KRONZO 20 Posted January 12, 2016 Posted January 12, 2016 This Worked for me too I now have almost fully populated people so THANK you
genesisforlive 7 Posted January 12, 2016 Posted January 12, 2016 This Worked for me too I now have almost fully populated people so THANK you Manuel delet the people folder on Metadata Folder?
G0M 4 Posted January 12, 2016 Posted January 12, 2016 Hi, As i said this didnt work for me even with the altest Beta version. I run emby on Ubuntu 12.04 but it shouldn't be an issue. Any idea what is wrong (my log is in my previous post) Thanks
G0M 4 Posted January 16, 2016 Posted January 16, 2016 Hi, I still don't have the pictures of people here. Anyone to help me please?
Luke 42287 Posted January 16, 2016 Posted January 16, 2016 Yea i think the issues are fixed going forward for new actors, just not yet for existing actors.
zoula 6 Posted January 16, 2016 Posted January 16, 2016 Thank you Luke, So what need to be done to make old actor appear. Do I have to wipe database. ????
Happy2Play 9814 Posted January 16, 2016 Posted January 16, 2016 Thank you Luke, So what need to be done to make old actor appear. Do I have to wipe database. ???? What exactly is the issue? Are the case and crew listed in the movie metadata? Are you just seeing place holders in cast and crew?
zoula 6 Posted January 16, 2016 Posted January 16, 2016 (edited) What exactly is the issue? Are the case and crew listed in the movie metadata? Are you just seeing place holders in cast and crew? Sorry about that.... I've started another tread about this, and I tough that I was in my new thread.... oups.... You could find all the detail in this post http://emby.media/community/index.php?/topic/30021-people-images-not-downloading/ Basically only a few actors are populated in the "People" folder with only XML files no photos. Only manual refresh of single "People" work. I have posted a log in my other post. You could reply in this tread and let die the other on as it may help more then me!! Thank you Zoula Edited January 16, 2016 by zoula
Happy2Play 9814 Posted January 16, 2016 Posted January 16, 2016 Well we need to know if you have a metadata issue before you can worry about the people issue. Does your media show cast and crew without images for TV and Movies?
zoula 6 Posted January 16, 2016 Posted January 16, 2016 I can see all crew members with no photos. Everything is extracted from the nfo files. But for some unknown reason it seams that the photos won't download.
G0M 4 Posted January 16, 2016 Posted January 16, 2016 Same I can see all the crew members with all the photos. When i make a fresh scan of people, Emby will populate the People folder with XML files only.
kjp4756 41 Posted January 19, 2016 Posted January 19, 2016 Emby server 3.0.5786.0 I'm having the exact same issue on my freebsd install since clearing out the ImagesByName folder; none of the actors have any images. Doing a people refresh didn't help. Refreshing all library metadata didn't help. Library scans don't help. In the People subdirectory there are only xml files. If I do a refresh of an individual in the webgui, the jpg for that one person will download successfully. People using windows appear to have no issues so maybe there is something going on with the non windows version of emby? Logs look pretty much OK other than the odd "crash" when querying themoviedb. 2016-01-19 00:35:31.4297 Info App: HttpClientManager GET: http://api.themoviedb.org/3/person/1342059?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=credits,images,external_ids 2016-01-19 00:35:31.5706 Error App: Error getting response from http://api.themoviedb.org/3/person/1342059?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=credits,images,external_ids *** Error Report *** Version: 3.0.5786.0 Command line: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -programdata /var/db/mediabrowser Operating system: Unix 9.3.28.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/db/mediabrowser Mono: 4.2.1 (Stable 4.2.1.124/39edf24 Fri Jan 8 18:46:18 UTC 2016) Application Path: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe One or more errors occurred. System.AggregateException at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x8197d3560 + 0x00038> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x8197d3290 + 0x00118> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x8197d31c0 + 0x000b3> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x8089003e0 + 0x00042> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x80903c920 + 0x0001f> in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>c__async4.MoveNext () <0x81239b040 + 0x01110> in <filename unknown>:0 InnerException: System.Net.WebException The remote server returned an error: (404) Not Found. at System.Net.HttpWebRequest.EndGetResponse (IAsyncResult asyncResult) <0x8137df6d0 + 0x0020d> in <filename unknown>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (IAsyncResult iar, System.Func`2 endFunction, System.Action`1 endAction, System.Threading.Tasks.Task`1 promise, Boolean requiresSynchronization) <0x8137df2d0 + 0x00093> in <filename unknown>:0 2016-01-19 00:35:31.5706 Debug App: MovieDbPersonProvider returned no metadata for /var/db/mediabrowser/ImagesByName/People/G/Gerald B. Greenberg 2016-01-19 00:35:31.5706 Debug App: Saving /var/db/mediabrowser/ImagesByName/People/G/Gerald B. Greenberg to database. 2016-01-19 00:35:31.5724 Debug App: Running PersonXmlProvider for /var/db/mediabrowser/ImagesByName/People/A/Ari Handel 2016-01-19 00:35:31.5724 Debug App: Saving /var/db/mediabrowser/ImagesByName/People/A/Ari Handel to database. 