Luke 42241 Posted March 9, 2016 Author Posted March 9, 2016 you see stuttering during playback? that i haven't seen.
jasonmcroy 320 Posted March 9, 2016 Posted March 9, 2016 Yes. It is like a micro stutter, mainly during action shots or when the camera pans around. That being said, I am currently watching a show on Amazon Prime and am seeing the same thing so maybe it's not a problem with the App. I can do some more testing tomorrow with different settings. Sent from my SM-G386T1 using Tapatalk
onemoredave 2 Posted March 9, 2016 Posted March 9, 2016 I've separated the skip settings, so now you can do separate values for forward and back. If you already customized you'll need to reconfigure. Awesome, I hadn't found this feature...it was one of the main reasons I haven't been able to get my partner away from using media center :-)
Luke 42241 Posted March 10, 2016 Author Posted March 10, 2016 Text-based subtitles are now fixed in Microsoft Edge, both on the PC and Xbox One. Please try it out, thanks.
Lawrage 13 Posted March 10, 2016 Posted March 10, 2016 I've added more xbox one performance improvements for you guys to try out. @@Luke, say what, how does this integrate with the Xbone?
Happy2Play 9811 Posted March 11, 2016 Posted March 11, 2016 @@Luke, say what, how does this integrate with the Xbone? I believe this is in reference the web app. http://emby.media/community/index.php?/topic/2142-emby-theater/?p=307615
Luke 42241 Posted March 11, 2016 Author Posted March 11, 2016 Yes, just use the Edge browser on Xbox One, you can even add it to your homescreen which basically turns it into an app. And you can control it with the basic directionals on your gamepad.
danswan 13 Posted March 11, 2016 Posted March 11, 2016 I'm confused - why is the edge/browser stuff in the Emby Theater section? Is there a relationship?
bluemonkey07 590 Posted March 11, 2016 Posted March 11, 2016 (edited) To unconfuse and to see the relationship follow the link a couple posts up Edit: or alternatively read the blog https://emby.media/introducing-the-new-emby-theater-for-windows-and-the-web.html Edited March 11, 2016 by Vidman 1
Luke 42241 Posted March 11, 2016 Author Posted March 11, 2016 Mouse wheel vertical scrolling on settings pages is fixed now
shaefurr 1340 Posted March 11, 2016 Posted March 11, 2016 So I read through that blog post again, noticed this typo. Wait, if This is HTML... Does that mean the built-in web app could be made to animate as smoothly as Emby Theater? Yes! It can, and it will. But the built-in web app has to support older browsers such as Internet Explorer, so it will take a little longer to get there. So Which Version Should I Use? It really depends. For most users, we suggest that if you need HD Audio Bistreaming, External Players, or MadVR, you'll want to use the native windows app. For everyone else, the web app with Chrome running in full-screen is a great option. Yes! It can, and it will. But the built-in web app has to support older browsers such as Internet Explorer, so it will take a little longer to get there.
LiquidFX 144 Posted March 12, 2016 Posted March 12, 2016 A few thing that stop me from using Emby Theater as my daily driver: It doesn't seem to stay on top of other apps, often times another background app will pop up and take focus Unlike WMC it doesn't timeout and revert to the login screen for users, good feature for kids like mentioned above I do notice a micro stutter on some of the animations every few movements Cant wait on the future though, been a fan since MB2.
Luke 42241 Posted March 12, 2016 Author Posted March 12, 2016 Version 2.0.4 is up and bumps the embedded Chromium from version 47 to 49. It improves animation performance a little bit more, not that the app was struggling in that regard.
