ebr 16337 Posted May 28, 2015 Posted May 28, 2015 See if it works for you now. I just re-set everyone's free trial for Sync for another two weeks since we are rolling out support for it slowly.
bluemonkey07 590 Posted May 28, 2015 Posted May 28, 2015 (edited) Sorry just to clarify, we are discussing the mobile app right? Edited May 28, 2015 by Vidman
saitoh183 137 Posted May 28, 2015 Author Posted May 28, 2015 Sorry just to clarify, we are discussing the mobile app right? Mobile
Hydro 5 Posted May 29, 2015 Posted May 29, 2015 See if it works for you now. I just re-set everyone's free trial for Sync for another two weeks since we are rolling out support for it slowly.Thank But no change for me. I try to create new sync job with one item in original quality. I reboot server many time, open / close android app, hit convert button but it did nothing Must I need android app beta ?
Luke 42243 Posted May 29, 2015 Posted May 29, 2015 No, the best thing to do is wait until we announce the sync feature for android.
Luke 42243 Posted June 5, 2015 Posted June 5, 2015 Mobile sync is here: http://emby.media/community/index.php?/blog/1-emby-blog/
Hydro 5 Posted June 7, 2015 Posted June 7, 2015 Great feature ! Few questions : - we've got task for convert but no task for transfer. When does he transfer video ? As soon as he can ? - is it possible to have notification when movie have been transferred ? Sent from my Nexus 5 using Tapatalk
Luke 42243 Posted June 7, 2015 Posted June 7, 2015 it syncs hourly. you can force a sync in android system settings -> accounts. i will add a button inside the app. and yes, notifications are a good idea.
Hydro 5 Posted June 10, 2015 Posted June 10, 2015 Hi Is it possible to use emby app offline ? I won't be able to access to my sync movie because i can't connect to my server. Maybe i miss a step.
Luke 42243 Posted June 10, 2015 Posted June 10, 2015 Hi Is it possible to use emby app offline ? I won't be able to access to my sync movie because i can't connect to my server. Maybe i miss a step. coming very soon.
Hydro 5 Posted June 10, 2015 Posted June 10, 2015 Maybe some improvements for sync : - be able to sync subtitle too - when you sync a season for exemple, the badge on the poster show all episode sync even those delete on the device because watched. Maybe it just show number of episode on the sync target ?
thefirstofthe300 292 Posted June 12, 2015 Posted June 12, 2015 Maybe some improvements for sync : - be able to sync subtitle too - when you sync a season for exemple, the badge on the poster show all episode sync even those delete on the device because watched. Maybe it just show number of episode on the sync target ? You are currently able to sync subtitles as I have actually had my device do it. I believe that if the app will play subtitles on a file because of the app preferences, it will sync them in a sync job. If the app won't play subtitles by default during playback, it won't sync the subtitles. Sent from my Nexus 7 using Tapatalk
Pete_Repeat 1 Posted August 29, 2015 Posted August 29, 2015 Any updates n when the Android app will allow offline browsing, or at least navigating to the synced files and also update the play count once back online?
Pete_Repeat 1 Posted September 3, 2015 Posted September 3, 2015 Thanks for the comment. I know it's difficult to put a date, and you wouldn't want to as it can just cause hassles if the deadline isn't met, but any idea what "soon" means? Months, weeks, maybe next year? Reason I ask is that 3 months ago it was "very soon" and offline sync of vieo and play counts is the main thing that brought me to Emby. I know the app has many other strengths that others utilise, but for me sync and playcount for offline use is the main importance. Nothing else does it well on Android apart from MediaMonkey of which I don't particularly like using anymore.
bry 12 Posted September 3, 2015 Posted September 3, 2015 It's coming soon.Thanks luke Sent from my XT1254 using Tapatalk
Pete_Repeat 1 Posted September 19, 2015 Posted September 19, 2015 Can you say which release it is aimed for? It's not in the beta's yet is it? I know my needs aren't the only ones, but I am paying $5 a month waiting on this offline mode. Without this, then Emby is just not being used in my case. repeat, I know that Emby has plenty of other great features, it's just I'm only really subscribed to do sync of video, sync of play count, and all the playcount and playback needs to work offline for it to be of benefit to me.
Luke 42243 Posted September 19, 2015 Posted September 19, 2015 It will be in the next significant app update. It is next on the list. The only reason it would not be in the very next release is in the event we have to put out some kind of bug fix for whatever reason. 4
thefirstofthe300 292 Posted September 21, 2015 Posted September 21, 2015 It will be in the next significant app update. It is next on the list. The only reason it would not be in the very next release is in the event we have to put out some kind of bug fix for whatever reason.YES! Sent from my Nexus 7 using Tapatalk
john6555 0 Posted October 20, 2015 Posted October 20, 2015 1 month on -- any news you can share? So anxious
Pete_Repeat 1 Posted October 21, 2015 Posted October 21, 2015 1 month on -- any news you can share? So anxious Same here. This is the key feature I came to Emby for (sync and watch unwatched video).. Waiting with a subscription for this feature. It's been since June that it was coming soon so I'm starting to wonder if it's still months away.
Pete_Repeat 1 Posted October 25, 2015 Posted October 25, 2015 (edited) It's coming soon. So is this likely to be out before the end of next month? It's not even in the Beta release yet is it? I signed up for that but I don't notice anything different. I recognize that Emby is useful for others in so many ways, but syncing and viewing the synced video without an internet connection is the only reason why I subscribed. So I am curious whether it's worth me keeping the subscription going just in anticipation for another 6 months or more... Edited October 25, 2015 by Pete_Repeat
Stormrider959 0 Posted November 1, 2015 Posted November 1, 2015 If you have synced your videos you can access them over the filesystem on the phone and play them with another player. I know it's just a workaround but it did work for me.