2016-01-19 00:35:31.5744 Debug App: Running PersonXmlProvider for /var/db/mediabrowser/ImagesByName/People/D/David Pirner 2016-01-19 00:35:31.5744 Debug App: Saving /var/db/mediabrowser/ImagesByName/People/D/David Pirner to database. 2016-01-19 00:35:31.5821 Debug App: Running PersonXmlProvider for /var/db/mediabrowser/ImagesByName/People/J/Jennifer Todd 2016-01-19 00:35:31.5821 Debug App: Saving /var/db/mediabrowser/ImagesByName/People/J/Jennifer Todd to database. 2016-01-19 00:35:31.5846 Debug App: Running PersonXmlProvider for /var/db/mediabrowser/ImagesByName/People/L/Larry Lynn 2016-01-19 00:35:31.5849 Debug App: Saving /var/db/mediabrowser/ImagesByName/People/L/Larry Lynn to database. 2016-01-19 00:35:31.5879 Debug App: Running PersonXmlProvider for /var/db/mediabrowser/ImagesByName/People/M/Michael Ewing 2016-01-19 00:35:31.5882 Debug App: Saving /var/db/mediabrowser/ImagesByName/People/M/Michael Ewing to database. 2016-01-19 00:35:31.5899 Debug App: Running PersonXmlProvider for /var/db/mediabrowser/ImagesByName/People/J/Jeanne McCarthy 2016-01-19 00:35:31.5902 Debug App: Saving /var/db/mediabrowser/ImagesByName/People/J/Jeanne McCarthy to database. 2016-01-19 00:35:31.5913 Debug App: Running PersonXmlProvider for /var/db/mediabrowser/ImagesByName/People/D/Douglas Milsome
Happy2Play 9814 Posted January 19, 2016 Posted January 19, 2016 Emby server 3.0.5786.0 I'm having the exact same issue on my freebsd install since clearing out the ImagesByName folder; none of the actors have any images. Doing a people refresh didn't help. Refreshing all library metadata didn't help. Library scans don't help. In the People subdirectory there are only xml files. If I do a refresh of an individual in the webgui, the jpg for that one person will download successfully. People using windows appear to have no issues so maybe there is something going on with the non windows version of emby? Logs look pretty much OK other than the odd "crash" when querying themoviedb. 2016-01-19 00:35:31.4297 Info App: HttpClientManager GET: http://api.themoviedb.org/3/person/1342059?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=credits,images,external_ids 2016-01-19 00:35:31.5706 Error App: Error getting response from http://api.themoviedb.org/3/person/1342059?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=credits,images,external_ids *** Error Report *** Version: 3.0.5786.0 Command line: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -programdata /var/db/mediabrowser Operating system: Unix 9.3.28.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/db/mediabrowser Mono: 4.2.1 (Stable 4.2.1.124/39edf24 Fri Jan 8 18:46:18 UTC 2016) Application Path: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe One or more errors occurred. System.AggregateException at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x8197d3560 + 0x00038> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x8197d3290 + 0x00118> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x8197d31c0 + 0x000b3> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x8089003e0 + 0x00042> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x80903c920 + 0x0001f> in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>c__async4.MoveNext () <0x81239b040 + 0x01110> in <filename unknown>:0 InnerException: System.Net.WebException The remote server returned an error: (404) Not Found. at System.Net.HttpWebRequest.EndGetResponse (IAsyncResult asyncResult) <0x8137df6d0 + 0x0020d> in <filename unknown>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (IAsyncResult iar, System.Func`2 endFunction, System.Action`1 endAction, System.Threading.Tasks.Task`1 promise, Boolean requiresSynchronization) <0x8137df2d0 + 0x00093> in <filename unknown>:0 2016-01-19 00:35:31.5706 Debug App: MovieDbPersonProvider returned no metadata for /var/db/mediabrowser/ImagesByName/People/G/Gerald B. Greenberg 2016-01-19 00:35:31.5706 Debug App: Saving /var/db/mediabrowser/ImagesByName/People/G/Gerald B. Greenberg to database. 2016-01-19 00:35:31.5724 Debug App: Running PersonXmlProvider for /var/db/mediabrowser/ImagesByName/People/A/Ari Handel 2016-01-19 00:35:31.5724 Debug App: Saving /var/db/mediabrowser/ImagesByName/People/A/Ari Handel to database. 2016-01-19 00:35:31.5744 Debug App: Running PersonXmlProvider for /var/db/mediabrowser/ImagesByName/People/D/David Pirner 2016-01-19 00:35:31.5744 Debug App: Saving /var/db/mediabrowser/ImagesByName/People/D/David Pirner to database. 2016-01-19 00:35:31.5821 Debug App: Running PersonXmlProvider for /var/db/mediabrowser/ImagesByName/People/J/Jennifer Todd 2016-01-19 00:35:31.5821 Debug App: Saving /var/db/mediabrowser/ImagesByName/People/J/Jennifer Todd to database. 2016-01-19 00:35:31.5846 Debug App: Running PersonXmlProvider for /var/db/mediabrowser/ImagesByName/People/L/Larry Lynn 2016-01-19 00:35:31.5849 Debug App: Saving /var/db/mediabrowser/ImagesByName/People/L/Larry Lynn to database. 2016-01-19 00:35:31.5879 Debug App: Running PersonXmlProvider for /var/db/mediabrowser/ImagesByName/People/M/Michael Ewing 2016-01-19 00:35:31.5882 Debug App: Saving /var/db/mediabrowser/ImagesByName/People/M/Michael Ewing to database. 2016-01-19 00:35:31.5899 Debug App: Running PersonXmlProvider for /var/db/mediabrowser/ImagesByName/People/J/Jeanne McCarthy 2016-01-19 00:35:31.5902 Debug App: Saving /var/db/mediabrowser/ImagesByName/People/J/Jeanne McCarthy to database. 2016-01-19 00:35:31.5913 Debug App: Running PersonXmlProvider for /var/db/mediabrowser/ImagesByName/People/D/Douglas Milsome Your error is do the person not existing or has been removed from TMDB so you got a (404) error. https://www.themoviedb.org/person/1342059-gerald-b-Greenberg Or his id has changed. https://www.themoviedb.org/person/852-gerald-b-greenberg Looks at the change logs looks like he was added to The Great White Hope.