techywarrior 689 Posted March 12, 2016 Posted March 12, 2016 Is there anything that can be done in regards to giving user feedback while the app is updating? On my tablet, which has limited WiFi speed can take a couple of minutes to update. During this time the screen just stays transparent (you can see the desktop or other windows that were open). Without knowing that it is updating you may assume that something has gone wrong. It would be really nice if there was some sort of indicaton that it was updating. At minimum even a spinning icon would be good but ideally I think a progress indicator with the percent of the total that has been downloaded would be great. 1
Spaceboy 2573 Posted March 12, 2016 Posted March 12, 2016 Is there anything that can be done in regards to giving user feedback while the app is updating? On my tablet, which has limited WiFi speed can take a couple of minutes to update. During this time the screen just stays transparent (you can see the desktop or other windows that were open). Without knowing that it is updating you may assume that something has gone wrong. It would be really nice if there was some sort of indicaton that it was updating. At minimum even a spinning icon would be good but ideally I think a progress indicator with the percent of the total that has been downloaded would be great. Yeah that would be useful. I've been closing it assuming it's crashed, when it's probably been trying to update
nicko84 72 Posted March 12, 2016 Posted March 12, 2016 Hi When i try to install Emby Theater 2.0.4 on Windows 7 i've this message (in french sorry !) : "electron.exe Point d'entrée introuvable Le point d'entrée de procédure PowerPlatformRolEx est introuvable dans la bibliothèque des liens dynamiques POWRPROF.dll" And no way to install Emby Theater when i answer OK I've no problem on Windows 10 to install it. Thanks
Luke 42241 Posted March 12, 2016 Author Posted March 12, 2016 Hi When i try to install Emby Theater 2.0.4 on Windows 7 i've this message (in french sorry !) : "electron.exe Point d'entrée introuvable Le point d'entrée de procédure PowerPlatformRolEx est introuvable dans la bibliothèque des liens dynamiques POWRPROF.dll" And no way to install Emby Theater when i answer OK I've no problem on Windows 10 to install it. Thanks http://emby.media/community/index.php?/topic/32556-powrprofdll-error/?p=311324
vick1982 15 Posted March 13, 2016 Posted March 13, 2016 is there no sorting onthe new emby theater for windows?... it would be good to be able to see all tv shows and movies in order of latest to oldest .. not just the preset amount on the homepage
Koleckai Silvestri 1154 Posted March 13, 2016 Posted March 13, 2016 is there no sorting onthe new emby theater for windows?... it would be good to be able to see all tv shows and movies in order of latest to oldest .. not just the preset amount on the homepage There is no filtering or sorting currently. At least none that I can find.
Fratopolis 64 Posted March 13, 2016 Posted March 13, 2016 (edited) Not sure if this has been mentioned but when Emby theater is open from a remote location it sucks down all my upload bandwidth while just sitting at the menus. Is this due to it rotating the previews that flip through? Meaning if someone leaves this open it causes buffering for others watching. Is there a way to make Emby theatre act more like the Android TV version. More static from menu to menu. Also would it not make more sense to standardize the layouts more. The layout for Emby for android TV is awesome and just wondering if there will or is a client just like that for windows. Just wondering on the layouts is all. Mostly I only care about the product for myself. And for myself the product is awesome. Edited March 13, 2016 by Fratopolis
Luke 42241 Posted March 13, 2016 Author Posted March 13, 2016 Not sure if this has been mentioned but when Emby theater is open from a remote location it sucks down all my upload bandwidth while just sitting at the menus. Is this due to it rotating the previews that flip through? Meaning if someone leaves this open it causes buffering for others watching. Is there a way to make Emby theatre act more like the Android TV version. More static from menu to menu. Also would it not make more sense to standardize the layouts more. The layout for Emby for android TV is awesome and just wondering if there will or is a client just like that for windows. Just wondering on the layouts is all. Mostly I only care about the product for myself. And for myself the product is awesome. Each app generally tries to do what is accepted and established on its' respective platform. Android TV is dominated by the vertical card layouts. On windows, the xbox-inspired layout has been very popular for us, but users are beginning to come around to more vertical designs as the new detail screen has been well received. Perhaps someone will do a skin for android tv. Flexage actually already whipped up an android tv sound effects plugin, although I haven't created a plugin catalog yet.
Fratopolis 64 Posted March 13, 2016 Posted March 13, 2016 Each app generally tries to do what is accepted and established on its' respective platform. Android TV is dominated by the vertical card layouts. On windows, the xbox-inspired layout has been very popular for us, but users are beginning to come around to more vertical designs as the new detail screen has been well received. Perhaps someone will do a skin for android tv. Flexage actually already whipped up an android tv sound effects plugin, although I haven't created a plugin catalog yet. Gotcha!
vick1982 15 Posted March 14, 2016 Posted March 14, 2016 There is no filtering or sorting currently. At least none that I can find. yeah... i dont understand why this isn't normal feature hat should be there..
Luke 42241 Posted March 14, 2016 Author Posted March 14, 2016 because the app knows it's target audience which is largely people that just want to sit down and press play. it will have sorting and filtering and all of that, but that's why it didn't make the first cut.
