ebr 16310 Posted May 7, 2015 Posted May 7, 2015 Yes, but the server isn't recreating those images during every scan because the timestamps are unchanged during the scans. It only extracts when it can't find metadata on the net about the movie, right? I usually only use that feature for home movies on one folder. If that's what is causing the long scans, then providing an option to only create them for a certain library would be helpful, because for the most part, I only want it to create those images for home videos, or when I manually refresh data on a video that doesn't have any internet-downloadable metadata (like a workout video or a video downloaded from the internet). He said chapter images... not just single screencaps. Do you have those enabled?
oldschool 16 Posted May 7, 2015 Posted May 7, 2015 He said chapter images... not just single screencaps. Do you have those enabled? Sorry - I misread. Yes, it seems like it is on by default for Movies and Home Videos. I turned it off for Movies (all the movies in the movies library are well known enough to find images for them). It looks like without the realtime monitor on, Emby is only scanning on the scheduled scan and took 1 hour and 8 minutes to scan. The scan last night only encountered 2 new movies from the day before (no new pictures, home videos, etc).
richardbigg 1 Posted May 8, 2015 Posted May 8, 2015 Ok, so I bailed on the Ubuntu server, couldnt' get it to run... Kept crashing after start up.. Switched over to Windows 7 Pro. However, it can't successfully scan the media library, the same media library the Ubuntu version was successfully able to scan. (In fact, it's still on the ubuntu and being accesed over network) The scan will run for, then fail... If I restart it does the same thing... This little snipliet about Yo Gabba Gabba (Yes, I have a kid that likes it... It's not me) 2015-05-07 07:58:25.8838 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 2f266ab07b6c44928031a2fbe29618f1 2015-05-07 07:58:34.6043 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: f4728637a9a54c54965f1f03a9ecfb2a 2015-05-07 07:58:56.3225 Debug - App: Running FFProbeProvider for \\media\Movies\Brave (2012) [HD] [5.1]\Brave (2012) [HD] [5.1].mkv 2015-05-07 07:58:56.3225 Debug - App: Running MovieNfoProvider for \\media\Movies\Brave (2012) [HD] [5.1]\Brave (2012) [HD] [5.1].mkv 2015-05-07 07:58:56.3555 Debug - App: Saving \\media\Movies\Brave (2012) [HD] [5.1]\Brave (2012) [HD] [5.1].mkv to database. 2015-05-07 07:59:11.8174 Info - App: HttpClientManager GET: http://www.thetvdb.com/api/GetSeries.php?seriesname=Yo+Gabba+Gabba&language=en 2015-05-07 07:59:11.8454 Debug - HttpServer: HTTP Response 204 to 10.0.0.160. Response time: 65148.7263 ms. Url: http://10.0.0.100:8096/ScheduledTasks/Running/2d67d886717cdade18d9640d4ebbb9cb 2015-05-07 07:59:11.8784 Debug - HttpServer: HTTP GET http://10.0.0.100:8096/ScheduledTasks?IsEnabled=true Ip: 10.0.0.160:50652. Headers: Host=10.0.0.100:8096,Accept-Language=en-us,Accept-Encoding=gzip, deflate,Connection=keep-alive,Accept=application/json, text/javascript, */*; q=0.01,User-Agent=Mozilla/5.0 (iPhone; CPU iPhone OS 8_1 like Mac OS X) AppleWebKit/600.1.4 (KHTML, like Gecko) Version/8.0 Mobile/12B411 Safari/600.1.4,Authorization=MediaBrowser Client="Dashboard", Device="Safari 600.1.4 Iphone", DeviceId="cecbe14e56bd047f4a6c80ffd9ce056d62e65c30", Version="3.0.5597.1", UserId="43e845c29a04485f862f3a411bc2c1fb",X-MediaBrowser-Token=fcdb51b616bc485e86c9978ef640c7ba 2015-05-07 07:59:11.8784 Debug - HttpServer: HTTP Response 200 to 10.0.0.160. Response time: 2.0001 ms. Url: http://10.0.0.100:8096/ScheduledTasks?IsEnabled=true 2015-05-07 07:59:12.2874 Info - App: TVDb Provider - yo gabba gabba did not match yo gabba gabba 2015-05-07 07:59:12.2874 Info - App: TVDb Provider - Could not find Yo Gabba Gabba. Check name on Thetvdb.org. 2015-05-07 07:59:12.2874 Debug - App: Running SeriesNfoProvider for \\media\Series Shows\Yo Gabba Gabba 2015-05-07 07:59:12.2874 Debug - App: SeriesNfoProvider returned no metadata for \\media\Series Shows\Yo Gabba Gabba 2015-05-07 07:59:12.2874 Debug - App: Running SeriesXmlProvider for \\media\Series Shows\Yo Gabba Gabba 2015-05-07 07:59:12.3064 Error - App: Error *** Error Report *** Version: 3.0.5597.1 Command line: C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Richard\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Object reference not set to an instance of an object. System.NullReferenceException at MediaBrowser.Providers.TV.SeriesMetadataService.MergeData(Series source, Series target, List`1 lockedFields, Boolean replaceData, Boolean mergeMetadataSettings) at MediaBrowser.Providers.Manager.MetadataService`2.<RefreshWithProviders>d__2d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Providers.Manager.MetadataService`2.<RefreshMetadata>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.BaseItem.<RefreshMetadata>d__1e.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.TV.Series.<RefreshAllMetadata>d__10.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.Folder.<RefreshChildMetadata>d__d6.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.Folder.<RefreshMetadataRecursive>d__cd.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.Folder.<RefreshChildMetadata>d__d6.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.Folder.<RefreshMetadataRecursive>d__cd.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Controller.Entities.Folder.<ValidateChildrenInternal>d__ba.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Server.Implementations.Library.LibraryManager.<PerformLibraryValidation>d__5b.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Server.Implementations.Library.LibraryManager.<ValidateMediaLibraryInternal>d__54.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Common.Implementations.ScheduledTasks.ScheduledTaskWorker.<ExecuteInternal>d__c.MoveNext() 2015-05-07 07:59:12.3064 Info - App: Scan media library Failed after 1 minute(s) and 5 seconds 2015-05-07 07:59:12.3064 Info - LibraryMonitor: Watching directory C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\root 2015-05-07 07:59:12.3064 Info - LibraryMonitor: Watching directory C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\collections 2015-05-07 07:59:12.3064 Info - LibraryMonitor: Watching directory C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\camerauploads 2015-05-07 07:59:12.3064 Info - LibraryMonitor: Watching directory C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\playlists 2015-05-07 07:59:12.3064 Debug - NotificationManager: Sending notification via Dashboard Notifications to user Richard 2015-05-07 07:59:12.3064 Info - ServerManager: Sending web socket message NotificationAdded 2015-05-07 07:59:12.3064 Info - ServerManager: Sending web socket message ScheduledTaskEnded 2015-05-07 07:59:12.5044 Info - LibraryMonitor: Watching directory \\media\series shows I'm restarting the server to get a fresh log and starting a fresh scan.. Will attach in its entirity next... 2015-05-07 19:56:42.8048 Info - Main: Emby Command line: C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Richard\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe 2015-05-07 19:56:43.3708 Info - App: Application version: 3.0.5597.1 2015-05-07 19:56:43.4198 Info - App: Application configuration: {"EnableUPnP":true,"PublicPort":8096,"PublicHttpsPort":8920,"HttpServerPortNumber":8096,"HttpsPortNumber":8920,"EnableHttps":false,"EnableUserSpecificUserViews":true,"EnableInternetProviders":false,"IsPortAuthorized":true,"SeasonZeroDisplayName":"Specials","SaveLocalMeta":false,"EnableLocalizedGuids":true,"EnableLibraryMetadataSubFolder":true,"PreferredMetadataLanguage":"en","MetadataCountryCode":"US","SortReplaceCharacters":[".","+","%"],"SortRemoveCharacters":[",","&","-","{","}","'"],"SortRemoveWords":["the","a","an"],"MinResumePct":5,"MaxResumePct":90,"MinResumeDurationSeconds":300,"RealtimeMonitorDelay":30,"EnableDashboardResponseCaching":true,"EnableDashboardResourceMinification":true,"DashboardSourcePath":"","MergeMetadataAndImagesByName":true,"EnableStandaloneMetadata":true,"ImageSavingConvention":"Compatible","MetadataOptions":[{"ItemType":"Book","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Movie","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280},{"Type":"Screenshot","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":["Nfo","Emby Xml"],"DisabledMetadataFetchers":["The Open Movie Database","TheMovieDb"],"MetadataFetcherOrder":["The Open Movie Database","TheMovieDb"],"DisabledImageFetchers":["TheMovieDb","FanArt","The Open Movie Database","Screen Grabber"],"ImageFetcherOrder":["TheMovieDb","FanArt","The Open Movie Database","Screen Grabber"]},{"ItemType":"Series","ImageOptions":[{"Type":"Backdrop","Limit":2,"MinWidth":1280},{"Type":"Screenshot","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml","Nfo"],"LocalMetadataReaderOrder":["Nfo","Emby Xml"],"DisabledMetadataFetchers":["The Open Movie Database","TheTVDB","TheMovieDb"],"MetadataFetcherOrder":["The Open Movie Database","TheTVDB","TheMovieDb"],"DisabledImageFetchers":["TheTVDB","FanArt","TheMovieDb"],"ImageFetcherOrder":["TheTVDB","FanArt","TheMovieDb"]},{"ItemType":"MusicAlbum","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Disc","Limit":0,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicArtist","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Banner","Limit":0,"MinWidth":0},{"Type":"Art","Limit":0,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Season","ImageOptions":[{"Type":"Backdrop","Limit":0,"MinWidth":1280}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Episode","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicVideo","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Video","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]}],"EnableAutomaticRestart":true,"EnableRealtimeMonitor":true,"PathSubstitutions":[],"UICulture":"en-us","PeopleMetadataOptions":{"DownloadActorMetadata":true,"DownloadDirectorMetadata":true,"DownloadProducerMetadata":false,"DownloadWriterMetadata":false,"DownloadComposerMetadata":false,"DownloadOtherPeopleMetadata":false,"DownloadGuestStarMetadata":false},"FindInternetTrailers":true,"InsecureApps9":["Chromecast","iOS","Unknown app","MediaPortal","Media Portal","iPad","iPhone","Windows