spam_permi 1 Posted January 31, 2016 Posted January 31, 2016 Good morning, I want to configure the Live TV settings in my emby server, but I don't know what is the best free solution. My PC works with: Win 10 Emby Server Hauppauge USB HD Tunner (Win TV) DvbLink is expensive for me. I don't want to have Media Portal and Emby (it is redundant, no?). Is the NextPVR the last and only solution? Thank you.
pünktchen 1411 Posted January 31, 2016 Posted January 31, 2016 DvbLink is expensive for me. I don't want to have Media Portal and Emby (it is redundant, no?). Is the NextPVR the last and only solution? Why do you think MediaPortal and Emby is redundant? You don't have to install the MediaPortal Client Frontend but only the TVServer. It works the same way as NextPVR, DVBLink, ServerWMC or TVHeadend. If you don't like Linux than TVHeadend is out. If you don't have Windows Mediacenter installed than ServerWMC is out. If you don't want to spend money than DVBLink is out. So only NextPVR and MediaPortal are left. Just try them both and make your decision. (The NextPVR backend is propably easier to configure for a beginner i think)
spam_permi 1 Posted February 3, 2016 Author Posted February 3, 2016 Hi pünktchen, you're right. I installed the media portal server and I'm trying configure the settings. Thank you.
Luke 42243 Posted January 7, 2018 Posted January 7, 2018 @@spam_permi We now have native Hauppauge support available for testing in the Emby Server beta: https://emby.media/community/index.php?/topic/54560-32609-hauppauge-support/?hl=hauppauge No plugin required. Thanks !
