Angelblue05 4132 Posted September 3, 2017 Posted September 3, 2017 Version 2.3.50 Changes: Support PlayPause (new server remote control pause)Fixes: Support series pooling as it is on your server. A database reset is required to apply this change. Once the initial sync is completed, you'll need to run a manual sync once to complete the process. (To be improved once I have more time) Subtitles to use original file container rather than defaulting to srt (for add-on playback) 4
Angelblue05 4132 Posted September 4, 2017 Posted September 4, 2017 (edited) Version 2.3.51 Fixes: Series pooling for non-admin emby users is currently not working. I disabled it temporarily, but it should be resolved with a future server update (I think, I will make a small announcement then). Edited September 4, 2017 by Angelblue05 4
Angelblue05 4132 Posted September 4, 2017 Posted September 4, 2017 Version 2.3.52 Quick follow up patch to 2.3.51. Fixes: Unauthorized error Sometimes, the client would not connect to the server. 5
Angelblue05 4132 Posted October 9, 2017 Posted October 9, 2017 (edited) Version 2.3.53 Fixes: Speed up connection to server Views should appear immediately rather than after connecting to your server Error caused by enabling new setting "limit resolution to screen resolution". It should behave correctly now (it was preventing playback in certain case where the content being played had no width value detected in Emby) Small error in reporting playback Small typo in audio streams Adjust subtitles extraction to follow server settings when transcoding Edited October 9, 2017 by Angelblue05 5
Angelblue05 4132 Posted October 10, 2017 Posted October 10, 2017 Version 2.3.54 Quick follow up to 2.3.53 Fixes: Fixed new speed up connection to server 3
Angelblue05 4132 Posted November 3, 2017 Posted November 3, 2017 Version 2.3.56 Changes: Support server address without a port number Add refresh boxsets (launch the emby add-on > Refresh Boxsets). Fixes: Connection not falling back to external when local is unavailable 2
Angelblue05 4132 Posted November 25, 2017 Posted November 25, 2017 Version 2.3.57 Changes: Update Leia support Update photos (well now home videos and photos) library to properly display. Fixes: Close dialog after syncing collections Fix trakt/watched status issues caused by tvshows being assigned their imdb id instead of tvdb. You'll need to reset your database to fix this (or a repair might do the trick too) Few little things 2
Angelblue05 4132 Posted December 2, 2017 Posted December 2, 2017 Version 2.3.58 Quick follow up to 2.3.57. Fixes: H265 error. 3
Angelblue05 4132 Posted December 13, 2017 Posted December 13, 2017 Version 2.3.59 Changes: The add-on will sync empty shows. Something changed, where the add-on is unable to detect is a show contains episodes or not. For now, I have remove that verification that was currently preventing proper updates.Fixes: Attempt to resolve issues loading the add-on when the system paths contains special characters. 2
Angelblue05 4132 Posted December 17, 2017 Posted December 17, 2017 Version 2.3.60 Quick update to 2.3.59. Let me know if there's any other issues. A big update to playback is being worked on. Fixes: Context menu incorrect label Loading paths that contain special characters 3
Angelblue05 4132 Posted December 18, 2017 Posted December 18, 2017 (edited) Version 2.3.61 Quick update to 2.3.59. Let me know if there's any other issues. A big update to playback is being worked on. Apologies for the rough ride in the past two updates. Hopefully it is back to normal with this version. Fixes: Playback for direct stream. Edited December 18, 2017 by Angelblue05 1
Angelblue05 4132 Posted January 8, 2018 Posted January 8, 2018 (edited) beta Version 3.0.0a The minimum build supported is now Krypton. There is still a few more things left to update for playback, but test and report with your Kodi logs if you encounter any issues. Live TV has been disabled. I don't know if I will re-add it. Reminder: Provide your log, but please use the search/replace function in a text editor to edit out sensitive information such as your ip address or api key. https://emby.media/community/index.php?/topic/17599-how-to-report-a-problem/ Changes: Update playback for Krytpon Support Multi source Add Force Transcode Add a small listener for external players Update dialog skin (thank you sualfred) A few settings for playback have changed, you can view them in the add-on settings > video playback tab. Fixes: Fix for empty shows. Refresh the tv show entry (Kodi context menu > Emby options > Refresh Item) and it will be dropped from the library as it should. Fix the context menu on the home screen If you are still using Kodi Isengard or Jarvis for some reason, you can find the last supported release here: https://github.com/MediaBrowser/plugin.video.emby/releases/tag/2.3.62 Edited January 10, 2018 by Angelblue05 3