Phone"],"SaveMetadataHidden":false,"ContentTypes":[],"EnableAudioArchiveFiles":false,"EnableVideoArchiveFiles":false,"RemoteClientBitrateLimit":0,"EnableDebugLevelLogging":false,"EnableAutoUpdate":true,"SystemUpdateLevel":"Release","LogFileRetentionDays":3,"RunAtStartup":true,"IsStartupWizardCompleted":true,"EnableCustomPathSubFolders":true} 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.Plugins.Trailers, Version=1.0.5573.39176, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.Api, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.WebDashboard, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.Model, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.Common, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.Controller, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.Providers, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.Common.Implementations, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.Server.Implementations, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.MediaEncoding, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.Dlna, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.LocalMetadata, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.XbmcMetadata, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.IsoMounter, Version=1.0.5344.20624, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.ServerApplication, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.Server.Startup.Common, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.8638 Info - SqliteUserRepository: Sqlite 3.8.6 opening C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\users.db 2015-05-07 19:56:43.9458 Info - SqliteItemRepository: Sqlite 3.8.6 opening C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\chapters.db 2015-05-07 19:56:43.9528 Info - SqliteItemRepository: Sqlite 3.8.6 opening C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\mediainfo.db 2015-05-07 19:56:43.9528 Info - SqliteFileOrganizationRepository: Sqlite 3.8.6 opening C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\fileorganization.db 2015-05-07 19:56:43.9658 Info - AuthenticationRepository: Sqlite 3.8.6 opening C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\authentication.db 2015-05-07 19:56:43.9888 Info - SyncRepository: Sqlite 3.8.6 opening C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\sync14.db 2015-05-07 19:56:44.2658 Info - ImageMagick: ImageMagick version: ImageMagick 6.9.0-9 Q8 x86 2015-02-28 http://www.imagemagick.org 2015-05-07 19:56:44.3189 Info - ImageProcessor: ImageProcessor started with 8 max concurrent image processes 2015-05-07 19:56:44.3699 Info - App: FFMpeg: C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\ffmpeg\20150331\ffmpeg.exe 2015-05-07 19:56:44.3699 Info - App: FFProbe: C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\ffmpeg\20150331\ffprobe.exe 2015-05-07 19:56:44.3699 Info - ActivityRepository: Sqlite 3.8.6 opening C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\activitylog.db 2015-05-07 19:56:44.3869 Info - SqliteDisplayPreferencesRepository: Sqlite 3.8.6 opening C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\displaypreferences.db 2015-05-07 19:56:44.3869 Info - SqliteItemRepository: Sqlite 3.8.6 opening C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\library.db 2015-05-07 19:56:44.4019 Info - SqliteProviderInfoRepository: Sqlite 3.8.6 opening C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\refreshinfo.db 2015-05-07 19:56:44.4019 Info - SqliteUserDataRepository: Sqlite 3.8.6 opening C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\userdata_v2.db 2015-05-07 19:56:44.4179 Info - SqliteNotificationsRepository: Sqlite 3.8.6 opening C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\notifications.db 2015-05-07 19:56:44.6179 Info - HttpServer: Calling ServiceStack AppHost.Init 2015-05-07 19:56:46.2710 Info - ServiceStackHost: Initializing Application took 2140.1224ms 2015-05-07 19:56:46.2840 Info - ServerManager: Loading Http Server 2015-05-07 19:56:46.2890 Info - HttpServer: Adding HttpListener prefix http://+:8096/ 2015-05-07 19:56:46.2890 Info - HttpServer: Adding HttpListener prefix https://+:8920/ 2015-05-07 19:56:46.2890 Info - HttpServer: attempting to load pfx: C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\ssl\cert_9c31b7884ea5475c8687970fc5996297.pfx 2015-05-07 19:56:46.4920 Debug - HttpServer: HTTP UNSUBSCRIBE http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/contentdirectory/events Ip: 10.0.0.189:1784. Headers: Host=10.0.0.100:8096,SID=uuid:7d9e3611a3734762ada80500f37ca2d7,CONNECTION=close 2015-05-07 19:56:46.5240 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/web/scheduledtasks.html Ip: 127.0.0.1:60587. Headers: Host=localhost:8096,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64; rv:37.0) Gecko/20100101 Firefox/37.0,Accept=text/html, */*; q=0.01,Accept-Language=en-US,en;q=0.5,Accept-Encoding=gzip, deflate,Connection=keep-alive,If-None-Match=ca9d22f44593e1618ff07b15724e0c32 2015-05-07 19:56:46.7240 Info - App: Core startup complete 2015-05-07 19:56:46.7620 Info - Dlna: SSDP service started 2015-05-07 19:56:46.7620 Debug - Dlna: Starting alive notifier 2015-05-07 19:56:46.7740 Debug - UpnpContentDirectory: Cancelling event subscription uuid:7d9e3611a3734762ada80500f37ca2d7 2015-05-07 19:56:46.7930 Debug - PortMapper: Starting NAT discovery 2015-05-07 19:56:46.8070 Debug - HttpServer: HTTP Response 200 to 10.0.0.189. Response time: 58.0033 ms. Url: http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/contentdirectory/events 2015-05-07 19:56:46.8070 Debug - HttpServer: HTTP Response 304 to 127.0.0.1. Response time: 281.0161 ms. Url: http://localhost:8096/mediabrowser/web/scheduledtasks.html 2015-05-07 19:56:46.8720 Debug - Dlna: Found interface: Local Area Connection. Type: Ethernet. Status: Up 2015-05-07 19:56:46.8720 Debug - Dlna: Found interface: Bluetooth Network Connection. Type: Ethernet. Status: Down 2015-05-07 19:56:46.8720 Debug - Dlna: Found interface: VirtualBox Host-Only Network. Type: Ethernet. Status: Up 2015-05-07 19:56:46.8720 Info - Dlna: Creating SSDP listener on 10.0.0.100 2015-05-07 19:56:46.8720 Info - Dlna: Creating SSDP listener on 192.168.1.100 2015-05-07 19:56:46.8720 Debug - Dlna: Found interface: Loopback Pseudo-Interface 1. Type: Loopback. Status: Up 2015-05-07 19:56:46.8720 Info - Dlna: Creating SSDP listener on 192.168.56.1 2015-05-07 19:56:46.8850 Info - Dlna: Creating SSDP listener on 127.0.0.1 2015-05-07 19:56:46.8850 Debug - Dlna: Found interface: isatap.{D9CC475F-A36D-4221-AE4F-A86C707AB076}. Type: Tunnel. Status: Down 2015-05-07 19:56:46.8850 Debug - Dlna: Found interface: Teredo Tunneling Pseudo-Interface. Type: Tunnel. Status: Down 2015-05-07 19:56:46.8850 Debug - Dlna: Found interface: isatap.{C68FC393-020D-4660-A66E-B50A00CA5DD8}. Type: Tunnel. Status: Down 2015-05-07 19:56:46.8850 Debug - Dlna: Found interface: isatap.{7C276FC1-C157-4C9B-915E-E6DAFCD73382}. Type: Tunnel. Status: Down 2015-05-07 19:56:46.9990 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/ScheduledTasks?isHidden=false Ip: 127.0.0.1:60585. Headers: Host=localhost:8096,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64; rv:37.0) Gecko/20100101 Firefox/37.0,Accept=application/json, text/javascript, */*; q=0.01,Accept-Language=en-US,en;q=0.5,Accept-Encoding=gzip, deflate,Authorization=MediaBrowser Client="Dashboard", Device="Firefox 37.0", DeviceId="33dcb75eac2c3c0f38ebfe2c83ef8708b0f4d747", Version="3.0.5597.1", UserId="43e845c29a04485f862f3a411bc2c1fb",X-MediaBrowser-Token=34f7bdec95ed44a7afe9d3c4d90cfcf2,Connection=keep-alive 2015-05-07 19:56:47.0140 Debug - Dlna: Registered mount 0173f77a-b746-f8be-c1dc-86369bdcf761 at http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/description.xml 2015-05-07 19:56:47.0140 Debug - Dlna: Registered mount 418700fa-de27-7f4b-ef72-56f2eb535948 at http://192.168.1.100:8096/dlna/418700fade277f4bef7256f2eb535948/description.xml 2015-05-07 19:56:47.1630 Debug - HttpServer: HTTP GET http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/description.xml Ip: 10.0.0.180:58016. Headers: Cache-Control=no-cache,Connection=Close,Pragma=no-cache,Accept=text/xml, application/xml,Host=10.0.0.100:8096,User-Agent=Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50 2015-05-07 19:56:47.2070 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 206.0118 ms. Url: http://localhost:8096/mediabrowser/ScheduledTasks?isHidden=false 2015-05-07 19:56:47.2480 Debug - Dlna: No matching device profile found. The default will be used. User-agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50. 2015-05-07 19:56:47.2480 Debug - HttpServer: HTTP Response 200 to 10.0.0.180. Response time: 92.0053 ms. Url: http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/description.xml 2015-05-07 19:56:47.2720 Info - App: HttpClientManager GET: http://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog 2015-05-07 19:56:47.2720 Info - App: HttpClientManager GET: http://www.mb3admin.com/admin/service/MB3ServerNotifications.json 2015-05-07 19:56:48.6371 Debug - HttpServer: HTTP GET http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/description.xml Ip: 10.0.0.189:1785. Headers: Host=10.0.0.100:8096,Connection=close,User-Agent=Mozilla/4.0 (compatible),Accept=*/* 2015-05-07 19:56:48.6711 Debug - Dlna: No matching device profile found. The default will be used. User-agent: Mozilla/4.0 (compatible). 2015-05-07 19:56:48.6711 Debug - HttpServer: HTTP Response 200 to 10.0.0.189. Response time: 34.002 ms. Url: http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/description.xml 2015-05-07 19:56:49.0061 Debug - HttpServer: HTTP SUBSCRIBE http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/contentdirectory/events Ip: 10.0.0.189:1786. Headers: Host=10.0.0.100:8096,TIMEOUT=Second-300,NT=upnp:event,CALLBACK=<http://10.0.0.189:1900/>,CONNECTION=close 2015-05-07 19:56:49.0061 Debug - UpnpContentDirectory: Creating event subscription for upnp:event with timeout of 300 to <http://10.0.0.189:1900/> 2015-05-07 19:56:49.0061 Debug - HttpServer: HTTP Response 200 to 10.0.0.189. Response time: 1.0001 ms. Url: http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/contentdirectory/events 2015-05-07 19:56:49.3181 Debug - HttpServer: HTTP GET http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/description.xml Ip: 10.0.0.161:56346. Headers: Cache-Control=no-cache,Connection=Close,Pragma=no-cache,Accept=text/xml, application/xml,Host=10.0.0.100:8096,User-Agent=Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50 2015-05-07 19:56:49.3311 Debug - Dlna: No matching device profile found. The default will be used. User-agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50. 