the-dumb1 136 Posted May 1, 2015 Posted May 1, 2015 Hi folks, Brand new install of Ubuntu 15.04 with Emby successfully installed. I have a 4 TB encrypted (LUKS) drive. I've successfully mounted it and am able to read/open files from it, but for the life of me, I can't get Emby to add ANY path on the drive to the Media Library. When I try to select the path (/media/test/multimedia), all I see Emby telling me is that the path does not exist--and it will not even let me navigate the structure of the drive. I'm guessing this is a permissions issue, but I don't understand it well enough to mess around in it--I'm hoping someone can shed some light on this for me? Thanks!
bwoah 0 Posted May 2, 2015 Posted May 2, 2015 I am having the same problem. I added emby to a group called "storage". This group has read-write permissions for my attached USB harddrive. Still get the " This path does not exist message." Wondering what to try next.
vindicator 1 Posted May 11, 2015 Posted May 11, 2015 I have a similar issue, but only with the TV Media Folder (http://emby.media/community/index.php?/topic/15820-tv-shows-type-folders-now-show-empty-all-of-a-sudden/).
domenic 33 Posted May 11, 2015 Posted May 11, 2015 Same issue here, I had to add another mount the drive as smb and from there it worked..... not certain why?