Angelblue05 4132 Posted January 10, 2018 Posted January 10, 2018 beta Version 3.0.1a The minimum build supported is now Krypton. There is still a few more things left to update for playback, but test and report with your Kodi logs if you encounter any issues. Reminder: Provide your log, but please use the search/replace function in a text editor to edit out sensitive information such as your ip address or api key. https://emby.media/c...port-a-problem/ Fixes: Listener for external players Theme media 3
Angelblue05 4132 Posted January 12, 2018 Posted January 12, 2018 beta Version 3.0.2a The minimum build supported is now Krypton. Report with your Kodi logs if you encounter any issues. Fixes: Clear the playlist once playback has ended A small bug in direct play detection 3
Angelblue05 4132 Posted January 15, 2018 Posted January 15, 2018 beta Version 3.0.4a Report with your Kodi logs if you encounter any issues. Fixes: External player watched status detection Source selection A few small bugs 3
Angelblue05 4132 Posted January 19, 2018 Posted January 19, 2018 (edited) beta Version 3.0.6a Report with your Kodi logs if you encounter any issues. Changes: Wait until playback ends to process server updatesFixes: Playback for playlists Resume from widgets A few small bugs Edited January 24, 2018 by Angelblue05 4
Angelblue05 4132 Posted January 27, 2018 Posted January 27, 2018 beta Version 3.0.7a Report with your Kodi logs if you encounter any issues. Fixes: Resume playback A few small bugs 3
Angelblue05 4132 Posted January 28, 2018 Posted January 28, 2018 (edited) beta Version 3.0.8a Report with your Kodi logs if you encounter any issues. Fixes: Intros playback Network protocol will now always be lowercase to prevent bugs in Kodi A few small bugs Edited January 28, 2018 by Angelblue05 4
Angelblue05 4132 Posted February 8, 2018 Posted February 8, 2018 (edited) betaVersion 3.0.9aReport with your Kodi logs if you encounter any issues.Fixes: Reverted back to our old dialogs to prevent Kodi from crashing (during initial setup, login screen, etc.), until we can figure out the source of the problem. Source selection for force transcode Trailers Playlists missing extensions Speed up initial server detection process Edited February 8, 2018 by Angelblue05 2
Angelblue05 4132 Posted February 9, 2018 Posted February 9, 2018 betaVersion 3.0.10aReport with your Kodi logs if you encounter any issues.Fixes: Dialogs have been restored (they should no longer cause Kodi to crash) 3
Angelblue05 4132 Posted February 11, 2018 Posted February 11, 2018 betaVersion 3.0.11aReport with your Kodi logs if you encounter any issues. Changes: Artwork urls (ensure original images are used by removing maxheight/maxwidth parameters)Fixes: Playback report 2
Angelblue05 4132 Posted February 21, 2018 Posted February 21, 2018 (edited) small announcement If you have external subtitles and you have a lot of updates generated for content you have not interacted with, update your Emby server to 3.2.70.16 beta or later. Update events should now reflect only content that you have interacted with. Edited February 21, 2018 by Angelblue05 3
Angelblue05 4132 Posted March 3, 2018 Posted March 3, 2018 (edited) betaVersion 3.0.12aReport with your Kodi logs if you encounter any issues. Changes: Artwork for your libraries (compatible with the Embuary skin) Mask the server address and token in logs (only as far as emby for kodi can control) Fixes: Subtitles detection for transcoding Playback path verification (add-on playback mode only) Double prompt during playback that happened under certain conditions. Edited March 3, 2018 by Angelblue05 3
Angelblue05 4132 Posted March 3, 2018 Posted March 3, 2018 betaVersion 3.0.13aA quick follow up update to 3.0.12a, Report with your Kodi logs if you encounter any issues. Fixes: Playback for add-on playback mode 4
Angelblue05 4132 Posted March 10, 2018 Posted March 10, 2018 betaVersion 3.0.14aI would like to move this build to stable very soon. So report them bugs! Changes: Play To supported Unofficially support music for Leia Fixes: Subtitles for transcode sometimes causing an error 3