2015-05-07 19:56:49.3311 Debug - HttpServer: HTTP Response 200 to 10.0.0.161. Response time: 20.0011 ms. Url: http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/description.xml 2015-05-07 19:56:49.4901 Info - App: HttpClientManager POST: http://www.mb3admin.com/admin/service/registration/validate 2015-05-07 19:56:49.7242 Info - App: StartupTrigger fired for task: Check for application updates 2015-05-07 19:56:49.7242 Info - App: StartupTrigger fired for task: Check for plugin updates 2015-05-07 19:56:49.7242 Info - App: StartupTrigger fired for task: Scan media library 2015-05-07 19:56:49.7242 Info - App: StartupTrigger fired for task: Refresh Guide 2015-05-07 19:56:49.7242 Info - App: Queueing task RefreshMediaLibraryTask 2015-05-07 19:56:49.7242 Info - App: Queueing task SystemUpdateTask 2015-05-07 19:56:49.7242 Info - App: Queueing task PluginUpdateTask 2015-05-07 19:56:49.7242 Info - App: Queueing task RefreshChannelsScheduledTask 2015-05-07 19:56:49.7242 Info - App: Executing Scan media library 2015-05-07 19:56:49.7242 Info - App: Validating media library 2015-05-07 19:56:49.7972 Info - App: HttpClientManager POST: https://connect.mediabrowser.tv/service/Servers?id=487ded72354875cd991938966a4f921a 2015-05-07 19:56:49.9652 Info - App: HttpClientManager GET: https://connect.mediabrowser.tv/service/ServerAuthorizations?serverId=487ded72354875cd991938966a4f921a 2015-05-07 19:56:51.8153 Info - App: HttpClientManager POST: http://www.mb3admin.com/admin/service/registration/ping 2015-05-07 19:56:52.0293 Debug - HttpServer: HTTP POST http://localhost:8096/mediabrowser/ScheduledTasks/Running/2d67d886717cdade18d9640d4ebbb9cb Ip: 127.0.0.1:60585. Headers: Host=localhost:8096,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64; rv:37.0) Gecko/20100101 Firefox/37.0,Accept=*/*,Accept-Language=en-US,en;q=0.5,Accept-Encoding=gzip, deflate,Authorization=MediaBrowser Client="Dashboard", Device="Firefox 37.0", DeviceId="33dcb75eac2c3c0f38ebfe2c83ef8708b0f4d747", Version="3.0.5597.1", UserId="43e845c29a04485f862f3a411bc2c1fb",X-MediaBrowser-Token=34f7bdec95ed44a7afe9d3c4d90cfcf2,Connection=keep-alive,Pragma=no-cache,Cache-Control=no-cache,Content-Length=0 2015-05-07 19:56:52.0303 Debug - HttpServer: HTTP Response 204 to 127.0.0.1. Response time: 10.0006 ms. Url: http://localhost:8096/mediabrowser/ScheduledTasks/Running/2d67d886717cdade18d9640d4ebbb9cb 2015-05-07 19:56:52.0473 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/ScheduledTasks?isHidden=false Ip: 127.0.0.1:60585. Headers: Host=localhost:8096,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64; rv:37.0) Gecko/20100101 Firefox/37.0,Accept=application/json, text/javascript, */*; q=0.01,Accept-Language=en-US,en;q=0.5,Accept-Encoding=gzip, deflate,Authorization=MediaBrowser Client="Dashboard", Device="Firefox 37.0", DeviceId="33dcb75eac2c3c0f38ebfe2c83ef8708b0f4d747", Version="3.0.5597.1", UserId="43e845c29a04485f862f3a411bc2c1fb",X-MediaBrowser-Token=34f7bdec95ed44a7afe9d3c4d90cfcf2,Connection=keep-alive 2015-05-07 19:56:52.0473 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 6.0003 ms. Url: http://localhost:8096/mediabrowser/ScheduledTasks?isHidden=false 2015-05-07 19:56:52.5903 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: c6b208ad11e44373ae78cacb35686d26 2015-05-07 19:56:52.5903 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 0e24066bca5745f5841801292e84af2e 2015-05-07 19:56:53.9924 Debug - HttpServer: HTTP POST http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/contentdirectory/control Ip: 10.0.0.189:1788. Headers: Host=10.0.0.100:8096,SOAPACTION="urn:schemas-upnp-org:service:ContentDirectory:1#GetSearchCapabilities",USER-AGENT=KnOS/3.2 bridgeCo-DMP/3.0 DLNADOC/1.50 INTEL_NMPR/2.0,CONNECTION=close,CONTENT-TYPE=text/xml; charset="utf-8",Content-Length=291 2015-05-07 19:56:54.2174 Debug - Dlna: No matching device profile found. The default will be used. 2015-05-07 19:56:54.2174 Debug - UpnpContentDirectory: Received control request GetSearchCapabilities 2015-05-07 19:56:54.2174 Debug - HttpServer: HTTP Response 200 to 10.0.0.189. Response time: 235.0135 ms. Url: http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/contentdirectory/control 2015-05-07 19:56:54.2464 Debug - HttpServer: HTTP POST http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/contentdirectory/control Ip: 10.0.0.189:1789. Headers: Host=10.0.0.100:8096,SOAPACTION="urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities",USER-AGENT=KnOS/3.2 bridgeCo-DMP/3.0 DLNADOC/1.50 INTEL_NMPR/2.0,CONNECTION=close,CONTENT-TYPE=text/xml; charset="utf-8",Content-Length=289 2015-05-07 19:56:54.4674 Debug - Dlna: No matching device profile found. The default will be used. 2015-05-07 19:56:54.4674 Debug - UpnpContentDirectory: Received control request GetSortCapabilities 2015-05-07 19:56:54.4674 Debug - HttpServer: HTTP Response 200 to 10.0.0.189. Response time: 221.0127 ms. Url: http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/contentdirectory/control 2015-05-07 19:56:54.9645 Info - App: HttpClientManager GET: http://bot.whatismyipaddress.com/ 2015-05-07 19:56:55.5465 Info - App: HttpClientManager POST: https://connect.mediabrowser.tv/service/Servers?id=487ded72354875cd991938966a4f921a 2015-05-07 19:56:55.6465 Info - App: HttpClientManager GET: https://connect.mediabrowser.tv/service/ServerAuthorizations?serverId=487ded72354875cd991938966a4f921a 2015-05-07 19:56:56.7116 Info - App: StartupTrigger fired for task: Refresh Channels 2015-05-07 19:56:56.7116 Info - App: Queueing task RefreshChannelsScheduledTask 2015-05-07 19:57:16.7247 Info - App: StartupTrigger fired for task: Log file cleanup 2015-05-07 19:57:16.7247 Info - App: Queueing task DeleteLogFileTask 2015-05-07 19:57:17.6718 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/web/library.html Ip: 127.0.0.1:60585. Headers: Host=localhost:8096,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64; rv:37.0) Gecko/20100101 Firefox/37.0,Accept=text/html, */*; q=0.01,Accept-Language=en-US,en;q=0.5,Accept-Encoding=gzip, deflate,Connection=keep-alive,If-None-Match=96ad335c967f3b44a7dd9b67fb35e000 2015-05-07 19:57:17.6718 Debug - HttpServer: HTTP Response 304 to 127.0.0.1. Response time: 1.0001 ms. Url: http://localhost:8096/mediabrowser/web/library.html 2015-05-07 19:57:17.8748 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Library/VirtualFolders Ip: 127.0.0.1:60585. Headers: Host=localhost:8096,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64; rv:37.0) Gecko/20100101 Firefox/37.0,Accept=application/json, text/javascript, */*; q=0.01,Accept-Language=en-US,en;q=0.5,Accept-Encoding=gzip, deflate,Authorization=MediaBrowser Client="Dashboard", Device="Firefox 37.0", DeviceId="33dcb75eac2c3c0f38ebfe2c83ef8708b0f4d747", Version="3.0.5597.1", UserId="43e845c29a04485f862f3a411bc2c1fb",X-MediaBrowser-Token=34f7bdec95ed44a7afe9d3c4d90cfcf2,Connection=keep-alive 2015-05-07 19:57:17.8748 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/ScheduledTasks?IsEnabled=true Ip: 127.0.0.1:60587. Headers: Host=localhost:8096,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64; rv:37.0) Gecko/20100101 Firefox/37.0,Accept=application/json, text/javascript, */*; q=0.01,Accept-Language=en-US,en;q=0.5,Accept-Encoding=gzip, deflate,Authorization=MediaBrowser Client="Dashboard", Device="Firefox 37.0", DeviceId="33dcb75eac2c3c0f38ebfe2c83ef8708b0f4d747", Version="3.0.5597.1", UserId="43e845c29a04485f862f3a411bc2c1fb",X-MediaBrowser-Token=34f7bdec95ed44a7afe9d3c4d90cfcf2,Connection=keep-alive 2015-05-07 19:57:17.8848 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 9.0005 ms. Url: http://localhost:8096/mediabrowser/Library/VirtualFolders 2015-05-07 19:57:17.8948 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 19.0011 ms. Url: http://localhost:8096/mediabrowser/ScheduledTasks?IsEnabled=true 2015-05-07 19:57:18.8028 Info - App: HttpClientManager GET: http://www.thetvdb.com/api/GetSeries.php?seriesname=Yo+Gabba+Gabba&language=en 2015-05-07 19:57:18.9028 Info - App: Executing Check for application updates 2015-05-07 19:57:18.9028 Info - App: HttpClientManager GET: http://www.mb3admin.com/admin/service/MB3Packages.json 2015-05-07 19:57:18.9098 Info - App: Executing Refresh Guide 2015-05-07 19:57:19.3329 Info - App: TVDb Provider - yo gabba gabba did not match yo gabba gabba 2015-05-07 19:57:19.3329 Info - App: TVDb Provider - Could not find Yo Gabba Gabba. Check name on Thetvdb.org. 2015-05-07 19:57:19.3329 Debug - App: Running SeriesNfoProvider for \\media\Series Shows\Yo Gabba Gabba 2015-05-07 19:57:19.3329 Debug - App: SeriesNfoProvider returned no metadata for \\media\Series Shows\Yo Gabba Gabba 2015-05-07 19:57:19.3329 Debug - App: Running SeriesXmlProvider for \\media\Series Shows\Yo Gabba Gabba 2015-05-07 19:57:19.3859 Info - LibraryMonitor: Watching directory C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\camerauploads 2015-05-07 19:57:19.3859 Info - LibraryMonitor: Watching directory C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\root 2015-05-07 19:57:19.3859 Info - LibraryMonitor: Watching directory C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\playlists 2015-05-07 19:57:19.3859 Info - LibraryMonitor: Watching directory C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\collections 2015-05-07 19:57:19.3949 Error - App: Error *** Error Report *** Version: 3.0.5597.1 Command line: C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Richard\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Object reference not set to an instance of an object. System.NullReferenceException at MediaBrowser.Providers.TV.SeriesMetadataService.MergeData(Series source, Series target, List`1 lockedFields, Boolean replaceData, Boolean mergeMetadataSettings) at MediaBrowser.Providers.Manager.MetadataService`2.<RefreshWithProviders>d__2d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Providers.Manager.MetadataService`2.