kwilcox 78 Posted October 4, 2016 Posted October 4, 2016 (edited) so this mean that the bitrate settings just lower the video/audio quality to boost the performance, right?! at least it is working fine Correct afik. Lowering bitrate lowers quality and sends less data. So a lower bitrate can be used to get non-buffered playback over a slower connection. I'd still like to find a way to turn transcoding completely off. I'm not sure if that's possible using HLS streams however. Edited October 4, 2016 by kwilcox
Luke 42234 Posted October 4, 2016 Posted October 4, 2016 You would just stream the file directly without hls. You only get to the point of using hls when you know that some kind of conversion is needed.
kwilcox 78 Posted October 5, 2016 Posted October 5, 2016 I thought that was probably it. Thx Luke. The swagger UI doc sucked me in b/c it listed the static parameter in GET /Videos/{Id}/master.m3u8.
kwilcox 78 Posted October 5, 2016 Posted October 5, 2016 (edited) Lots of rainy days in WI USA lately... Edited October 5, 2016 by kwilcox 1
kwilcox 78 Posted October 7, 2016 Posted October 7, 2016 not yet. Working on navigation still. I also haven't implemented the subtitle feature yet. However, l will push a version w/o subtitle support when I get navigation sorted so you can play with it. List box control with a standard remote is a bit of a UI challenge but I think you folks will like the solution. I just have some styling work to do on it tomorrow.
cmarques 14 Posted October 7, 2016 Posted October 7, 2016 Really nice your progress! do not forget the dual audio toggle and what about the LG's QA process? any news?
kwilcox 78 Posted October 7, 2016 Posted October 7, 2016 Well Damnit! My listbox code works great on the WebOS2 emulator (and my TV) but fails dismally on WebOS3. Back to the drawing board on listbox navigation without a magic remote... Dual audio is on the list under (needs more understanding). Subtitles is on the list under (understand how, need to code). v1.0.3 (the version you can get from github) is in process for QA testing currently. LG hasn't looked at it yet.
kwilcox 78 Posted October 12, 2016 Posted October 12, 2016 (edited) Guys, I just pushed a new version with prefs settings additions. I really need somebody with a WebOS3 TV to test the behavior of the color key list boxes in remote control settings. I'm guessing (hoping) that the behavior on an actual TV is different from the emulator. Bottom line: do the up/down buttons on your remote allow you to cycle through options or is the behavior identical to the WebOS3.0 emulator? As with other prefs, you need to press <enter> to edit a highlighted list box item, then <enter> again to exit edit mode. Edited October 12, 2016 by kwilcox
woozle 2 Posted October 12, 2016 Posted October 12, 2016 God I hate the WebOS IDE! I can never remember where the option is to pull from Github... and then I can never get it to connect to the telly (apparently it's an issue lots of people have...) Anyway, got there in the end. I assume you haven't touched any of the HLS/transcoding stuff, so I'm still in the same boat in that respect? Toggling subtitles isn't doing anything for me - should you see anything happen when you do toggle them? Or have you only changed the settings interface so far? On my TV, which is this funny 1+->2 version of WebOS, I'm having some issues with that navigation of the settings. When I click on say the "Red button" option, it goes blue, then if I use down to select the next item in that list, it does that but also moves the cursor down to the next field (green button). It leaves it highlighted blue, but I have to then go back up to the top field if I want to pick the next option in the list! Also, I found similar issues with the video and audio bitrate - somehow I managed to get both boxes highlighted in blue at one point.
