue05 4132 Posted February 22, 2016 Posted February 22, 2016 I just need your Kodi log. That is all. You say when you play to Kodi from the webclient, it plays fine, but when you play directly from Kodi, it doesn't? So, can you just repeat your tests and post that Kodi log so I can see what the difference is.
mata7 45 Posted February 22, 2016 Author Posted February 22, 2016 (edited) sorry maybe im confusing you, i mean, if i add the movies folder to my openelec kodi library everything work fine, if i install the emby addon and play "direct play" the same bluray folder from the emby server it wont play the TrueHD Audio, im really sorry for the confusion english is no my first language i will get you the log tomorrow wife is sliping now Edited February 22, 2016 by mata7
Angelblue05 4132 Posted February 22, 2016 Posted February 22, 2016 Ohhh, I understand what you mean now. Ok, can you go to your webclient > select the bluray movie > scroll at the bottom, you should see the media info. Can you grab a screenshot, and in Kodi (with emby for Kodi), play the bluray content, and post that Kodi log. Thanks. The media info looks like:
mata7 45 Posted February 22, 2016 Author Posted February 22, 2016 here is the mediainfo, tomorrow the logs,thanks again 1
mata7 45 Posted February 22, 2016 Author Posted February 22, 2016 (edited) please let me know if this is what you need and if you need anything more, again thanks for you help the movie is transformer age of extinction 01_KODI.log Edited February 22, 2016 by mata7
mata7 45 Posted February 22, 2016 Author Posted February 22, 2016 (edited) ohh i see what the problem is, it only happen when i select "play from HTTP intest of SMB" for some reason is transcoding the audio i believe, im playing over wired connection So why is transcoding? Edited February 22, 2016 by mata7
Angelblue05 4132 Posted February 22, 2016 Posted February 22, 2016 I'm not at my computer right now, so I'm unable to check your logs. If you have play from http enabled, then it should direct stream, unless you have set a really low video quality in the add-on settings. I'll be able to check your log in an hour or so. Sent from my iPhone using Tapatalk
mata7 45 Posted February 22, 2016 Author Posted February 22, 2016 thanks i have the video quality set to 1000 thas the maximun, and only happen wiht Bluray Folders
xnappo 1611 Posted February 22, 2016 Posted February 22, 2016 I don't think you can direct stream a Bluray folder.
mata7 45 Posted February 22, 2016 Author Posted February 22, 2016 but if i disable "play from http" the same Bluray folder play fine play from HTTP is direct stream 2 right, or not? thanks
Angelblue05 4132 Posted February 22, 2016 Posted February 22, 2016 Without the option enabled, it is direct playing. Check your emby dashboard while playing the bluray in Kodi. You'll see if it's direct streaming or transcoding the play from http enabled. Sent from my iPhone using Tapatalk
mata7 45 Posted February 22, 2016 Author Posted February 22, 2016 yea it is transcoding if i select play from http, can i ask you a favor, the only reason that i have play from http enable is because 2 folders are give me problem whit Path substitutions, can i upload the Path substitutions log to this topic so you can take look or do i need to create a new topic, and btw did you check my log? thanks in advance
Angelblue05 4132 Posted February 22, 2016 Posted February 22, 2016 (edited) Sure, post your path substitution here. I'm currently checking your logs. Yeah, transcoding is automatically set to use h264 and ac3 audio, that's why you are not getting truehd. From the lack of logging, I'm assuming the emby server marks the bluray as "unable to direct stream", hence why it's transcoding. Edited February 22, 2016 by Angelblue05
mata7 45 Posted February 22, 2016 Author Posted February 22, 2016 (edited) thank you very much for all you help, here are the log for the path substitution, just so you know i have unraid server, and the files that im trying to play is shameles they are on synology nas mounted on unraid and im trying this path smb://192.168.1.100/mnt/disks/NASSERVER_TV_Series nfs://192.168.1.103/TV Series 01_KODI.log Edited February 22, 2016 by mata7
Angelblue05 4132 Posted February 22, 2016 Posted February 22, 2016 It says it's unable to find the file at this location: nfs://192.168.1.103/TV Series/Shameless (US)/Season4/S04E02.mkv If you go to add-ons > install from zip > and navigate to where your content is located (via nfs protocol), does Kodi has access? Let me know.
mata7 45 Posted February 22, 2016 Author Posted February 22, 2016 yes kodi see and play my nfs library fine
Angelblue05 4132 Posted February 22, 2016 Posted February 22, 2016 Are you sure the paths are the same? It's not missing part of the directory in the path substitution?
mata7 45 Posted February 22, 2016 Author Posted February 22, 2016 that i donk know, is there a way to fiend out if im missing someting, that could be the problem
Angelblue05 4132 Posted February 22, 2016 Posted February 22, 2016 You could just compare. As in, go to add-ons > install from zip > navigate via NFS and take note of the folders you open to get to your content (especially the first folders, make sure they are part of your path substitution)
mata7 45 Posted February 22, 2016 Author Posted February 22, 2016 im use the same path that kodi have and still cant play the file i use /mnt/disks/NASSERVER_TV_Series to nfs://192.168.1.103/VOLUME1/TV Series
Angelblue05 4132 Posted February 22, 2016 Posted February 22, 2016 With your last log: nfs://192.168.1.103/TV Series/Shameless (US)/Season4/S04E02.mkv So you were missing Volume1.... Can you post a new Kodi log since you modified the path substitution? Thanks
mata7 45 Posted February 22, 2016 Author Posted February 22, 2016 here my friend and thank you for all you help 01_KODI.log
