heula 192 Posted January 26, 2016 Posted January 26, 2016 I think there is an issue with the option "Overwrite existing episodes" in auto organize. I have enabled that option but my existing files (recording) is not replaced by the new one but just added next to the old file. Is this normal behaviour with .ts files or should the extension make no difference. I think but I'm not sure yet this is just with .ts files. Server log 1
moviemadnessman 13 Posted February 11, 2016 Posted February 11, 2016 Delayed reply (doing search research about my own auto-organize question), but to answer your question this is normal behavior, and it is because the extensions are different. If your new episode had also been a .mkv file (or .ts file, I'm not sure which you started with), then it would have been overwritten. As it is, the program moves the new file, but there is no conflict as it has a different extension thus making it a completely different file. 1
heula 192 Posted February 11, 2016 Author Posted February 11, 2016 no, it's more likely a metadata issue Does this mean it can and will be fixed?
Happy2Play 9800 Posted February 11, 2016 Posted February 11, 2016 I don't see how this would be a metadata issues as it would be the same for both episodes. I can see it being an extension issue, since overwrite refers to like name.extensions. Other organizers do the same thing if extensions are different both are added to collection.
Luke 42186 Posted February 11, 2016 Posted February 11, 2016 i doubt there's anything that needs to be fixed. it's probably a value that was missing from your metadata at the time
heula 192 Posted February 11, 2016 Author Posted February 11, 2016 i doubt there's anything that needs to be fixed. it's probably a value that was missing from your metadata at the timeI don't know if that's the case. It's only when the extensions are different. If I rename the extension the same as the excisting file it will always be overwritten. Metabrowser did this always right no matter what the extension was. I have a workaround for my self now by auto renaming all my video files to .mkv. Now if needed all files will be overwritten and I don't get double episodes this way.
softworkz 5127 Posted February 21, 2016 Posted February 21, 2016 i doubt there's anything that needs to be fixed. it's probably a value that was missing from your metadata at the time I think his point is valid. Currently the "overwrite existing" feature is looking at the complete file name only. If there is an existing episode with same name but different video extension, that existing file should be deleted, if "overwrite existing" is activated.
softworkz 5127 Posted February 21, 2016 Posted February 21, 2016 I apologize, you are right! (I looked at the wrong place) Also, I just tested this to be sure and it worked as it should.
Maximus Naxsus 20 Posted February 25, 2016 Posted February 25, 2016 (edited) I have the same issue. Seem to start after the last update. Investigating now. Auto sort doensn't do anything anymore! Started a new topic after a quick browse trow the active posts..; http://emby.media/community/index.php?/topic/31848-auto-sort-isnt-responding-anymore/ Edited February 25, 2016 by Maximus Naxsus