<RefreshMetadata>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.BaseItem.<RefreshMetadata>d__1e.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.TV.Series.<RefreshAllMetadata>d__10.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.Folder.<RefreshChildMetadata>d__d6.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.Folder.<RefreshMetadataRecursive>d__cd.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.Folder.<RefreshChildMetadata>d__d6.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.Folder.<RefreshMetadataRecursive>d__cd.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Controller.Entities.Folder.<ValidateChildrenInternal>d__ba.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Server.Implementations.Library.LibraryManager.<PerformLibraryValidation>d__5b.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Server.Implementations.Library.LibraryManager.<ValidateMediaLibraryInternal>d__54.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Common.Implementations.ScheduledTasks.ScheduledTaskWorker.<ExecuteInternal>d__c.MoveNext() 2015-05-07 19:57:19.3949 Info - App: Scan media library Failed after 0 minute(s) and 29 seconds 2015-05-07 19:57:19.3949 Info - LibraryMonitor: Watching directory \\media\series shows 2015-05-07 19:57:19.3949 Info - LibraryMonitor: Watching directory \\media\Movies 2015-05-07 19:57:19.4079 Debug - NotificationManager: Sending notification via Dashboard Notifications to user Richard 2015-05-07 19:57:19.4569 Debug - App: No application update available. 2015-05-07 19:57:19.4569 Info - App: Check for application updates Completed after 0 minute(s) and 0 seconds 2015-05-07 19:57:23.9031 Info - App: Refresh Guide Completed after 0 minute(s) and 4 seconds 2015-05-07 19:57:24.2151 Info - App: Executing Check for plugin updates 2015-05-07 19:57:24.2151 Info - App: Check for plugin updates Completed after 0 minute(s) and 0 seconds 2015-05-07 19:57:24.5112 Info - App: Executing Refresh Channels 2015-05-07 19:57:24.5112 Info - App: Refresh Channels Completed after 0 minute(s) and 0 seconds 2015-05-07 19:57:24.6592 Info - App: Executing Log file cleanup 2015-05-07 19:57:24.6972 Info - App: Log file cleanup Completed after 0 minute(s) and 0 seconds 2015-05-07 19:57:41.0061 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/web/scheduledtasks.html Ip: 127.0.0.1:60587. Headers: Host=localhost:8096,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64; rv:37.0) Gecko/20100101 Firefox/37.0,Accept=text/html, */*; q=0.01,Accept-Language=en-US,en;q=0.5,Accept-Encoding=gzip, deflate,Connection=keep-alive,If-None-Match=ca9d22f44593e1618ff07b15724e0c32 2015-05-07 19:57:41.0061 Debug - HttpServer: HTTP Response 304 to 127.0.0.1. Response time: 0 ms. Url: http://localhost:8096/mediabrowser/web/scheduledtasks.html 2015-05-07 19:57:41.1321 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/ScheduledTasks?isHidden=false Ip: 127.0.0.1:60587. Headers: Host=localhost:8096,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64; rv:37.0) Gecko/20100101 Firefox/37.0,Accept=application/json, text/javascript, */*; q=0.01,Accept-Language=en-US,en;q=0.5,Accept-Encoding=gzip, deflate,Authorization=MediaBrowser Client="Dashboard", Device="Firefox 37.0", DeviceId="33dcb75eac2c3c0f38ebfe2c83ef8708b0f4d747", Version="3.0.5597.1", UserId="43e845c29a04485f862f3a411bc2c1fb",X-MediaBrowser-Token=34f7bdec95ed44a7afe9d3c4d90cfcf2,Connection=keep-alive 2015-05-07 19:57:41.1321 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 5.0002 ms. Url: http://localhost:8096/mediabrowser/ScheduledTasks?isHidden=false 2015-05-07 19:57:44.0313 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/web/support.html Ip: 127.0.0.1:60587. Headers: Host=localhost:8096,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64; rv:37.0) Gecko/20100101 Firefox/37.0,Accept=text/html, */*; q=0.01,Accept-Language=en-US,en;q=0.5,Accept-Encoding=gzip, deflate,Connection=keep-alive,If-None-Match=3d5f0b654c1a7cd18f866cb14570d5f9 2015-05-07 19:57:44.0313 Debug - HttpServer: HTTP Response 304 to 127.0.0.1. Response time: 1 ms. Url: http://localhost:8096/mediabrowser/web/support.html 2015-05-07 19:57:45.5854 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/web/log.html Ip: 127.0.0.1:60587. Headers: Host=localhost:8096,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64; rv:37.0) Gecko/20100101 Firefox/37.0,Accept=text/html, */*; q=0.01,Accept-Language=en-US,en;q=0.5,Accept-Encoding=gzip, deflate,Connection=keep-alive,If-None-Match=de6088a37aefe0a3542f85995642cccd 2015-05-07 19:57:45.5854 Debug - HttpServer: HTTP Response 304 to 127.0.0.1. Response time: 1 ms. Url: http://localhost:8096/mediabrowser/web/log.html 2015-05-07 19:57:45.7054 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/System/Logs Ip: 127.0.0.1:60587. Headers: Host=localhost:8096,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64; rv:37.0) Gecko/20100101 Firefox/37.0,Accept=application/json, text/javascript, */*; q=0.01,Accept-Language=en-US,en;q=0.5,Accept-Encoding=gzip, deflate,Authorization=MediaBrowser Client="Dashboard", Device="Firefox 37.0", DeviceId="33dcb75eac2c3c0f38ebfe2c83ef8708b0f4d747", Version="3.0.5597.1", UserId="43e845c29a04485f862f3a411bc2c1fb",X-MediaBrowser-Token=34f7bdec95ed44a7afe9d3c4d90cfcf2,Connection=keep-alive 2015-05-07 19:57:45.7094 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 11.0007 ms. Url: http://localhost:8096/mediabrowser/System/Logs 2015-05-07 19:57:46.7234 Info - App: StartupTrigger fired for task: Cache file cleanup 2015-05-07 19:57:46.7234 Info - App: Queueing task DeleteCacheFileTask 2015-05-07 19:57:46.7234 Info - App: Executing Cache file cleanup
Luke 42204 Posted May 8, 2015 Posted May 8, 2015 Ok, so I bailed on the Ubuntu server, couldnt' get it to run... Kept crashing after start up.. Switched over to Windows 7 Pro. However, it can't successfully scan the media library, the same media library the Ubuntu version was successfully able to scan. (In fact, it's still on the ubuntu and being accesed over network) The scan will run for, then fail... If I restart it does the same thing... This little snipliet about Yo Gabba Gabba (Yes, I have a kid that likes it... It's not me) 2015-05-07 07:58:25.8838 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 2f266ab07b6c44928031a2fbe29618f1 2015-05-07 07:58:34.6043 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: f4728637a9a54c54965f1f03a9ecfb2a 2015-05-07 07:58:56.3225 Debug - App: Running FFProbeProvider for \\media\Movies\Brave (2012) [HD] [5.1]\Brave (2012) [HD] [5.1].mkv 2015-05-07 07:58:56.3225 Debug - App: Running MovieNfoProvider for \\media\Movies\Brave (2012) [HD] [5.1]\Brave (2012) [HD] [5.1].mkv 2015-05-07 07:58:56.3555 Debug - App: Saving \\media\Movies\Brave (2012) [HD] [5.1]\Brave (2012) [HD] [5.1].mkv to database. 2015-05-07 07:59:11.8174 Info - App: HttpClientManager GET: http://www.thetvdb.com/api/GetSeries.php?seriesname=Yo+Gabba+Gabba&language=en 2015-05-07 07:59:11.8454 Debug - HttpServer: HTTP Response 204 to 10.0.0.160. Response time: 65148.7263 ms. Url: http://10.0.0.100:8096/ScheduledTasks/Running/2d67d886717cdade18d9640d4ebbb9cb 2015-05-07 07:59:11.8784 Debug - HttpServer: HTTP GET http://10.0.0.100:8096/ScheduledTasks?IsEnabled=true Ip: 10.0.0.160:50652. Headers: Host=10.0.0.100:8096,Accept-Language=en-us,Accept-Encoding=gzip, deflate,Connection=keep-alive,Accept=application/json, text/javascript, */*; q=0.01,User-Agent=Mozilla/5.0 (iPhone; CPU iPhone OS 8_1 like Mac OS X) AppleWebKit/600.1.4 (KHTML, like Gecko) Version/8.0 Mobile/12B411 Safari/600.1.4,Authorization=MediaBrowser Client="Dashboard", Device="Safari 600.1.4 Iphone", DeviceId="cecbe14e56bd047f4a6c80ffd9ce056d62e65c30", Version="3.0.5597.1", UserId="43e845c29a04485f862f3a411bc2c1fb",X-MediaBrowser-Token=fcdb51b616bc485e86c9978ef640c7ba 2015-05-07 07:59:11.8784 Debug - HttpServer: HTTP Response 200 to 10.0.0.160. Response time: 2.0001 ms. Url: http://10.0.0.100:8096/ScheduledTasks?IsEnabled=true 2015-05-07 07:59:12.2874 Info - App: TVDb Provider - yo gabba gabba did not match yo gabba gabba 2015-05-07 07:59:12.2874 Info - App: TVDb Provider - Could not find Yo Gabba Gabba. Check name on Thetvdb.org. 2015-05-07 07:59:12.2874 Debug - App: Running SeriesNfoProvider for \\media\Series Shows\Yo Gabba Gabba 2015-05-07 07:59:12.2874 Debug - App: SeriesNfoProvider returned no metadata for \\media\Series Shows\Yo Gabba Gabba 2015-05-07 07:59:12.2874 Debug - App: Running SeriesXmlProvider for \\media\Series Shows\Yo Gabba Gabba 2015-05-07 07:59:12.3064 Error - App: Error *** Error Report *** Version: 3.0.5597.1 Command line: C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Richard\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Object reference not set to an instance of an object. System.NullReferenceException at MediaBrowser.Providers.TV.SeriesMetadataService.MergeData(Series source, Series target, List`1 lockedFields, Boolean replaceData, Boolean mergeMetadataSettings) at MediaBrowser.Providers.Manager.MetadataService`2.<RefreshWithProviders>d__2d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Providers.Manager.MetadataService`2.<RefreshMetadata>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.BaseItem.<RefreshMetadata>d__1e.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.TV.Series.<RefreshAllMetadata>d__10.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.Folder.<RefreshChildMetadata>d__d6.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.Folder.<RefreshMetadataRecursive>d__cd.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.Folder.<RefreshChildMetadata>d__d6.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.Folder.<RefreshMetadataRecursive>d__cd.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Controller.Entities.Folder.<ValidateChildrenInternal>d__ba.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Server.Implementations.Library.LibraryManager.<PerformLibraryValidation>d__5b.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Server.Implementations.Library.LibraryManager.<ValidateMediaLibraryInternal>d__54.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Common.Implementations.ScheduledTasks.ScheduledTaskWorker.