hifiaudio2 48 Posted June 5, 2015 Posted June 5, 2015 (edited) Running version 2.2.38 on a Nexus 6 (Android 5.1). Server Version 3.0.5621.4 All DTS MA movies play and transcode just fine. TrueHD movies (American Sniper, Jupiter Ascending, Unbroken) crash immediately. FYI the same movies all play fine on the iOS app on my iPad. 0e52da577a950b83de0183/hlsdynamic/main/0.ts?DeviceId=f6e5209d7184f099&MediaSourceId=f5d6dce7250e52da577a950b83de0183&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=25000000&AudioBitrate=320000&MaxAudioChannels=8&MaxWidth=2160&Level=41&ClientTime=1433521033556&MaxVideoBitDepth=8&Profile=high&PlaySessionId=45be7f1b0a5a44c1868affa86c65a405&api_key=0dce3763547e481aa929718035436027 {"Protocol":"File","Id":"f5d6dce7250e52da577a950b83de0183","Path":"E:\\Media\\Movies\\Jupiter Ascending\\Jupiter Ascending.mkv","Type":"Default","Container":"mkv","Name":"1080P/H264/TRUEHD","RunTimeTicks":76543130000,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":false,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","Language":"eng","IsInterlaced":false,"BitRate":30126184,"BitDepth":8,"RefFrames":2,"IsDefault":false,"IsForced":false,"Height":1080,"Width":1920,"AverageFrameRate":23.97602,"RealFrameRate":23.97602,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":41,"IsAnamorphic":false,"IsCabac":true},{"Codec":"truehd","Language":"eng","IsInterlaced":false,"ChannelLayout":"7.1","Channels":8,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"PlayableStreamFileNames":[],"Formats":["mkv","webm"],"Bitrate":30126184,"RequiredHttpHeaders":{}} C:\Users\JohnAdmin\AppData\Roaming\MediaBrowser-Server\ffmpeg\20150331\ffmpeg.exe -t 00:02:00.000 -i file:"E:\Media\Movies\Jupiter Ascending\Jupiter Ascending.mkv" -map_metadata -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -pix_fmt yuv420p -preset superfast -crf 23 -maxrate 25000000 -bufsize 50000000 -vsync vfr -profile:v high -level 41 -force_key_frames expr:gte(t,n_forced*3) -vf "scale=min(iw\,2160):trunc(ow/dar/2)*2" -flags +loop-global_header -sc_threshold 0 -codec:a:0 aac -strict experimental -ac 8 -ab 320000 -af "adelay=1,aresample=async=1" -hls_time 3 -start_number 0 -hls_list_size 0 -y "C:\xxxxxx\AppData\Roaming\MediaBrowser-Server\transcoding-temp\c5866901981f08f5139f7ddd26f6feb9.m3u8" ffmpeg version N-71182-g5cba529 Copyright © 2000-2015 the FFmpeg developers built with gcc 4.9.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-lzma --enable-decklink --enable-zlib libavutil 54. 21.100 / 54. 21.100 libavcodec 56. 32.100 / 56. 32.100 libavformat 56. 27.100 / 56. 27.100 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 13.101 / 5. 13.101 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 1.100 / 1. 1.100 libpostproc 53. 3.100 / 53. 3.100Input #0, matroska,webm, from 'file:E:\Media\Movies\Jupiter Ascending\Jupiter Ascending.mkv': Metadata: title : Jupiter Ascending encoder : libmakemkv v1.9.2 (1.3.0/1.4.1) win(x64-release) creation_time : 2015-05-13 19:32:38 Duration: 02:07:34.31, start: 0.000000, bitrate: 30126 kb/s Chapter #0:0: start 0.000000, end 524.857667 Metadata: title : Chapter 01 Chapter #0:1: start 524.857667, end 1171.128292 Metadata: title : Chapter 02 Chapter #0:2: start 1171.128292, end 1892.891000 Metadata: title : Chapter 03 Chapter #0:3: start 1892.891000, end 2502.166333 Metadata: title : Chapter 04 Chapter #0:4: start 2502.166333, end 2975.347375 Metadata: title : Chapter 05 Chapter #0:5: start 2975.347375, end 3509.547708 Metadata: title : Chapter 06 Chapter #0:6: start 3509.547708, end 4159.989167 Metadata: title : Chapter 07 Chapter #0:7: start 4159.989167, end 4746.992250 Metadata: title : Chapter 08 Chapter #0:8: start 4746.992250, end 5349.052042 Metadata: title : Chapter 09 Chapter #0:9: start 5349.052042, end 5768.512750 Metadata: title : Chapter 10 Chapter #0:10: start 5768.512750, end 6206.575375 Metadata: title : Chapter 11 Chapter #0:11: start 6206.575375, end 6778.688583 Metadata: title : Chapter 12 Chapter #0:12: start 6778.688583, end 7079.238833 Metadata: title : Chapter 13 Chapter #0:13: start 7079.238833, end 7654.313333 Metadata: title : Chapter 14 Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x1080 [sAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc Stream #0:1(eng): Audio: truehd, 48000 Hz, 7.1, s32 (24 bit) (default) Metadata: title : Surround 7.1[libx264 @ 0000000004e0c880] using SAR=1/1[libx264 @ 0000000004e0c880] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 AVX2 LZCNT BMI2[libx264 @ 0000000004e0c880] profile High, level 4.1[aac @ 0000000004e0d740] Unsupported number of channels: 8Output #0, hls, to 'C:\Users\JohnAdmin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\c5866901981f08f5139f7ddd26f6feb9.m3u8': Chapter #0:0: start 0.000000, end 524.857667 Chapter #0:1: start 524.857667, end 1171.128292 Chapter #0:2: start 1171.128292, end 1892.891000 Chapter #0:3: start 1892.891000, end 2502.166333 Chapter #0:4: start 2502.166333, end 2975.347375 Chapter #0:5: start 2975.347375, end 3509.547708 Chapter #0:6: start 3509.547708, end 4159.989167 Chapter #0:7: start 4159.989167, end 4746.992250 Chapter #0:8: start 4746.992250, end 5349.052042 Chapter #0:9: start 5349.052042, end 5768.512750 Chapter #0:10: start 5768.512750, end 6206.575375 Chapter #0:11: start 6206.575375, end 6778.688583 Chapter #0:12: start 6778.688583, end 7079.238833 Chapter #0:13: start 7079.238833, end 7654.313333 Stream #0:0: Video: h264 (libx264), yuv420p, 1920x1080 [sAR 1:1 DAR 16:9], q=-1--1, max. 25000 kb/s, 23.98 fps, 23.98 tbn, 23.98 tbc Metadata: encoder : Lavc56.32.100 libx264 Stream #0:1: Audio: aac, 0 channels, 128 kb/s (default) Metadata: encoder : Lavc56.32.100 aacStream mapping: Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (truehd (native) -> aac (native))Error while opening encoder for output stream #0:1 - maybe incorrect parameters such as bit_rate, rate, width or height Edited June 5, 2015 by hifiaudio2
Luke 42242 Posted June 5, 2015 Posted June 5, 2015 Please report on how it goes with the new app: http://emby.media/community/index.php?/blog/1-emby-blog/
hifiaudio2 48 Posted June 6, 2015 Author Posted June 6, 2015 Works great now! New app looks killer, thanks! So I signed in with Emby connect.... It will just decide to use WiFi when available and cell when not?