kjp4756 41 Posted January 19, 2016 Posted January 19, 2016 Your error is do the person not existing or has been removed from TMDB so you got a (404) error. https://www.themoviedb.org/person/1342059-gerald-b-Greenberg Or his id has changed. https://www.themoviedb.org/person/852-gerald-b-greenberg Looks at the change logs looks like he was added to The Great White Hope. Ok, cool. I didn't think those errors were a serious concern. Still doesn't explain why I'm not getting any images unless I do a manual refresh on each person. I do still have my old ImagesByName folder so I will just move that back. It wasn't using the "new" directory structure but it was at least pretty much complete.
zoula 6 Posted January 19, 2016 Posted January 19, 2016 Hi, I may reply that I never had the old directory structure, I'm running windows 10, so It's not a linux trouble... I would like to know if this problem is consider to be a problem and it is in the to do list... I understand that it mat not be a priority or there is some more important things to fix but I'm under the impression that this tread is not really consider a bug...??? I really don't want to sound rude or pushing someone, i'm just asking.... Thank you Zoula
jds828 24 Posted January 20, 2016 Posted January 20, 2016 (edited) I don't really use this but checked. It contains the odd person but by no means complete. I tried a People scan that took ages and.... no more people. Forgot to add. Windows 10 Clean install of Emby a couple of days ago. Edited January 20, 2016 by jds828
Luke 42287 Posted January 20, 2016 Posted January 20, 2016 I don't really use this but checked. It contains the odd person but by no means complete. I tried a People scan that took ages and.... no more people. Forgot to add. Windows 10 Clean install of Emby a couple of days ago. The people refresh does not add people. Chances are you're not actually having a problem, but we can tell more if you provide the server log from that refresh http://emby.media/community/index.php?/topic/739-how-to-report-a-problem/
zoula 6 Posted January 21, 2016 Posted January 21, 2016 OK then, Here is a new log from my system. Earlier in this thread I post older log from my system.... So to resume my bug, I have only a few pictures of "People" I can see all their name but no photos. Like i said earlier I don't think it's IMDB site that is throttling because I can download lot of actor at the same time using "Tiny Media Manager" software. I have some doubt about the NFO files and cross match issue. All my NFO a generated with EMBY. Like others I can update one by one, but this is not a practical solution.... Thank you Zoula server-63588913262.txt
jds828 24 Posted January 21, 2016 Posted January 21, 2016 The people refresh does not add people. Chances are you're not actually having a problem, but we can tell more if you provide the server log from that refresh http://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Hi Luke, If it doesn't add people, what does it do? As I said in my previous post, I'm not really bothered by the actors pictures missing but if you think my log files will help sort it for others, I will gladly post them.
Happy2Play 9814 Posted January 21, 2016 Posted January 21, 2016 Does then new beta help any? 3.0.5842.0 •Support photo orientation•Wake system for scheduled recordings•Update people refresh
kjp4756 41 Posted January 22, 2016 Posted January 22, 2016 Does then new beta help any? 3.0.5842.0 •Support photo orientation •Wake system for scheduled recordings •Update people refresh Beta 5843 seems to have fixed it for me on freebsd. It's taking forever to download the people images but at least it's doing it now. 1
genesisforlive 7 Posted January 23, 2016 Posted January 23, 2016 Hallo, its fixed after you move your Metadirectory. Thx for fixing
pünktchen 1414 Posted January 23, 2016 Posted January 23, 2016 Hallo, its fixed after you move your Metadirectory. Thx for fixing Move where?
pünktchen 1414 Posted January 23, 2016 Posted January 23, 2016 I know where i can change it. I mean from where to where?
