Cerothen 98 Posted November 25, 2015 Posted November 25, 2015 I have the library scan hanging at 55.9% for an indefinite period of time (I have never seen it finish). This started in the last 48 hours and I haven't been able to nail down what the issue is so I thought I would post here for some help. I started out by reading this post http://emby.media/community/index.php?/topic/27372-library-scan-hangs-mid-way-takes-7-8-hours-to-complete/?hl=%2Bcomplete+%2Blibrary+%2Bscan and the issue may be the same however I figured I would post this under the linux thread since thats where I am running Emby. I have looked at the log file attached and noticed some weird things that I thought were strange in the log file and I am not sure if they are related: It says there is an error parsing <path>.xml file however I don't store metadata as XMLs and I don't store them with the library data. There are a lot of places where it indicates a GET request to http://domain.tld:8096 (changed from actual) however this isn't a real place as my server has an internal hostname of emby.domain.local and externally its only accessible from either https://domain.tld/emby (or mediabrowser) or https://domain.tld:8920 as a result I thought it was a little strange since none of those requests would likely be answered? Thanks for your feedback! embylog.txt
Cerothen 98 Posted November 26, 2015 Author Posted November 26, 2015 As far as the library not scanning I have removed the music library and the scan completed as expected. I will spend some time trying to identify what is causing the issue in the music library so that it might be able to be improved
Cerothen 98 Posted November 30, 2015 Author Posted November 30, 2015 (edited) I have reinstalled emby on a fresh install of debian 7 and still have no luck completing a library scan with my music folders. I can't seem to determine why it keeps having issues, attached are two different logs with different folders in the music library at the time. EDIT: After a while of hanging on the library scan emby crashes and needs to be manually restarted. If anyone has any I could use some advise. Thanks, Log.txt Log.txt Edited November 30, 2015 by Cerothen
chef 3811 Posted December 1, 2015 Posted December 1, 2015 Besides the crashing part, and the fact I am in Windows not Linux, my media scan has been running for over thirty hours. Not sure if it is connected, probably not, but I thought I would mention it. I am going to begin removing libraraies and adding them back one at a time after a clean database task, and see if that helps. I might consider removing plugins to see if that helps.
Cerothen 98 Posted December 1, 2015 Author Posted December 1, 2015 @@chef Initially I tied a totally clean install without any plugins at all but that didn't seem to resolve it. Also it seems to be exclusively connected to the music library. I have tried adding just a few files in and still no luck. It would be nice if I could identfy if there are just a few trouble files that are causing the issues however I haven't found any such case yet.
chef 3811 Posted December 1, 2015 Posted December 1, 2015 @@chef Initially I tied a totally clean install without any plugins at all but that didn't seem to resolve it. Also it seems to be exclusively connected to the music library. I have tried adding just a few files in and still no luck. It would be nice if I could identfy if there are just a few trouble files that are causing the issues however I haven't found any such case yet. I also have narrowed it down to one particular library and one particular folder which, like you, contains a large amount of media files. I also can't pinpoint the troublesome file. Maybe this should be a feature request?? The library scan could mention the item it is stuck on... Sorry I can't be of help.
Luke 42243 Posted December 1, 2015 Posted December 1, 2015 try disabling some of the music internet metadata providers
Cerothen 98 Posted December 2, 2015 Author Posted December 2, 2015 I removed the "ImageExtractor" image fetcher and the library scan is completing now however the music library doesn't actually have any contents so it isn't adding any music to the library/database. Log Attached. Log.txt