<ExecuteInternal>d__c.MoveNext() 2015-05-07 07:59:12.3064 Info - App: Scan media library Failed after 1 minute(s) and 5 seconds 2015-05-07 07:59:12.3064 Info - LibraryMonitor: Watching directory C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\root 2015-05-07 07:59:12.3064 Info - LibraryMonitor: Watching directory C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\collections 2015-05-07 07:59:12.3064 Info - LibraryMonitor: Watching directory C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\camerauploads 2015-05-07 07:59:12.3064 Info - LibraryMonitor: Watching directory C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\playlists 2015-05-07 07:59:12.3064 Debug - NotificationManager: Sending notification via Dashboard Notifications to user Richard 2015-05-07 07:59:12.3064 Info - ServerManager: Sending web socket message NotificationAdded 2015-05-07 07:59:12.3064 Info - ServerManager: Sending web socket message ScheduledTaskEnded 2015-05-07 07:59:12.5044 Info - LibraryMonitor: Watching directory \\media\series shows I'm restarting the server to get a fresh log and starting a fresh scan.. Will attach in its entirity next... 2015-05-07 19:56:42.8048 Info - Main: Emby Command line: C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Richard\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe 2015-05-07 19:56:43.3708 Info - App: Application version: 3.0.5597.1 2015-05-07 19:56:43.4198 Info - App: Application configuration: {"EnableUPnP":true,"PublicPort":8096,"PublicHttpsPort":8920,"HttpServerPortNumber":8096,"HttpsPortNumber":8920,"EnableHttps":false,"EnableUserSpecificUserViews":true,"EnableInternetProviders":false,"IsPortAuthorized":true,"SeasonZeroDisplayName":"Specials","SaveLocalMeta":false,"EnableLocalizedGuids":true,"EnableLibraryMetadataSubFolder":true,"PreferredMetadataLanguage":"en","MetadataCountryCode":"US","SortReplaceCharacters":[".","+","%"],"SortRemoveCharacters":[",","&","-","{","}","'"],"SortRemoveWords":["the","a","an"],"MinResumePct":5,"MaxResumePct":90,"MinResumeDurationSeconds":300,"RealtimeMonitorDelay":30,"EnableDashboardResponseCaching":true,"EnableDashboardResourceMinification":true,"DashboardSourcePath":"","MergeMetadataAndImagesByName":true,"EnableStandaloneMetadata":true,"ImageSavingConvention":"Compatible","MetadataOptions":[{"ItemType":"Book","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Movie","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280},{"Type":"Screenshot","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":["Nfo","Emby Xml"],"DisabledMetadataFetchers":["The Open Movie Database","TheMovieDb"],"MetadataFetcherOrder":["The Open Movie Database","TheMovieDb"],"DisabledImageFetchers":["TheMovieDb","FanArt","The Open Movie Database","Screen Grabber"],"ImageFetcherOrder":["TheMovieDb","FanArt","The Open Movie Database","Screen Grabber"]},{"ItemType":"Series","ImageOptions":[{"Type":"Backdrop","Limit":2,"MinWidth":1280},{"Type":"Screenshot","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml","Nfo"],"LocalMetadataReaderOrder":["Nfo","Emby Xml"],"DisabledMetadataFetchers":["The Open Movie Database","TheTVDB","TheMovieDb"],"MetadataFetcherOrder":["The Open Movie Database","TheTVDB","TheMovieDb"],"DisabledImageFetchers":["TheTVDB","FanArt","TheMovieDb"],"ImageFetcherOrder":["TheTVDB","FanArt","TheMovieDb"]},{"ItemType":"MusicAlbum","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Disc","Limit":0,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicArtist","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Banner","Limit":0,"MinWidth":0},{"Type":"Art","Limit":0,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Season","ImageOptions":[{"Type":"Backdrop","Limit":0,"MinWidth":1280}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Episode","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicVideo","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Video","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]}],"EnableAutomaticRestart":true,"EnableRealtimeMonitor":true,"PathSubstitutions":[],"UICulture":"en-us","PeopleMetadataOptions":{"DownloadActorMetadata":true,"DownloadDirectorMetadata":true,"DownloadProducerMetadata":false,"DownloadWriterMetadata":false,"DownloadComposerMetadata":false,"DownloadOtherPeopleMetadata":false,"DownloadGuestStarMetadata":false},"FindInternetTrailers":true,"InsecureApps9":["Chromecast","iOS","Unknown app","MediaPortal","Media Portal","iPad","iPhone","Windows Phone"],"SaveMetadataHidden":false,"ContentTypes":[],"EnableAudioArchiveFiles":false,"EnableVideoArchiveFiles":false,"RemoteClientBitrateLimit":0,"EnableDebugLevelLogging":false,"EnableAutoUpdate":true,"SystemUpdateLevel":"Release","LogFileRetentionDays":3,"RunAtStartup":true,"IsStartupWizardCompleted":true,"EnableCustomPathSubFolders":true} 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.Plugins.Trailers, Version=1.0.5573.39176, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.Api, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.WebDashboard, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.Model, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.Common, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.Controller, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.Providers, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.Common.Implementations, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.Server.Implementations, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.MediaEncoding, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.Dlna, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.LocalMetadata, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.XbmcMetadata, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.IsoMounter, Version=1.0.5344.20624, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.ServerApplication, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.4778 Info - App: Loading MediaBrowser.Server.Startup.Common, Version=3.0.5597.1, Culture=neutral, PublicKeyToken=null 2015-05-07 19:56:43.8638 Info - SqliteUserRepository: Sqlite 3.8.6 opening C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\users.db 2015-05-07 19:56:43.9458 Info - SqliteItemRepository: Sqlite 3.8.6 opening C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\chapters.db 2015-05-07 19:56:43.9528 Info - SqliteItemRepository: Sqlite 3.8.6 opening C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\mediainfo.db 2015-05-07 19:56:43.9528 Info - SqliteFileOrganizationRepository: Sqlite 3.8.6 opening C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\fileorganization.db 2015-05-07 19:56:43.9658 Info - AuthenticationRepository: Sqlite 3.8.6 opening C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\authentication.db 2015-05-07 19:56:43.9888 Info - SyncRepository: Sqlite 3.8.6 opening C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\sync14.db 2015-05-07 19:56:44.2658 Info - ImageMagick: ImageMagick version: ImageMagick 6.9.0-9 Q8 x86 2015-02-28 http://www.imagemagick.org 2015-05-07 19:56:44.3189 Info - ImageProcessor: ImageProcessor started with 8 max concurrent image processes 2015-05-07 19:56:44.3699 Info - App: FFMpeg: C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\ffmpeg\20150331\ffmpeg.exe 2015-05-07 19:56:44.3699 Info - App: FFProbe: C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\ffmpeg\20150331\ffprobe.exe 2015-05-07 19:56:44.3699 Info - ActivityRepository: Sqlite 3.8.6 opening C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\activitylog.db 2015-05-07 19:56:44.3869 Info - SqliteDisplayPreferencesRepository: Sqlite 3.8.6 opening C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\displaypreferences.db 2015-05-07 19:56:44.3869 Info - SqliteItemRepository: Sqlite 3.8.6 opening C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\library.db 2015-05-07 19:56:44.4019 Info - SqliteProviderInfoRepository: Sqlite 3.8.6 opening C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\refreshinfo.db 2015-05-07 19:56:44.4019 Info - SqliteUserDataRepository: Sqlite 3.8.6 opening C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\userdata_v2.db 2015-05-07 19:56:44.4179 Info - SqliteNotificationsRepository: Sqlite 3.8.6 opening C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\notifications.db 2015-05-07 19:56:44.6179 Info - HttpServer: Calling ServiceStack AppHost.Init 2015-05-07 19:56:46.2710 Info - ServiceStackHost: Initializing Application took 2140.1224ms 2015-05-07 19:56:46.2840 Info - ServerManager: Loading Http Server 2015-05-07 19:56:46.2890 Info - HttpServer: Adding HttpListener prefix http://+:8096/ 2015-05-07 19:56:46.2890 Info - HttpServer: Adding HttpListener prefix https://+:8920/ 2015-05-07 19:56:46.2890 Info - HttpServer: attempting to load pfx: C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\ssl\cert_9c31b7884ea5475c8687970fc5996297.pfx 2015-05-07 19:56:46.4920 Debug - HttpServer: HTTP UNSUBSCRIBE http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/contentdirectory/events Ip: 10.0.0.189:1784. Headers: Host=10.0.0.100:8096,SID=uuid:7d9e3611a3734762ada80500f37ca2d7,CONNECTION=close 2015-05-07 19:56:46.5240 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/web/scheduledtasks.html Ip: 127.0.0.1:60587. Headers: Host=localhost:8096,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64; rv:37.0) Gecko/20100101 Firefox/37.0,Accept=text/html, */*; q=0.01,Accept-Language=en-US,en;q=0.5,Accept-Encoding=gzip, deflate,Connection=keep-alive,If-None-Match=ca9d22f44593e1618ff07b15724e0c32 2015-05-07 19:56:46.7240 Info - App: Core startup complete 2015-05-07 19:56:46.7620 Info - Dlna: SSDP service started 2015-05-07 19:56:46.7620 Debug - Dlna: Starting alive notifier 2015-05-07 19:56:46.7740 Debug - UpnpContentDirectory: Cancelling event subscription uuid:7d9e3611a3734762ada80500f37ca2d7 2015-05-07 19:56:46.7930 Debug - PortMapper: Starting NAT discovery 2015-05-07 19:56:46.8070 Debug - HttpServer: HTTP Response 200 to 10.0.0.189. Response time: 58.0033 ms. Url: http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/contentdirectory/events 2015-05-07 19:56:46.8070 Debug - HttpServer: HTTP Response 304 to 127.0.0.1. Response time: 281.0161 ms. Url: http://localhost:8096/mediabrowser/web/scheduledtasks.html 2015-05-07 19:56:46.8720 Debug - Dlna: Found interface: Local Area Connection. Type: Ethernet. Status: Up 2015-05-07 19:56:46.8720 Debug - Dlna: Found interface: Bluetooth Network Connection. Type: Ethernet. Status: Down 2015-05-07 19:56:46.8720 Debug - Dlna: Found interface: VirtualBox Host-Only Network. Type: Ethernet. Status: Up 2015-05-07 19:56:46.8720 Info - Dlna: Creating SSDP listener on 10.0.0.100 2015-05-07 19:56:46.8720 Info - Dlna: Creating SSDP listener on 192.168.1.100 2015-05-07 19:56:46.8720 Debug - Dlna: Found interface: Loopback Pseudo-Interface 1. Type: Loopback. Status: Up 2015-05-07 19:56:46.8720 Info - Dlna: Creating SSDP listener on 192.168.56.1 2015-05-07 19:56:46.8850 Info - Dlna: Creating SSDP listener on 127.0.0.1 2015-05-07 19:56:46.8850 Debug - Dlna: Found interface: isatap.