tphillip1120 2 Posted May 13, 2015 Posted May 13, 2015 Since several Emby updates ago, Live TV through the Emby Web interface and through my Roku 3 plays for a few minutes at most and then exits. Looking at my ServerWMC Log file it appears as though ServerWMC is receiving a request from Emby Server to close the stream. I am using a a Hauppauge 2250 WinTV Card which does not support DLNA, so I have disabled Stream Live channels using DLNA to MediaBrowser in the ServerWMC Live TV Config hoping this was the problem. Emby seemed to play Live TV a little longer after changing this setting but is still exiting after a minute or two. I have attached both the logs for ServerWMC (partial log) and for Emby. Hopefully someone can help me figure out what the problem might be. Thanks, Tony ServerWMCLog.txt server-63567113246.txt transcode-4e8f0a18-84c7-4f53-aa4c-ddfbce6a13dd.txt
tphillip1120 2 Posted May 13, 2015 Author Posted May 13, 2015 I am at work right now and ready to leave, but started a live tv stream in chrome and it has been playing now for 12 minutes. I will continue to let it run and remote to my desktop later to see if the stream is still playing. Playing for 12 minutes now through Chrome is encouraging though. I will disconnect the work stream and see how long I can stream live tv from home tonight. The stopping after a few minutes was happening in both Firefox and Internet Explorer.
tphillip1120 2 Posted May 14, 2015 Author Posted May 14, 2015 Now this is strange. While accessing Live TV from a very fast connection (work connection at 50 mbs download speed) using Google Chrome, the connection seems to stream fine. When at home accessing Live Tv through Google Chrome with a 3 mbs download speed live tv exits after a minute or two. I have the stream settings in Emby set to 480X1.5 mbs at both locations. I even tried a 480X1.0 mbs setting on the slower connection. When I first tried streaming it seemed to work longer. Subsequent attempts to stream live tv played for less time before the stream stopped. I noticed you just released an update to the Roku app which I have not been able to try yet, but last night I noticed these issues: 1. When attempting to play a live tv channel from the Guide, The Roku app blows up and sends me back to my Roku Main Menu. 2. When attempting to play a live tv channel from the Channels Section of the Roku App the stream plays for a little bit and then stops. 3. Movies play fine from within the Roku App with the exception of some buffering issues occurring after the stream has played for about an hour. I have attached logs files from yesterday and today. Thanks, Tony server-63567085826.txt server-63567172127.txt ServerWMC.log ServerWMC_20150513.log transcode-4c6e19dc-1e7c-44d1-8479-948c82a500c7.txt transcode-8cb1d15e-f73e-441f-8c49-a97fa92b596c.txt transcode-41a0523c-b82f-4f32-ba2e-ec28706dac86.txt transcode-948c0e9d-e732-4419-af4e-b48dabfe1b4a.txt transcode-e8e53db7-3d2e-461f-a8ff-249185ce75db.txt
krustyreturns 191 Posted May 14, 2015 Posted May 14, 2015 This is not related to your live-tv problem, but looking at your serverwmc log you have the setting 'Debug_RemuxAllRecordings' set to true. There is really no reason to set this, it's really only there for debugging and will make the playback of wtv files slower than they need to be. As for the problem with streams stopping early for live tv, one thing that would be interesting to try is to go to the 'http service' tab in serverwmc and enable the http host service. After it is enabled, on the same page enable 'Use URLs insteam of SMB... ...for MediaBrowser-Server'. See if running in this mode has an impact on the stopping early problem. 1
tphillip1120 2 Posted May 15, 2015 Author Posted May 15, 2015 Krusty your a genius! After implementing your suggestions, I ran multiple tests last night and streaming live tv is working perfectly now through the Roku and the Web Client even through a slow 3 mbs internet connection. No more Roku app blowups either when attempting to play live tv through the Roku Guide! 1
krustyreturns 191 Posted May 15, 2015 Posted May 15, 2015 That's great, thanks for letting me know. I have been wanting someone who has the 'live-tv stops early' problem, that shows up in non-dlna mode, to test this. I was hoping the above fix would work but since I don't have the problem I couldn't test it.
tphillip1120 2 Posted May 15, 2015 Author Posted May 15, 2015 Your welcome and thank you for figuring this out. I just ordered a Ceton 4 tuner card so I am anxious to begin testing on it as well. I believe that card does support DLNA.
krustyreturns 191 Posted May 15, 2015 Posted May 15, 2015 I don't think it does do dlna. I think only si-dust tuners like the hdhr prime do.
tphillip1120 2 Posted May 15, 2015 Author Posted May 15, 2015 Well, it will be another good test of non DLNA mode then with other hardware. I am looking for better resolution since the Hauppauge analog tuners are not good at displaying tv in 16x9 format.
Falstaff 0 Posted June 19, 2015 Posted June 19, 2015 As for the problem with streams stopping early for live tv, one thing that would be interesting to try is to go to the 'http service' tab in serverwmc and enable the http host service. After it is enabled, on the same page enable 'Use URLs insteam of SMB... ...for MediaBrowser-Server'. See if running in this mode has an impact on the stopping early problem. I know this is an old post, but these settings fixed the problem for me. Thanks Krustyreturns!
Luke 42237 Posted June 19, 2015 Posted June 19, 2015 @@Falstaff, good to know, thanks. Just curious, is http the default for new installations?
krustyreturns 191 Posted June 19, 2015 Posted June 19, 2015 No, its not. I thought it might solve the long standing problems we have had with streams stopping early (in non-dlna) but I really wanted to get some testing done with it before I made it the default.
bmoses 9 Posted June 20, 2015 Posted June 20, 2015 just adding some more evidence in case you didn't see it. i had the same issue on my nexus player and turning on the http stream option appears to have fixed it for me http://emby.media/community/index.php?/topic/22452-nexus-player-live-tv/
krustyreturns 191 Posted June 20, 2015 Posted June 20, 2015 @@bmoses, thanks - I didn't know about this thread (someone should have slapped a @krustyreturns in there). I think I will make a sticky about this issue in this forum and think about how to make this the default in serverwmc for emby going forward.
Pcrockett83 0 Posted July 27, 2015 Posted July 27, 2015 I was having the same issue with my Roku 3, where the live stream from Emby would sometimes stop on its own, although in my case it sometimes wouldn't happen for 20 or 30 minutes. Anyway, this solution seems to have fixed the problem for me.
mjktg99 35 Posted July 27, 2015 Posted July 27, 2015 I don't watch much live TV anymore... but this would randomly happen to me on my Roku. Although, for me it would be after an hour or 2 that it would just stop. And sometimes not at all. I changed this setting and hopefully that fixes this issue. Especially with NFL starting soon.
mjktg99 35 Posted August 17, 2015 Posted August 17, 2015 As for the problem with streams stopping early for live tv, one thing that would be interesting to try is to go to the 'http service' tab in serverwmc and enable the http host service. After it is enabled, on the same page enable 'Use URLs insteam of SMB... ...for MediaBrowser-Server'. See if running in this mode has an impact on the stopping early problem. I just want to follow up that this has seemed to resolve 2 issues for me. 1 is with the Live Stream stopping early. The other is about 50% of the time when I would hit play on a channel, it would start loading but never load and go back to the channel screen. After making this change, that hasn't happened at all.
btgerold 3 Posted October 5, 2015 Posted October 5, 2015 I was having the same issue, and this appears to have fixed it on Roku. Still having issues streaming to the Android app. Will try restarting everything to see if that helps.
