kelpo 0 Posted May 30, 2015 Posted May 30, 2015 Hi there, i've setup a nginx reverse proxy on port 443 pointing to embys https port 8920 with a startssl certificate. if i enter these settings in the kodi addon i do get a popup every second that the emby server is unreachable followed by a emby server is online in a infinte loop. i can browse the emby library and even play files the log file has several lines stating: "ERROR: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.requests/lib/requests/packages/urllib3/util/ssl_.py:79: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL appropriately and may cause certain SSL connections to fail. For more information, see https://urllib3.readthedocs.org/en/latest/security.html#insecureplatformwarning. InsecurePlatformWarning" can anyone help me out on this ? thanks in advance
Angelblue05 4132 Posted May 31, 2015 Posted May 31, 2015 @@kelpo Can you let us know what exact settings you've set in Kodi settings to make it HTTPS? Since you are not using a self-signed certificate created by Emby server, you will need to verify the host certificate.
kelpo 0 Posted May 31, 2015 Author Posted May 31, 2015 Hi Angelblue05, i have just the Enable HTTPS setting checked. I have attached a screenshot of a ssl certifcate validation checker Thanks in advance
Angelblue05 4132 Posted May 31, 2015 Posted May 31, 2015 In Kodi, do you have Verify Host SSL Certificate enabled?
kelpo 0 Posted May 31, 2015 Author Posted May 31, 2015 setting that option does not make a difference on my end, i can still stream but the constant connection/disconnection popup is still going on
Angelblue05 4132 Posted May 31, 2015 Posted May 31, 2015 Ok, can you post your log set to info: http://emby.media/community/index.php?/topic/17599-how-to-report-a-problem/