{D9CC475F-A36D-4221-AE4F-A86C707AB076}. Type: Tunnel. Status: Down 2015-05-07 19:56:46.8850 Debug - Dlna: Found interface: Teredo Tunneling Pseudo-Interface. Type: Tunnel. Status: Down 2015-05-07 19:56:46.8850 Debug - Dlna: Found interface: isatap.{C68FC393-020D-4660-A66E-B50A00CA5DD8}. Type: Tunnel. Status: Down 2015-05-07 19:56:46.8850 Debug - Dlna: Found interface: isatap.{7C276FC1-C157-4C9B-915E-E6DAFCD73382}. Type: Tunnel. Status: Down 2015-05-07 19:56:46.9990 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/ScheduledTasks?isHidden=false Ip: 127.0.0.1:60585. Headers: Host=localhost:8096,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64; rv:37.0) Gecko/20100101 Firefox/37.0,Accept=application/json, text/javascript, */*; q=0.01,Accept-Language=en-US,en;q=0.5,Accept-Encoding=gzip, deflate,Authorization=MediaBrowser Client="Dashboard", Device="Firefox 37.0", DeviceId="33dcb75eac2c3c0f38ebfe2c83ef8708b0f4d747", Version="3.0.5597.1", UserId="43e845c29a04485f862f3a411bc2c1fb",X-MediaBrowser-Token=34f7bdec95ed44a7afe9d3c4d90cfcf2,Connection=keep-alive 2015-05-07 19:56:47.0140 Debug - Dlna: Registered mount 0173f77a-b746-f8be-c1dc-86369bdcf761 at http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/description.xml 2015-05-07 19:56:47.0140 Debug - Dlna: Registered mount 418700fa-de27-7f4b-ef72-56f2eb535948 at http://192.168.1.100:8096/dlna/418700fade277f4bef7256f2eb535948/description.xml 2015-05-07 19:56:47.1630 Debug - HttpServer: HTTP GET http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/description.xml Ip: 10.0.0.180:58016. Headers: Cache-Control=no-cache,Connection=Close,Pragma=no-cache,Accept=text/xml, application/xml,Host=10.0.0.100:8096,User-Agent=Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50 2015-05-07 19:56:47.2070 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 206.0118 ms. Url: http://localhost:8096/mediabrowser/ScheduledTasks?isHidden=false 2015-05-07 19:56:47.2480 Debug - Dlna: No matching device profile found. The default will be used. User-agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50. 2015-05-07 19:56:47.2480 Debug - HttpServer: HTTP Response 200 to 10.0.0.180. Response time: 92.0053 ms. Url: http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/description.xml 2015-05-07 19:56:47.2720 Info - App: HttpClientManager GET: http://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog 2015-05-07 19:56:47.2720 Info - App: HttpClientManager GET: http://www.mb3admin.com/admin/service/MB3ServerNotifications.json 2015-05-07 19:56:48.6371 Debug - HttpServer: HTTP GET http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/description.xml Ip: 10.0.0.189:1785. Headers: Host=10.0.0.100:8096,Connection=close,User-Agent=Mozilla/4.0 (compatible),Accept=*/* 2015-05-07 19:56:48.6711 Debug - Dlna: No matching device profile found. The default will be used. User-agent: Mozilla/4.0 (compatible). 2015-05-07 19:56:48.6711 Debug - HttpServer: HTTP Response 200 to 10.0.0.189. Response time: 34.002 ms. Url: http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/description.xml 2015-05-07 19:56:49.0061 Debug - HttpServer: HTTP SUBSCRIBE http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/contentdirectory/events Ip: 10.0.0.189:1786. Headers: Host=10.0.0.100:8096,TIMEOUT=Second-300,NT=upnp:event,CALLBACK=<http://10.0.0.189:1900/>,CONNECTION=close 2015-05-07 19:56:49.0061 Debug - UpnpContentDirectory: Creating event subscription for upnp:event with timeout of 300 to <http://10.0.0.189:1900/> 2015-05-07 19:56:49.0061 Debug - HttpServer: HTTP Response 200 to 10.0.0.189. Response time: 1.0001 ms. Url: http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/contentdirectory/events 2015-05-07 19:56:49.3181 Debug - HttpServer: HTTP GET http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/description.xml Ip: 10.0.0.161:56346. Headers: Cache-Control=no-cache,Connection=Close,Pragma=no-cache,Accept=text/xml, application/xml,Host=10.0.0.100:8096,User-Agent=Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50 2015-05-07 19:56:49.3311 Debug - Dlna: No matching device profile found. The default will be used. User-agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50. 2015-05-07 19:56:49.3311 Debug - HttpServer: HTTP Response 200 to 10.0.0.161. Response time: 20.0011 ms. Url: http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/description.xml 2015-05-07 19:56:49.4901 Info - App: HttpClientManager POST: http://www.mb3admin.com/admin/service/registration/validate 2015-05-07 19:56:49.7242 Info - App: StartupTrigger fired for task: Check for application updates 2015-05-07 19:56:49.7242 Info - App: StartupTrigger fired for task: Check for plugin updates 2015-05-07 19:56:49.7242 Info - App: StartupTrigger fired for task: Scan media library 2015-05-07 19:56:49.7242 Info - App: StartupTrigger fired for task: Refresh Guide 2015-05-07 19:56:49.7242 Info - App: Queueing task RefreshMediaLibraryTask 2015-05-07 19:56:49.7242 Info - App: Queueing task SystemUpdateTask 2015-05-07 19:56:49.7242 Info - App: Queueing task PluginUpdateTask 2015-05-07 19:56:49.7242 Info - App: Queueing task RefreshChannelsScheduledTask 2015-05-07 19:56:49.7242 Info - App: Executing Scan media library 2015-05-07 19:56:49.7242 Info - App: Validating media library 2015-05-07 19:56:49.7972 Info - App: HttpClientManager POST: https://connect.mediabrowser.tv/service/Servers?id=487ded72354875cd991938966a4f921a 2015-05-07 19:56:49.9652 Info - App: HttpClientManager GET: https://connect.mediabrowser.tv/service/ServerAuthorizations?serverId=487ded72354875cd991938966a4f921a 2015-05-07 19:56:51.8153 Info - App: HttpClientManager POST: http://www.mb3admin.com/admin/service/registration/ping 2015-05-07 19:56:52.0293 Debug - HttpServer: HTTP POST http://localhost:8096/mediabrowser/ScheduledTasks/Running/2d67d886717cdade18d9640d4ebbb9cb Ip: 127.0.0.1:60585. Headers: Host=localhost:8096,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64; rv:37.0) Gecko/20100101 Firefox/37.0,Accept=*/*,Accept-Language=en-US,en;q=0.5,Accept-Encoding=gzip, deflate,Authorization=MediaBrowser Client="Dashboard", Device="Firefox 37.0", DeviceId="33dcb75eac2c3c0f38ebfe2c83ef8708b0f4d747", Version="3.0.5597.1", UserId="43e845c29a04485f862f3a411bc2c1fb",X-MediaBrowser-Token=34f7bdec95ed44a7afe9d3c4d90cfcf2,Connection=keep-alive,Pragma=no-cache,Cache-Control=no-cache,Content-Length=0 2015-05-07 19:56:52.0303 Debug - HttpServer: HTTP Response 204 to 127.0.0.1. Response time: 10.0006 ms. Url: http://localhost:8096/mediabrowser/ScheduledTasks/Running/2d67d886717cdade18d9640d4ebbb9cb 2015-05-07 19:56:52.0473 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/ScheduledTasks?isHidden=false Ip: 127.0.0.1:60585. Headers: Host=localhost:8096,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64; rv:37.0) Gecko/20100101 Firefox/37.0,Accept=application/json, text/javascript, */*; q=0.01,Accept-Language=en-US,en;q=0.5,Accept-Encoding=gzip, deflate,Authorization=MediaBrowser Client="Dashboard", Device="Firefox 37.0", DeviceId="33dcb75eac2c3c0f38ebfe2c83ef8708b0f4d747", Version="3.0.5597.1", UserId="43e845c29a04485f862f3a411bc2c1fb",X-MediaBrowser-Token=34f7bdec95ed44a7afe9d3c4d90cfcf2,Connection=keep-alive 2015-05-07 19:56:52.0473 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 6.0003 ms. Url: http://localhost:8096/mediabrowser/ScheduledTasks?isHidden=false 2015-05-07 19:56:52.5903 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: c6b208ad11e44373ae78cacb35686d26 2015-05-07 19:56:52.5903 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 0e24066bca5745f5841801292e84af2e 2015-05-07 19:56:53.9924 Debug - HttpServer: HTTP POST http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/contentdirectory/control Ip: 10.0.0.189:1788. Headers: Host=10.0.0.100:8096,SOAPACTION="urn:schemas-upnp-org:service:ContentDirectory:1#GetSearchCapabilities",USER-AGENT=KnOS/3.2 bridgeCo-DMP/3.0 DLNADOC/1.50 INTEL_NMPR/2.0,CONNECTION=close,CONTENT-TYPE=text/xml; charset="utf-8",Content-Length=291 2015-05-07 19:56:54.2174 Debug - Dlna: No matching device profile found. The default will be used. 2015-05-07 19:56:54.2174 Debug - UpnpContentDirectory: Received control request GetSearchCapabilities 2015-05-07 19:56:54.2174 Debug - HttpServer: HTTP Response 200 to 10.0.0.189. Response time: 235.0135 ms. Url: http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/contentdirectory/control 2015-05-07 19:56:54.2464 Debug - HttpServer: HTTP POST http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/contentdirectory/control Ip: 10.0.0.189:1789. Headers: Host=10.0.0.100:8096,SOAPACTION="urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities",USER-AGENT=KnOS/3.2 bridgeCo-DMP/3.0 DLNADOC/1.50 INTEL_NMPR/2.0,CONNECTION=close,CONTENT-TYPE=text/xml; charset="utf-8",Content-Length=289 2015-05-07 19:56:54.4674 Debug - Dlna: No matching device profile found. The default will be used. 2015-05-07 19:56:54.4674 Debug - UpnpContentDirectory: Received control request GetSortCapabilities 2015-05-07 19:56:54.4674 Debug - HttpServer: HTTP Response 200 to 10.0.0.189. Response time: 221.0127 ms. Url: http://10.0.0.100:8096/dlna/0173f77ab746f8bec1dc86369bdcf761/contentdirectory/control 2015-05-07 19:56:54.9645 Info - App: HttpClientManager GET: http://bot.whatismyipaddress.com/ 2015-05-07 19:56:55.5465 Info - App: HttpClientManager POST: https://connect.mediabrowser.tv/service/Servers?id=487ded72354875cd991938966a4f921a 2015-05-07 19:56:55.6465 Info - App: HttpClientManager GET: https://connect.mediabrowser.tv/service/ServerAuthorizations?serverId=487ded72354875cd991938966a4f921a 2015-05-07 19:56:56.7116 Info - App: StartupTrigger fired for task: Refresh Channels 2015-05-07 