kwilcox 78 Posted October 12, 2016 Posted October 12, 2016 (edited) Thanks... I haven't tried it on WebOS1+ at all so your results may vary. On WebOS2, hitting <enter> when an option is highlighted will turn it blue (edit mode), then up/down arrows will cycle through the options. Hitting enter again will exit edit mode (remove blue), then up/down/left/right will navigate between items on the settings screen again. Right now, the only options that are programmed are reset screenplay and toggle controls. Edited October 12, 2016 by kwilcox
kwilcox 78 Posted October 12, 2016 Posted October 12, 2016 (edited) When I can't connect to my TV from the IDE, I first go into the developer mode app on my TV to see if the Key Server is disabled. On my TV, this is always the case when I first turn it on. If re-enabling the key server doesn't fix the problem, I turn developer mode off which resets the TV. Then I turn it back on (resets the TV again), then I enable the key server. This always fixes the connection problem for me. Edited October 12, 2016 by kwilcox
kwilcox 78 Posted October 14, 2016 Posted October 14, 2016 as expected, LG rejected the app because the UI doc wasn't the current version. No quarter given to the fact that it was current when I submitted it; in fact they also stated that they couldn't contact my server to test the app. This was because the credentials were in the UI doc that they rejected for not being current lol... Time for some quality time with powerpoint on the new UI format then re-submit this weekend hopefully...
Jonz 11 Posted October 16, 2016 Posted October 16, 2016 as expected, LG rejected the app because the UI doc wasn't the current version. No quarter given to the fact that it was current when I submitted it; in fact they also stated that they couldn't contact my server to test the app. This was because the credentials were in the UI doc that they rejected for not being current lol... Time for some quality time with powerpoint on the new UI format then re-submit this weekend hopefully... you're doin good mate. Thumbs up
kwilcox 78 Posted October 16, 2016 Posted October 16, 2016 ok.... docs updated, version 1.0.4 sent back to LG for testing. Their new UX doc has tester login data as the first thing. Go figure... I've also pushed v1.0.4 to the repo. I believe it will fix the settings issue that @woozle identified.
woozle 2 Posted October 17, 2016 Posted October 17, 2016 @@kwilcox yes, the settings stuff looks much better now, thanks!
kwilcox 78 Posted October 18, 2016 Posted October 18, 2016 (edited) ok thx. I just pushed v1.0.5 which finishes up the settings fix. I'd still like to know if there's anybody out there running a WebOS3.0 TV that can test this... Edited October 18, 2016 by kwilcox
pellepirat77 0 Posted October 18, 2016 Posted October 18, 2016 Hi! I-ve been using Emby for a while and just bought an LG tv with WebOS 3.0 I would really like to try the Playz-emby app. Can anyone point me to an "how-to" guide for installing it on my TV?
woozle 2 Posted October 18, 2016 Posted October 18, 2016 (edited) @@pellepirat77 As far as I know, there isn't one. You have to use the developer tools and feed it kwilcox's code. This is really the starting point: http://developer.lge.com/webOSTV/develop/web-app/getting-started/ You can PM if you want me to talk you through it. Edited October 18, 2016 by woozle
pellepirat77 0 Posted October 18, 2016 Posted October 18, 2016 @@pellepirat77 As far as I know, there isn't one. You have to use the developer tools and feed it kwilcox's code. This is really the starting point: http://developer.lge.com/webOSTV/develop/web-app/getting-started/ You can PM if you want me to talk you through it. Ok, great! I'll give it a try and report back with my progress.
kwilcox 78 Posted October 18, 2016 Posted October 18, 2016 (edited) Thanks for offering to test! After you are set up with developer tools, you might want to install some GIT tools. I use git-gui for windows: https://git-scm.com/download/win That will make it easier to clone the screenplay app from here: https://github.com/sleuth255/playz-emby Next, in the WebOSTV IDE, choose Import WebOS project from the webOS Menu. Point it to the directory that your local clone is in and it should create the project with GIT linkage to the repository. Let us know if you need help with developer mode on your TV. Since I'm at a pause point on the code, I can help ppl who want to install/test screenplay. Edited October 18, 2016 by kwilcox
kwilcox 78 Posted October 19, 2016 Posted October 19, 2016 Everybody, in anticipation of acceptance of the app by LG ITNF, I've started an official thead for screenplay and have changed the base repositiory as well. That thread is here: https://emby.media/community/index.php?/topic/40456-screenplay-for-webos-20-and-higher-tvs/ I've asked @Luke to close this thread and it is up to him, but I will begin posting to the new topic immediately.
