Kosta 8 Posted June 25, 2015 Posted June 25, 2015 Is it possible to customize the default web-view? I'm talking about the first view you see when you click the media in the pull-out menu. It shows by default suggestions, I would rather have it show "Movies" for instance by default. I am aware there is an option to reduce to folder-view, however I like to keep my Collections, which are not displayed in the flat folder view. 1
drakus72 17 Posted June 25, 2015 Posted June 25, 2015 I do believe what you are searching for is in the profile settings per user. Click on the little guy in the top right corner.
Kosta 8 Posted June 25, 2015 Author Posted June 25, 2015 Been there, what I am missing? I can only only see "View Styles", which does what I wrote in my first post. As I want to keep my Collections IN the movies list, I need to use Styles, however it would be nice if I could define WHICH view is a default view that opens (currently it's "Suggestions" and I find myself clicking to Movies each time).
bluemonkey07 590 Posted June 25, 2015 Posted June 25, 2015 (edited) This has been requested many times already, of you search for and up vote one of the feature requests for this it may get some attention Edit: to save you searching here is my one from ages ago http://emby.media/community/index.php?/topic/10783-Web-client-to-remember-"Tab" Edited June 25, 2015 by Vidman 1
emby.ch 3 Posted June 26, 2015 Posted June 26, 2015 You can change this manually and it's very easy. >> Note, make sure you have a backup off your system. 1. go to your ..\dashboard-ui\scripts\ directory. 2. make a copy from "librarybrowser.js" for a backup 3. now open "librarybrowser.js" and search for the row 490 4. change the value from "return 'moviesrecommended.html?topParentId=' + item.Id;" to "return 'movies.html?topParentId=' + item.Id;" 5. click save and save the file 6. delete the browsers cache and cookies 7. Login and enjoy! PS: We have made many changes in our WebClient. If anyone would like to have a look what we made (still in build), go to http://stream.ink and type in the Username "preview" with the password "preview" like blue sliders or a new User-Hovermenu. 1
Kosta 8 Posted June 26, 2015 Author Posted June 26, 2015 Thank you for your reply. Don't get me wrong, and although I find editing code somewhat appealing, I think those options should be available through the GUI. 2
Luke 42186 Posted December 12, 2016 Posted December 12, 2016 The best way to do this is by learning how to build a skin. It's easy and only requires knowledge of html, css and javascript. You can learn more here: https://emby.media/community/index.php?/blog/1/entry-302-learn-how-to-create-skins-for-emby-theater/ Thanks !