19:56:56.7116 Info - App: Queueing task RefreshChannelsScheduledTask 2015-05-07 19:57:16.7247 Info - App: StartupTrigger fired for task: Log file cleanup 2015-05-07 19:57:16.7247 Info - App: Queueing task DeleteLogFileTask 2015-05-07 19:57:17.6718 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/web/library.html Ip: 127.0.0.1:60585. Headers: Host=localhost:8096,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64; rv:37.0) Gecko/20100101 Firefox/37.0,Accept=text/html, */*; q=0.01,Accept-Language=en-US,en;q=0.5,Accept-Encoding=gzip, deflate,Connection=keep-alive,If-None-Match=96ad335c967f3b44a7dd9b67fb35e000 2015-05-07 19:57:17.6718 Debug - HttpServer: HTTP Response 304 to 127.0.0.1. Response time: 1.0001 ms. Url: http://localhost:8096/mediabrowser/web/library.html 2015-05-07 19:57:17.8748 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/Library/VirtualFolders Ip: 127.0.0.1:60585. Headers: Host=localhost:8096,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64; rv:37.0) Gecko/20100101 Firefox/37.0,Accept=application/json, text/javascript, */*; q=0.01,Accept-Language=en-US,en;q=0.5,Accept-Encoding=gzip, deflate,Authorization=MediaBrowser Client="Dashboard", Device="Firefox 37.0", DeviceId="33dcb75eac2c3c0f38ebfe2c83ef8708b0f4d747", Version="3.0.5597.1", UserId="43e845c29a04485f862f3a411bc2c1fb",X-MediaBrowser-Token=34f7bdec95ed44a7afe9d3c4d90cfcf2,Connection=keep-alive 2015-05-07 19:57:17.8748 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/ScheduledTasks?IsEnabled=true Ip: 127.0.0.1:60587. Headers: Host=localhost:8096,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64; rv:37.0) Gecko/20100101 Firefox/37.0,Accept=application/json, text/javascript, */*; q=0.01,Accept-Language=en-US,en;q=0.5,Accept-Encoding=gzip, deflate,Authorization=MediaBrowser Client="Dashboard", Device="Firefox 37.0", DeviceId="33dcb75eac2c3c0f38ebfe2c83ef8708b0f4d747", Version="3.0.5597.1", UserId="43e845c29a04485f862f3a411bc2c1fb",X-MediaBrowser-Token=34f7bdec95ed44a7afe9d3c4d90cfcf2,Connection=keep-alive 2015-05-07 19:57:17.8848 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 9.0005 ms. Url: http://localhost:8096/mediabrowser/Library/VirtualFolders 2015-05-07 19:57:17.8948 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 19.0011 ms. Url: http://localhost:8096/mediabrowser/ScheduledTasks?IsEnabled=true 2015-05-07 19:57:18.8028 Info - App: HttpClientManager GET: http://www.thetvdb.com/api/GetSeries.php?seriesname=Yo+Gabba+Gabba&language=en 2015-05-07 19:57:18.9028 Info - App: Executing Check for application updates 2015-05-07 19:57:18.9028 Info - App: HttpClientManager GET: http://www.mb3admin.com/admin/service/MB3Packages.json 2015-05-07 19:57:18.9098 Info - App: Executing Refresh Guide 2015-05-07 19:57:19.3329 Info - App: TVDb Provider - yo gabba gabba did not match yo gabba gabba 2015-05-07 19:57:19.3329 Info - App: TVDb Provider - Could not find Yo Gabba Gabba. Check name on Thetvdb.org. 2015-05-07 19:57:19.3329 Debug - App: Running SeriesNfoProvider for \\media\Series Shows\Yo Gabba Gabba 2015-05-07 19:57:19.3329 Debug - App: SeriesNfoProvider returned no metadata for \\media\Series Shows\Yo Gabba Gabba 2015-05-07 19:57:19.3329 Debug - App: Running SeriesXmlProvider for \\media\Series Shows\Yo Gabba Gabba 2015-05-07 19:57:19.3859 Info - LibraryMonitor: Watching directory C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\camerauploads 2015-05-07 19:57:19.3859 Info - LibraryMonitor: Watching directory C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\root 2015-05-07 19:57:19.3859 Info - LibraryMonitor: Watching directory C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\playlists 2015-05-07 19:57:19.3859 Info - LibraryMonitor: Watching directory C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\data\collections 2015-05-07 19:57:19.3949 Error - App: Error *** Error Report *** Version: 3.0.5597.1 Command line: C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Richard\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Richard\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Object reference not set to an instance of an object. System.NullReferenceException at MediaBrowser.Providers.TV.SeriesMetadataService.MergeData(Series source, Series target, List`1 lockedFields, Boolean replaceData, Boolean mergeMetadataSettings) at MediaBrowser.Providers.Manager.MetadataService`2.<RefreshWithProviders>d__2d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Providers.Manager.MetadataService`2.<RefreshMetadata>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.BaseItem.<RefreshMetadata>d__1e.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.TV.Series.<RefreshAllMetadata>d__10.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.Folder.<RefreshChildMetadata>d__d6.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.Folder.<RefreshMetadataRecursive>d__cd.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.Folder.<RefreshChildMetadata>d__d6.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Controller.Entities.Folder.<RefreshMetadataRecursive>d__cd.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Controller.Entities.Folder.<ValidateChildrenInternal>d__ba.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Server.Implementations.Library.LibraryManager.<PerformLibraryValidation>d__5b.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Server.Implementations.Library.LibraryManager.<ValidateMediaLibraryInternal>d__54.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Common.Implementations.ScheduledTasks.ScheduledTaskWorker.<ExecuteInternal>d__c.MoveNext() 2015-05-07 19:57:19.3949 Info - App: Scan media library Failed after 0 minute(s) and 29 seconds 2015-05-07 19:57:19.3949 Info - LibraryMonitor: Watching directory \\media\series shows 2015-05-07 19:57:19.3949 Info - LibraryMonitor: Watching directory \\media\Movies 2015-05-07 19:57:19.4079 Debug - NotificationManager: Sending notification via Dashboard Notifications to user Richard 2015-05-07 19:57:19.4569 Debug - App: No application update available. 2015-05-07 19:57:19.4569 Info - App: Check for application updates Completed after 0 minute(s) and 0 seconds 2015-05-07 19:57:23.9031 Info - App: Refresh Guide Completed after 0 minute(s) and 4 seconds 2015-05-07 19:57:24.2151 Info - App: Executing Check for plugin updates 2015-05-07 19:57:24.2151 Info - App: Check for plugin updates Completed after 0 minute(s) and 0 seconds 2015-05-07 19:57:24.5112 Info - App: Executing Refresh Channels 2015-05-07 19:57:24.5112 Info - App: Refresh Channels Completed after 0 minute(s) and 0 seconds 2015-05-07 19:57:24.6592 Info - App: Executing Log file cleanup 2015-05-07 19:57:24.6972 Info - App: Log file cleanup Completed after 0 minute(s) and 0 seconds 2015-05-07 19:57:41.0061 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/web/scheduledtasks.html Ip: 127.0.0.1:60587. Headers: Host=localhost:8096,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64; rv:37.0) Gecko/20100101 Firefox/37.0,Accept=text/html, */*; q=0.01,Accept-Language=en-US,en;q=0.5,Accept-Encoding=gzip, deflate,Connection=keep-alive,If-None-Match=ca9d22f44593e1618ff07b15724e0c32 2015-05-07 19:57:41.0061 Debug - HttpServer: HTTP Response 304 to 127.0.0.1. Response time: 0 ms. Url: http://localhost:8096/mediabrowser/web/scheduledtasks.html 2015-05-07 19:57:41.1321 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/ScheduledTasks?isHidden=false Ip: 127.0.0.1:60587. Headers: Host=localhost:8096,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64; rv:37.0) Gecko/20100101 Firefox/37.0,Accept=application/json, text/javascript, */*; q=0.01,Accept-Language=en-US,en;q=0.5,Accept-Encoding=gzip, deflate,Authorization=MediaBrowser Client="Dashboard", Device="Firefox 37.0", DeviceId="33dcb75eac2c3c0f38ebfe2c83ef8708b0f4d747", Version="3.0.5597.1", UserId="43e845c29a04485f862f3a411bc2c1fb",X-MediaBrowser-Token=34f7bdec95ed44a7afe9d3c4d90cfcf2,Connection=keep-alive 2015-05-07 19:57:41.1321 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 5.0002 ms. Url: http://localhost:8096/mediabrowser/ScheduledTasks?isHidden=false 2015-05-07 19:57:44.0313 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/web/support.html Ip: 127.0.0.1:60587. Headers: Host=localhost:8096,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64; rv:37.0) Gecko/20100101 Firefox/37.0,Accept=text/html, */*; q=0.01,Accept-Language=en-US,en;q=0.5,Accept-Encoding=gzip, deflate,Connection=keep-alive,If-None-Match=3d5f0b654c1a7cd18f866cb14570d5f9 2015-05-07 19:57:44.0313 Debug - HttpServer: HTTP Response 304 to 127.0.0.1. Response time: 1 ms. Url: http://localhost:8096/mediabrowser/web/support.html 2015-05-07 19:57:45.5854 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/web/log.html Ip: 127.0.0.1:60587. Headers: Host=localhost:8096,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64; rv:37.0) Gecko/20100101 Firefox/37.0,Accept=text/html, */*; q=0.01,Accept-Language=en-US,en;q=0.5,Accept-Encoding=gzip, deflate,Connection=keep-alive,If-None-Match=de6088a37aefe0a3542f85995642cccd 2015-05-07 19:57:45.5854 Debug - HttpServer: HTTP Response 304 to 127.0.0.1. Response time: 1 ms. Url: http://localhost:8096/mediabrowser/web/log.html 2015-05-07 19:57:45.7054 Debug - HttpServer: HTTP GET http://localhost:8096/mediabrowser/System/Logs Ip: 127.0.0.1:60587. Headers: Host=localhost:8096,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64; rv:37.0) Gecko/20100101 Firefox/37.0,Accept=application/json, text/javascript, */*; q=0.01,Accept-Language=en-US,en;q=0.5,Accept-Encoding=gzip, deflate,Authorization=MediaBrowser Client="Dashboard", Device="Firefox 37.0", DeviceId="33dcb75eac2c3c0f38ebfe2c83ef8708b0f4d747", Version="3.0.5597.1", UserId="43e845c29a04485f862f3a411bc2c1fb",X-MediaBrowser-Token=34f7bdec95ed44a7afe9d3c4d90cfcf2,Connection=keep-alive 2015-05-07 19:57:45.7094 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 11.0007 ms. Url: http://localhost:8096/mediabrowser/System/Logs 2015-05-07 19:57:46.7234 Info - App: StartupTrigger fired for task: Cache file cleanup 2015-05-07 19:57:46.7234 Info - App: Queueing task DeleteCacheFileTask 2015-05-07 19:57:46.7234 Info - App: Executing Cache file cleanup I cannot tell what this is from the log so i will make a change based on a theory and also add more logging to find out what it is.
