tanStaafl 15 Posted December 4, 2015 Posted December 4, 2015 Ok, I have looked and looked and can find nothing on this in forums or Wiki. There was a popup a while back that said 'Try Multi-select'.. well, I didn't try it and I cannot seem to find where to toggle it or how to use it anywhere. I know it is there hiding from me.. I just don't know where. Can somebody post a 'How to' for multi-select?? Thanks!!
Solution Happy2Play 9811 Posted December 4, 2015 Solution Posted December 4, 2015 Left click and hold on poster. 1
Luke 42242 Posted December 4, 2015 Posted December 4, 2015 Did you read the text inside the message? To edit multiple media items, just click and hold any poster and select the items you want to manage. Try it!
tanStaafl 15 Posted December 4, 2015 Author Posted December 4, 2015 (edited) Luke, apparently I did not Happy2Play thanks for the info, I thought I had tried that! Drat, after all that I finally find the hidden multi-select and no 'Played' option... bummed.. Edited December 4, 2015 by tanStaafl
Chyron 256 Posted December 28, 2018 Posted December 28, 2018 This function appears to not be working while on Emby Connect.
Happy2Play 9811 Posted December 28, 2018 Posted December 28, 2018 (edited) This function appears to not be working while on Emby Connect. Can you explain what is not working. I just marked items as watched and unwatched via app.emby.media. Edited December 28, 2018 by Happy2Play
Luke 42242 Posted December 28, 2018 Posted December 28, 2018 This function appears to not be working while on Emby Connect. Please see how to report a problem. Thanks.
Chyron 256 Posted December 28, 2018 Posted December 28, 2018 (edited) Can you explain what is not working. I just marked items as watched and unwatched via app.emby.media. Hmm... okay, it wasn't working, but now it is. For some reason when I just previously clicked-and-held on a poster---any poster---while in an Emby Connect tab it did nothing. But now I tried it again after you asked me to confirm and it works fine as advertised. So it was just me then, I guess. Working fine now. Edited December 28, 2018 by chyron8472
