psycopuppy 0 Posted February 20, 2016 Posted February 20, 2016 OK, so perhaps i am doing something wrong, but my recording are staying as .ts files. Overall not a big deal i don't record a lot. my setup is a Hauppauge 2250 and i do have nextPVR so Emby can see my tuners. Could that be the possible issue? I do have the shows scheduled to record through the Emby TV guide. I did check the box to convert and as best as i can tell, am a paid member. scott
ebr 16337 Posted February 20, 2016 Posted February 20, 2016 This feature only works with the internal Emby TV DVR function. If you use an external service (like NextPVR) then it is in control of the recording process.
Luke 42243 Posted January 7, 2018 Posted January 7, 2018 @@psycopuppy We now have native Hauppauge support available for testing in the Emby Server beta: https://emby.media/community/index.php?/topic/54560-32609-hauppauge-support/?hl=hauppauge No plugin required. Thanks !
psycopuppy 0 Posted January 7, 2018 Author Posted January 7, 2018 Thanks, but i ended up using a silicondust device as i have changed cable providers.
