cdarney3 6 Posted September 27, 2015 Posted September 27, 2015 I'm having problems getting guide data to show up in Emby LiveTV. I have Schedules Direct configured and when I go to that site I see guide XML metadata that shows channels and program information. When I go to Home/LiveTV in Emby there are no channels and no guide at all. I have a HDHR Connect and getting TV from an antenna. I'd really like to get this working but I'm at something of a loss. I've tried refreshing the guide data but it takes 0 seconds to do that. I turned on logging and refreshed again. The log is attacvhed? server-63578956298.txt
Luke 42241 Posted September 27, 2015 Posted September 27, 2015 can you enable debug logging under advanced, restart the server, then repeat? thanks.
cdarney3 6 Posted September 27, 2015 Author Posted September 27, 2015 can you enable debug logging under advanced, restart the server, then repeat? thanks. I Set logging then restarted, followed by: Refresh Guide Refresh Channels Home/LiveTV Guide Channels Recordings Is there anything else I should try so that it's logged? Server Log 9-27-15 1515.txt
Solution Luke 42241 Posted September 27, 2015 Solution Posted September 27, 2015 it looks like the hdhr is returning zero channels from http://10.9.51.101/lineup.json in this case, you probably need to make sure to go through the HDHR setup wizard, have it auto-scan, etc. See here: http://emby.media/community/index.php?/topic/25815-tip-emby-tv-completely-empty-after-adding-tuner-schedules-direct/ 1
cdarney3 6 Posted September 27, 2015 Author Posted September 27, 2015 Well...THAT certainly seemed to work! It found the channels properly and I'm able to watch TV live and schedule future shows. I hope the rest works out to my expectations! Thanks VERY much! 1
