tre4b 4 Posted December 29, 2015 Posted December 29, 2015 Having made some alterations I now have emby workingish on live TV using HDHomerun. quite a few things still to sort out but one of the currently most disturbing is an aspect ratio flick that occurs when the channel is tuned. The screen keeps flicking between still images that gradualy change but remain still. Each image repeatedly changes from 4:3 to 16:9 and back every second or two in a very distracting way. After a minute or so the flicking settles down and the program starts to run normally. Any ideas how I can stop this?
tre4b 4 Posted January 3, 2016 Author Posted January 3, 2016 Does anyone else even get this? I notice there have been 18 views so wondered if these were other people looking for a solution to this.
Luke 42241 Posted January 3, 2016 Posted January 3, 2016 Hi, I have not seen this before. for media playback issues, please see how to report a problem so that we can best help you. Thanks.
tre4b 4 Posted January 5, 2016 Author Posted January 5, 2016 Hi there, So I took a video of the issue and copied the logs for that day. They are all in here : http://1drv.ms/1TCPXuY
ebr 16335 Posted January 6, 2016 Posted January 6, 2016 Yes, that is a problem in VLC with some SD channels. See here for a possible workaround.
tre4b 4 Posted January 10, 2016 Author Posted January 10, 2016 Okay ta. I thought that might be the case. Good that you have seen it and we will wait for VLC to get itself fixed. Work around did not seem to work but I will keep trying.
