Luke 42276 Posted September 2, 2018 Posted September 2, 2018 In the interests of transparency I do not see a lot happening here. It's a lot of work in areas we don't have a whole lot of knowledge about, and it will only target a very small number of users. We do not have unlimited developer resources. We have to focus our efforts on the features that are used by larger numbers of people.
muller_md 4 Posted September 29, 2019 Posted September 29, 2019 In the interests of transparency I do not see a lot happening here. It's a lot of work in areas we don't have a whole lot of knowledge about, and it will only target a very small number of users. We do not have unlimited developer resources. We have to focus our efforts on the features that are used by larger numbers of people. Any chance in open-sourcing the BDInfo plugin, so the community could help with the necessary updates?
Luke 42276 Posted September 29, 2019 Posted September 29, 2019 Any chance in open-sourcing the BDInfo plugin, so the community could help with the necessary updates? @@muller_md, what would you be looking to enhance? Because at this point, I don't think there's much the plugin can do without getting help from the core first.
muller_md 4 Posted September 29, 2019 Posted September 29, 2019 It's the UHD BDMV folder structure support, which is missing. I was able to update the old code + fresh bdinfo with Atmos/UHD support and get emby-server to play them.
ebr 16351 Posted September 30, 2019 Posted September 30, 2019 It's the UHD BDMV folder structure support, which is missing. I was able to update the old code + fresh bdinfo with Atmos/UHD support and get emby-server to play them. I'm afraid that will be a rather large task and not really related to the plug-in so much. The problem is the entire world is moving away from these disc formats so almost nothing current is supporting them in the streaming realm. My advice to you would be to convert them.
Luke 42276 Posted September 30, 2019 Posted September 30, 2019 It's the UHD BDMV folder structure support, which is missing. I was able to update the old code + fresh bdinfo with Atmos/UHD support and get emby-server to play them. Actually yes that plugin could be updated. Do you know exactly which files from BDInfo have changed? When I tried to just dump the whole thing on top before, there were a lot of changes, so many that i couldn't find what was actually related to UHD.
muller_md 4 Posted October 1, 2019 Posted October 1, 2019 (edited) I'm afraid that will be a rather large task and not really related to the plug-in so much. The problem is the entire world is moving away from these disc formats so almost nothing current is supporting them in the streaming realm. My advice to you would be to convert them. Sure, that "works", and that's what i'm doing, in hope that current mainstream containers won't be forgotten. Actually yes that plugin could be updated. Do you know exactly which files from BDInfo have changed? When I tried to just dump the whole thing on top before, there were a lot of changes, so many that i couldn't find what was actually related to UHD. It's the HDMV300/MPLS300, HEVC, Atmos, DTS:X, 4K/UHD/2160p resolutions, so a lot. But I guess the basic support for the container + playlist should be enough. This is how the identification looks after "fixing" the plugin. Also playing it works (server remuxes it) on at least 2 devices (fire stick 4k / lg c8). Edited October 1, 2019 by muller_md 3
Luke 42276 Posted October 2, 2019 Posted October 2, 2019 Ok so you don't know what source files have been updated? That kind of makes it a big job because along the way we have made changes, so if we just dump everything on top then we lose all of that.
SikSlayer 254 Posted October 2, 2019 Posted October 2, 2019 I figured this was going to be as deep a rabbit hole as it's sounding like it is. That's why I didn't bother asking when I saw my test UHD BD didn't get any media info. It's the HDMV300/MPLS300, HEVC, Atmos, DTS:X, 4K/UHD/2160p resolutions, so a lot. But I guess the basic support for the container + playlist should be enough. This is how the identification looks after "fixing" the plugin. Also playing it works (server remuxes it) on at least 2 devices (fire stick 4k / lg c8). This is all I truly want, hopefully it can be worked out. Wish it wasn't such a pain.
muller_md 4 Posted October 14, 2019 Posted October 14, 2019 (edited) I figured this was going to be as deep a rabbit hole as it's sounding like it is. That's why I didn't bother asking when I saw my test UHD BD didn't get any media info. This is all I truly want, hopefully it can be worked out. Wish it wasn't such a pain. It's IMO, less of a pain and more of prioritizing some feature requests over others. This is why I asked to opensource it, if there's little value that devs see in it. I've made a pull-request to jellyfin to upgrade the bdinfo library to latest uhd-supporting version: https://github.com/jellyfin/jellyfin/pull/1891 And it wasn't that hard. Edited October 14, 2019 by muller_md 1
Luke 42276 Posted October 18, 2019 Posted October 18, 2019 I'm happy to open source it, but what's going to make this hard is you need to change out all of the System.IO.File or Directory methods to instead use our IFileSystem api so that it can support the server's built-in SMB browsing. That's what makes this hard, and that's the primary reason why you can't just dump newer versions of the BDInfo source over the top. It also means you're going to have to do the same thing with DiscUtils. That means you can't add it as a package reference. You'll have to embed the DiscUtils source and then change out all of the IO methods. If you're willing to do that, then i can help you get started.
marcoxyz 1 Posted January 8, 2020 Posted January 8, 2020 Hi Admin Any updates here? It is very painful, no Metadata for UHD HDR Movies on ISO or BDMV Structure. Even if I write a full NFO with all stream information upfront (KODI compatible). The metadata are not recognized by Emby. There is even no way to provide this information over the Metadata Manager. What is the solution here (And no MKV is it not because of preserving the BluRay structure for direct play). Best regards, Marco
marcoxyz 1 Posted January 8, 2020 Posted January 8, 2020 (edited) Me again: https://emby.media/community/index.php?/topic/25219-media-info-of-media-stubs/ Is that still the case that Stream information is not read from the NFO? (it must be an option) Best regards, Marco Edited January 8, 2020 by marcoxyz
Luke 42276 Posted January 11, 2020 Posted January 11, 2020 We'll try to update the code for our bluray support as soon as we can. Thanks for the feedback. 1
muller_md 4 Posted January 29, 2020 Posted January 29, 2020 We'll try to update the code for our bluray support as soon as we can. Thanks for the feedback. Feel free to have a look at the Jellyfin BDInfo contribution (available over nuget as well).
SvANPhOTOART1 7 Posted September 22, 2020 Posted September 22, 2020 Hi friends, i have a new install from Emby on my new maschine, i would like to habe the same layout like on the old one but i dont know how to enable it, can sombody help me? On the new install is liftime licence and working fine, the plugins are installed and enable ... Thanks I would like to have it like on the pictures ...
Luke 42276 Posted September 22, 2020 Posted September 22, 2020 14 minutes ago, tznemet said: Hi friends, i have a new install from Emby on my new maschine, i would like to habe the same layout like on the old one but i dont know how to enable it, can sombody help me? On the new install is liftime licence and working fine, the plugins are installed and enable ... Thanks I would like to have it like on the pictures ... Hi, what does it look like now?
SvANPhOTOART1 7 Posted September 22, 2020 Posted September 22, 2020 like the last picture, on the old maschine like the first 2 pictures ... thank you
SvANPhOTOART1 7 Posted September 22, 2020 Posted September 22, 2020 i would like to have it like on the old server, see the first 2 pictures, the addons are installed and enabled but it dosnt show it like on the first 2 pictures regards thanks
Carlo 4561 Posted September 22, 2020 Posted September 22, 2020 Hi, the difference I see is that one is using the CoverArt plugin and one is not. Have you installed and configured CoverArt on your new machine?
