xmario13 1 Posted September 12, 2015 Posted September 12, 2015 There is plugin for enigma2 that connect emby server?
Lee 212 Posted September 12, 2015 Posted September 12, 2015 There is one, I can't get it to work tho others have... lookup vuplus plugin
Lee 212 Posted September 12, 2015 Posted September 12, 2015 http://emby.media/community/index.php?/topic/18999-devvu-enigma2-live-tv-plugin/
xmario13 1 Posted September 12, 2015 Author Posted September 12, 2015 Enigma2 is The Linux-based production software for DVB satellite, terrestrial and cable digital television receivers (set-top box). Enigma2 wiki: http://dream.reichholf.net/wiki/Enigma2 see also https://en.wikipedia.org/wiki/Dreambox https://en.wikipedia.org/wiki/Vu%2B currently is the operating system most used by set-top box
Lee 212 Posted September 12, 2015 Posted September 12, 2015 I can't get the Kofi plugin to work either tho and my webif works perfectly thru vlc or internet explorer???
xmario13 1 Posted September 12, 2015 Author Posted September 12, 2015 i do not would share my livetv to emby server. i would see vod connect on my server in my box.
Lee 212 Posted September 12, 2015 Posted September 12, 2015 only way to do that would be when kodi is updated on E2.. its still an xbmc build in blackhole for my vuplus....
xmario13 1 Posted September 14, 2015 Author Posted September 14, 2015 but it possible write a plugin similar dreamplex to connect emby server? 1
Lee 212 Posted September 15, 2015 Posted September 15, 2015 If only I was a dev... So many projects on here I'd like to get involved with.
Lee 212 Posted September 15, 2015 Posted September 15, 2015 @@Luke just seen that dreamplex is on github, open source. Does emby have enough similarities with plex to make a clone/branch easy? I'll try contact the dev... 1
xmario13 1 Posted September 17, 2015 Author Posted September 17, 2015 news? I have also tried kodi connect 2.0 + plugin.video.emby but plugin do not work... :-(
lilvfr400boy 0 Posted February 11, 2016 Posted February 11, 2016 Any news on this at all , @@Luke what would it cost to have this implemented onto enigma 2. Would love if the Dreamplex add on could be replicated for emby
Luke 42246 Posted February 11, 2016 Posted February 11, 2016 I think it would be a great project for a community member to take on.
Luke 42246 Posted February 11, 2016 Posted February 11, 2016 This is the right place to see if anyone is interested.
Lee 212 Posted February 12, 2016 Posted February 12, 2016 I got no response from the dreamplex dev unfortunately...
Luke 42246 Posted September 12, 2016 Posted September 12, 2016 The Vu+ plugin has been updated with a new configuration screen to match the look and feel of the rest of Emby Server. I think you'll find it much more enjoyable to use and configure now. Thanks.
xero43 0 Posted October 27, 2016 Posted October 27, 2016 where can I get a copy of this plugin? I am just looking for plex and the dreamplex is the only thing I can see missing from your offering
informatyk 2 Posted January 18, 2017 Posted January 18, 2017 Hello! where can I get a copy of this plugin? I have the same question. ...but I think Luke wrote about the plugin for live TV (to stream live TV in the Emby). Does anyone have a plugin for the Emby client for enigma boxes? 2
captain 0 Posted February 20, 2017 Posted February 20, 2017 hello With the source code, can someone make it compatible with emby? https://github.com/DonDavici/DreamPlex/releases
informatyk 2 Posted April 5, 2017 Posted April 5, 2017 Perhaps somebody is able to do it for money? How much would it cost to make a feature?
Luke 42246 Posted November 9, 2017 Posted November 9, 2017 @@xmario13 @@Lee @@captain @@informatyk if you have an enigma tv tuner then we have a better way of using that with Emby. Now with OpenVix you can add your enigma tuner directly to Emby using Emby's native support. No VU+ plugin needed. You can learn more here: https://emby.media/community/index.php?/topic/52762-enigma2-livetvdvr-support/ Thanks ! 1
