genesisforlive 7 Posted October 12, 2015 Posted October 12, 2015 Hello, i have a Problem -.- Look at the Picture not all persons are in the db, when i check the Person manualy it works fine. A lot of people are import normal and other not. What can i do? best regards German Post http://emby.media/community/index.php?/topic/26042-probleme-beim-aktualisieren-der-personen
Happy2Play 9800 Posted October 13, 2015 Posted October 13, 2015 A lot of times it is just to many requests to TMDB and you will see a 429 error in the logs. I don't know if Emby ever follows up on stuff it gets errors on, so you end up doing manual intervention.
genesisforlive 7 Posted October 13, 2015 Author Posted October 13, 2015 Try this thread. Thx i think it works " Survey says: Manual Advanced Refresh (adding only missing data) for the entire folder/library (not just a specific movie) and then Save solves the problem. This is obviously a slight workaround, though, so ideally future server updates may address this behavior so that no user action is required. Thanks to everyone for their input and guidance. "
genesisforlive 7 Posted October 15, 2015 Author Posted October 15, 2015 Hello, i have update the often. but the people does not update Any other ideers?
Luke 42185 Posted October 15, 2015 Posted October 15, 2015 Hello, i have update the often. but the people does not update Any other ideers? Can you please be more descriptive about your problem? Please see http://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
Hydro 5 Posted October 16, 2015 Posted October 16, 2015 Question about people, i set people to actor only but on my movie cast (for example furious 7) i have actor and director and makeup artist and hairstyle artist... On my nfo, everybobdy is under actor bracket. Is it normal ?
Swynol 375 Posted October 16, 2015 Posted October 16, 2015 i think this issue has been resolved in the latest Dev build. i went from Beta to Dev last night and i set the scheduled task for refresh people off which took over an hour to run. i will double check later.
Happy2Play 9800 Posted October 16, 2015 Posted October 16, 2015 Question about people, i set people to actor only but on my movie cast (for example furious 7) i have actor and director and makeup artist and hairstyle artist... On my nfo, everybobdy is under actor bracket. Is it normal ? I don't think limiting your People metadata/image choices to actors prevent cast and crew from being downloaded into movie metadata. Is the server still getting the all the metadata/images for "director and makeup artist and hairstyle artist" or just Actors?
Luke 42185 Posted October 16, 2015 Posted October 16, 2015 Exactly. read the text. Download biography and images for:
Hydro 5 Posted October 16, 2015 Posted October 16, 2015 OK i though without bio / image people didn't show. Maybe future option to only get "main" actors ? Envoyé de mon Nexus 5 en utilisant Tapatalk