richardbigg 1 Posted May 8, 2015 Posted May 8, 2015 I've dropped the "series" folders from the library, and performed another scan... It completed without error... I added it back, it failed... I removed the "Yo Gabba Gabba" folder It stilled failed, So I systematically removed and added folders until I narrowed down the culprit, but it fails on numerous different "TV Series" folders. All prefaced with this: 2015-05-07 21:19:25.4766 Info - App: HttpClientManager GET: http://www.thetvdb.com/api/GetSeries.php?seriesname=The+Muppet+Show&language=en 2015-05-07 21:19:25.8716 Info - App: TVDb Provider - muppet show did not match muppet show 2015-05-07 21:19:25.8716 Info - App: TVDb Provider - Could not find The Muppet Show. Check name on Thetvdb.org. 2015-05-07 21:19:25.8716 Debug - App: Running SeriesNfoProvider for \\media\Series Shows\The Muppet Show 2015-05-07 21:19:25.8716 Debug - App: SeriesNfoProvider returned no metadata for \\media\Series Shows\The Muppet Show 2015-05-07 21:19:25.8716 Debug - App: Running SeriesXmlProvider for \\media\Series Shows\The Muppet Show 2015-05-07 21:19:25.8956 Error - App: Error *** Error Report *** Let me know what I can do to test those changes you are making... If you need any further information, please advise. Richard
steve1977 67 Posted May 16, 2015 Posted May 16, 2015 I am also facing the "library stuck" issue. Unfortunately not only recently, but on and off since over a year. My issue is that it does get stuck when adding a large amount of new things (movies, music, etc.). It does not / less stuck when just restarting. Below a log file with the specific error message. This may be related to other issues, so I will cross-post in related threads. http://pastebin.com/E1GtgkB9
steve1977 67 Posted May 30, 2015 Posted May 30, 2015 Any update on this and anyone else having this issue. My other issue (http://emby.media/community/index.php?/topic/21610-error-sending-datagram/) may or may not be related to the library scanning. I have now let it run for the last 5 days, but it remains stuck at 51%. I have sent @@Luke last weekend the full error log from a few-day-scan. Let me know if anyone has a solution or idea, which could have led to this issue? Thanks!!!
steve1977 67 Posted June 5, 2015 Posted June 5, 2015 @@Luke, anything more I can provide? Had it yet again run for the last 5 days, but still stuck and no progress completing the scan. Any thoughts?
Luke 42204 Posted June 5, 2015 Posted June 5, 2015 try disabling fanart and musicbrainz for all library item types
steve1977 67 Posted June 6, 2015 Posted June 6, 2015 Thanks. I am still doing some troubleshooting, but it appears that Musibrainz indeed causes the issue. Any thoughts why and how it can be solved without disabling it?
oldschool 16 Posted June 23, 2015 Posted June 23, 2015 (edited) Just updating from a conversation we had earlier. I had turned off the Enable Real Time Monitoring feature, but I think in one of the latest server updates it turned it back on (or set it to "Auto"). This forced an scan this morning when I uploaded a file to the server. During our conversation, it was stated that Emby looks to only scan in the items that have been added since the last successful scan. I can verify that there were only 4 movies added since last night to my "Latest Media". Whether the latest scan detected only 1 or all 4 during its latest scan, I couldn't tell you, but I know there were a maximum of 4 new movies added to the library in the latest scan. I checked my server this morning and it started the scan at 06:22:01 because it was reporting a change in one folder. The scan ended at 12:28:48, reporting 366 minutes and 46 seconds to scan the library. So, either it took over 6 hours to scan in 4 items, or it is scanning the entire library and refreshing all the metadata from every item in my library during every scan. I was asking for a feature where it would scan only the 4 items into the library during the real time monitoring, and then do a full scan scheduled during my daily scans at midnight (or whenever I schedule it for downtime). By comparing date/time stamps for the modified folders, those items that have changed since the last scan would ideally be the only ones Emby scans during the monitor scans, IMHO. During scans, the web client front page shows up blank. I can get to the admin screen, but the sections that show the folders, libraries, etc that you can navigate to your media do not show up until the scan is complete. I wish there was a resolution to that problem as well (caching the front page to show the items from the last known successful scan), but I can live with a non-responding front page during scans if Emby could be a little smarter about what it scans during these real time monitor scans and how long it takes to add new data to the database. Using Emby Version 3.0.5641.4 on Win Server 2K8. Log file attached. server-63570614400.zip Edited June 23, 2015 by oldschool
steve1977 67 Posted June 26, 2015 Posted June 26, 2015 I keep on having the same issue that my library scan does not complete. In my case, I think it is a music / MBZ - related issue, but hard to say. Anyone can read anything in the log what may be related to it. I had it running for several days before, but same result as now. http://we.tl/ZxHzAPB0Ht
steve1977 67 Posted June 28, 2015 Posted June 28, 2015 I had it yet again run over night with same result Below a new log. It keeps on being stuck. Videos scan fine, but music leads to being stuck. Any ideas? http://we.tl/HVMn6N0zjc
Luke 42204 Posted June 28, 2015 Posted June 28, 2015 just keep mbz disabled until the reason for that is figured out
steve1977 67 Posted July 4, 2015 Posted July 4, 2015 Unfortunately, this did not solve it. I disabled MBZ and even removed the music library. Unfortunately, the issue remains. I can provide a fresh log tomorrow, but - from checking the logs - the many error messages are the same as in the log files that I have provided above. Any idea what is causing this and worth to try the development built? I am currently on the latest beta.
steve1977 67 Posted July 5, 2015 Posted July 5, 2015 I deleted my library, cache and about everything else that could be causing this issue. With librry scan stuck, Emby was basically non-usable anyways. I now added only one movie folder with 100 movies. No music, shows or anything else. Scan is yet again stuck, but log easier to read / smaller. I dont see anything though. Any idea what i could do to trouble-shoot? Log below: http://we.tl/qTCP9NK2z2
ebr 16310 Posted July 5, 2015 Posted July 5, 2015 Try some different hardware. Perhaps there is an issue with a disc or something.
steve1977 67 Posted July 6, 2015 Posted July 6, 2015 Thanks, I am starting to get an idea what it is about. Whenever it gets stuck and I restart, it gets stuck again at exactly the same %. One way to get it progress is to renew my IP Address. So, I scan until it gets stuck. Then I shut down Emby and renew my IP address. Then I start Emby again and let it scan. It then goes a bit further and gets stuck at a different point. Yet again, restarting and changing IP address gets it a bit further. Not sure whether I will ever get it to complete the scan, but above may allow to narrow down the issue and a potential solution?
Luke 42204 Posted July 6, 2015 Posted July 6, 2015 try removing the last fm plugin. someone else reported something similar and that fixed it
steve1977 67 Posted July 6, 2015 Posted July 6, 2015 Thanks, will do and report back. For now, I don't even have any single song in the music library. Will still give it a shot.
steve1977 67 Posted July 6, 2015 Posted July 6, 2015 Unfortunately, uninstalling lastfm did not change anything. Also, I disabled chapter image extraction, but also no success. Below one of the error messages, which comes up quite often right before it stucks. It is not fully consistent, but maybe related? 2015-07-06 20:34:09.9352 Error - HttpServer: Error in HttpConnection.BeginReadRequest. ConnectionId: da6c0d74f8da403882003af18f3cd3cf *** Error Report *** Version: 3.0.5641.4 Command line: C:\Users\user\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 4 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\user\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\user\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Unable to read data from the transport connection: An established connection was aborted by the software in your host machine. System.IO.IOException at System.Net.Sockets.NetworkStream.BeginRead(Byte[] buffer, Int32 offset, Int32 size, AsyncCallback callback, Object state) at SocketHttpListener.Net.HttpConnection.BeginReadRequest() InnerException: System.Net.Sockets.SocketException An established connection was aborted by the software in your host machine at System.Net.Sockets.Socket.BeginReceive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags, AsyncCallback callback, Object state) at System.Net.Sockets.NetworkStream.BeginRead(Byte[] buffer, Int32 offset, Int32 size, AsyncCallback callback, Object state)
Jasoon 9 Posted August 10, 2015 Posted August 10, 2015 Is this problem still about? Im having the same issues and it seems to be when my phone is on the device list it looks for camerauploads even thou its not selected
somy 25 Posted August 21, 2015 Posted August 21, 2015 (edited) Could be a similar issue, but mine photo scan also take a long time and consumes a lot of resource. Reported: http://emby.media/community/index.php?/topic/24430-high-cpu-and-disk-usage/ Edited August 21, 2015 by somy
