Chuck 17 Posted October 24, 2015 Posted October 24, 2015 Comcast recently moved HD channels from the 200's to the 800's. I've updated the HomeRun tuner, as well as the Schedule's direct mapping. However, Schedule's direct isn't loading some of the HD channels in the 800's range, despite channel tagging (names) being correct in the Schedules Direct lineup. Is there, or could there, be a way to map a channel guide listing from one channel to another? An example would be, the tuner and Emby guide set to say channel 100, but map the Schedules Direct guide listings from channel 200 to the Emby channel 100 set-up?
ebr 16334 Posted October 24, 2015 Posted October 24, 2015 Manually Assigning tuned stations to those on Schedules Direct
Luke 42241 Posted October 24, 2015 Posted October 24, 2015 Also if the lineup has changed it might be good to report it to schedules direct
rkulagow 19 Posted October 25, 2015 Posted October 25, 2015 @@Chuck Please open a ticket on the Schedules Direct website under "Lineup Support" so that we can find out if Comcast pushed a lineup update; sometimes they don't and we have to remind them about that, and having one or two examples of channels that have been added / deleted helps.
Chuck 17 Posted October 26, 2015 Author Posted October 26, 2015 Thanks ... I've opened a ticket with SD
