hilfer 0 Posted July 14, 2015 Posted July 14, 2015 Hi all: I installed emby on my new Samsung Tab S. When I loggin to my server I can only see the menus, when I select "home" I see only a grey screen and the other menus: NEXT UP FAVORITES UPCOMING: No splash screen no movie pictures, no shows... nothing. on my mobile phone everything works great (samsung galaxy 3 with android version jellybean) My Samsung tablet has the last android version LOLIPOP vs 5.0.2 anyone else having same problem ?? What can I do to fix that ???
Luke 42242 Posted July 14, 2015 Posted July 14, 2015 Can you grab a log from the device? http://emby.media/community/index.php?/topic/15638-how-to-report-an-android-problem/ Thanks.
hilfer 0 Posted July 15, 2015 Author Posted July 15, 2015 Here you have it. ca835c1b-ef81-488e-b848-c0e7f368b463.log
Luke 42242 Posted July 15, 2015 Posted July 15, 2015 Ok. would you like to get on the beta test group? i would like to take a closer look at this and use the beta releases to get it solved, if it's not already. thanks.
Tranquil 95 Posted July 15, 2015 Posted July 15, 2015 I have the same issue with my Galaxy S4 (GT I 9506). It was working for some time, then, maybe after an update, it fails. Posted my log in the Alpha Area some minutes ago as problem still persists in Alpha Release.
hilfer 0 Posted July 15, 2015 Author Posted July 15, 2015 Ok. would you like to get on the beta test group? i would like to take a closer look at this and use the beta releases to get it solved, if it's not already. thanks. Ok what do I have to do ??
chef 3811 Posted July 15, 2015 Posted July 15, 2015 (edited) Luke this has started to happen to me as well. Here is my log: d3ccc174-a024-4d87-8e3f-342fe88146cb.log Edited July 15, 2015 by chef
chef 3811 Posted July 15, 2015 Posted July 15, 2015 Never mind, my wife's sync adventures rendered emby on my tablet unuseable, I have since figured it out.
