MadStu 0 Posted June 13, 2015 Posted June 13, 2015 Hi, I updated to 1.0.07 earlier today and now when I watch something it doesn't mark as watched. I am running server version 3.0.5621.4 Thanks for the great work :-)
MadStu 0 Posted June 13, 2015 Author Posted June 13, 2015 Also just to say I did reset database after updating, not sure if that makes a difference. Cheers
CBers 7554 Posted June 13, 2015 Posted June 13, 2015 Latest beta of server is v3.0.5641.2. http://emby.media/community/index.php?/topic/21348-emby-latest-versions/ Might be worth updating.
MadStu 0 Posted June 14, 2015 Author Posted June 14, 2015 Latest beta of server is v3.0.5641.2. http://emby.media/community/index.php?/topic/21348-emby-latest-versions/ Might be worth updating. Ok thanks, my server says it has latest version and manually running the update task doesn't update it. I'll wait until it updates itself automatically.
MadStu 0 Posted June 14, 2015 Author Posted June 14, 2015 there is some sort of info in some sort of post somewhere on this forum that give you pointers and stuff on reporting issues and problems.I don't understand what your reply means.
MadStu 0 Posted June 14, 2015 Author Posted June 14, 2015 Latest beta of server is v3.0.5641.2. http://emby.media/community/index.php?/topic/21348-emby-latest-versions/ Might be worth updating. I had it set to update to official release, I changed to beta and have updated to 3.0.5641.2 I reset kodi db again and the bug still exists.
Angelblue05 4132 Posted June 14, 2015 Posted June 14, 2015 @@MadStu Please post a log following: http://emby.media/community/index.php?/topic/17599-how-to-report-a-problem/ We need to see what's actually going on. Thanks
MadStu 0 Posted June 14, 2015 Author Posted June 14, 2015 I have the emby server running on a remote server located in a different country. I have the log but would rather not post those details in a public forum without editing first. And I don't have access to a PC currently in order to edit it.
Angelblue05 4132 Posted June 14, 2015 Posted June 14, 2015 We don't need your server log, just your Kodi log. (The watched status is incorrect in Kodi, right? Sent from my iPhone using Tapatalk
Angelblue05 4132 Posted June 14, 2015 Posted June 14, 2015 Sorry it doesn't show the relevant part in this. It would be a bit after and start with "played information". How is your setup - do you play next item automatically? Does it not mark as watch any of the episodes, or just a few? Sent from my iPhone using Tapatalk
MadStu 0 Posted June 14, 2015 Author Posted June 14, 2015 (edited) My setup doesn't play next item automatically. It appears to mark the episode or movie as watched with the little icon in the corner when it's finished playing, but doesn't disappear from list (kodi set to only show unplayed items). When you go out to main screen and back to episode list / movie list it doesn't show the watched icon. I run kodibuntu in my living room and have a windows server located overseas which the files stream from. It's only not been marking watched since the latest update of kodi emby app. Thanks Edited June 15, 2015 by MadStu
xnappo 1611 Posted June 15, 2015 Posted June 15, 2015 Please see the how to report a problem sticky for how to post a log. 1
Angelblue05 4132 Posted June 15, 2015 Posted June 15, 2015 (edited) @@MadStu If you don't feel comfortable posting your log in this thread, then you can pm me the log file (need the entire log file). Please follow the how to report a problem. Very simple. Thanks. Edited June 15, 2015 by Angelblue05
Solution Angelblue05 4132 Posted June 15, 2015 Solution Posted June 15, 2015 (edited) This is now resolved and a bug fix has been pushed to Github. Edited June 15, 2015 by Angelblue05 1
CBers 7554 Posted June 15, 2015 Posted June 15, 2015 This is now resolved and a push has been pushed to Github. A bug fix? 1
