Luke 42241 Posted January 23, 2018 Posted January 23, 2018 I would just remove all of that and let the core server handle it.
Tolotos 61 Posted January 23, 2018 Author Posted January 23, 2018 @@fc7 can you please check without probing if subtites and different language streams are working?
Luke 42241 Posted January 23, 2018 Posted January 23, 2018 @@fc7 can you please check without probing if subtites and different language streams are working? They won't be, but it will be handled in the core, so its' not something the plugin should worry about. Thanks.
jl94x4 14 Posted January 28, 2018 Posted January 28, 2018 Hi, I've installed TVheadend on my server and configured it correctly, I've installed tvheadend plugin on Emby, how do i get this functioning from here? My Live TV won't detect new device. Thanks
Luke 42241 Posted January 28, 2018 Posted January 28, 2018 That's all you need to do. Now just run the guide refresh in emby server.
jleckenby 13 Posted January 28, 2018 Posted January 28, 2018 Hi guys, Started using it a bit more, working for the most part! However since I installed the latest emby and reinstalled the plugin I have no channel logos. Any ideas? Ive confirmed the urls provided for them are correct.
Luke 42241 Posted January 28, 2018 Posted January 28, 2018 Hi guys, Started using it a bit more, working for the most part! However since I installed the latest emby and reinstalled the plugin I have no channel logos. Any ideas? Ive confirmed the urls provided for them are correct. I could be wrong but I thought we've seen cases of tvheadend sending back svg logos, in which case those will not work.
michael_stonebridge 0 Posted February 1, 2018 Posted February 1, 2018 (edited) Hi guys, Started using it a bit more, working for the most part! However since I installed the latest emby and reinstalled the plugin I have no channel logos. Any ideas? Ive confirmed the urls provided for them are correct. Same here, the logos are all pngs and show up fine on the tvheadend website, but they no longer work in Emby. They worked in previous versions of Emby. There are other reports of missing logos (https://emby.media/community/index.php?/topic/55451-tvheadend-no-channel-icons-after-upgrades/). The channels do have a channel icon set, and I can get the images from http://<tvh_ip>:<port>/imagecache/<nr>. Even with debug logging enabled I don't see any requests to tvheadend for channel logos, even after wiping the cache in Emby. 2018-02-01 16:35:38.140 Info App: [TVHclient] ChannelDataHelper: Adding channel HTSMessage: <dump> channelId : 23001047 channelNumber : 31 channelName : BR Fernsehen Süd HD channelIcon : imagecache/165 eventId : 780603 nextEventId : 780605 services : HTSMessage: <dump> name : Astra/11582.25H/BR Fernsehen Süd HD type : HDTV content : 1 </dump> , tags : 1, 4, method : channelAdd </dump> Edited February 1, 2018 by michael_stonebridge
jfath 2 Posted February 3, 2018 Posted February 3, 2018 I noticed something strange, but not critical. When I play a live channel from my HDHR extend through Tvheadend with this plugin, I notice in the tvh log that it almost always subscribes and unsubscribes to the channel several times showing continuity errors during the failed subscriptions. When I play the same live channels from the same machine using Kodi and their tvh plugin, there are never any failed subscriptions nor continuity errors. This makes no sense to me, as it seems like it would be a tvh<->hdhr communication issue and the client would have no affect, but I see it consistently. The only noticeable effect is that it takes slightly longer for the video to begin streaming in Emby, so this is not at all critical. I just wonder if others have seen the same or have any idea what might be causing it.
Luke 42241 Posted February 3, 2018 Posted February 3, 2018 @@jfath, are you aware that Emby has native support for HDHR? You can use your HDHR without the need for any plugin and that should give you the best experience.
jfath 2 Posted February 3, 2018 Posted February 3, 2018 Yes, thanks Luke. But I also feed my cable boxes through tvh using old USB component capture boxes and I like having everything managed through that single interface.
Luke 42241 Posted February 3, 2018 Posted February 3, 2018 Yes, thanks Luke. But I also feed my cable boxes through tvh using old USB component capture boxes and I like having everything managed through that single interface. I understand that, but you should still be aware you'll get the best experience with the native support. It is no fault of the TVH plugin, it's simply a matter of that's what I'm able to test personally and continuously refine over time.
jfath 2 Posted February 3, 2018 Posted February 3, 2018 Absolutely understand. Already getting a great experience and I know there'll be hiccups as long as I'm running a non-standard setup. Just happy that you and Tolotos have given tvh users an integration option.
jleckenby 13 Posted February 7, 2018 Posted February 7, 2018 Hi, Has anyone managed to work out why logos are missing on the latest emby and tvheadend release? I can see the channel coming through: 2018-02-07 02:00:03.227 Info App: [TVHclient] ChannelDataHelper: Adding channelHTSMessage:<dump>channelId : 752227772channelNumber : 115channelName : BBC One HDchannelIcon : imagecache/354eventId : 65141nextEventId : 65143services :HTSMessage:<dump>name : IPTV 1/get.php - UK: BBC ONE FHD/Service01type : SDTVcontent : 1</dump>,tags : 1,method : channelUpdate</dump>And the channel icon URL when called from my browser correctly returns the icon. Not a huge issue, just bugging me!
Luke 42241 Posted February 23, 2018 Posted February 23, 2018 In another topic, another user has confirmed that the logos are working with the next release of Emby Server and an updated TVheadEnd plugin. Thanks guys.
bobwinters 1 Posted February 25, 2018 Posted February 25, 2018 (edited) I've just reinstalled Emby and switched to the Docker version and I'm unable to get the logos. The logos were working fine before. The message I get when I try to view the thumbnail from Emby is "Unauthorized" Edited February 25, 2018 by bobwinters
Luke 42241 Posted February 25, 2018 Posted February 25, 2018 I've just reinstalled Emby and switched to the Docker version and I'm unable to get the logos. The logos were working fine before. Please try refreshing the guide and if the issue remains attach the information requested in how to report a problem. thanks. 1
Marv 9 Posted February 25, 2018 Posted February 25, 2018 My "Others" recording folder ist just empty after upgrading and I got a few channel logos which still not show. strange is, there actually are icons (all black) when clicking on edit image for the channels where no icon is shown. Kodi aswell as the Tvh app show these icons correctly for me. It seems that Emby just doesn't display them correctly I don't know :/
Gerrit507 24 Posted February 25, 2018 Posted February 25, 2018 My emby server crashes multiple times a day because of an unhandled exception in the tvheadend plugin: System.PlatformNotSupportedException: Thread abort is not supported on this platform. at System.Threading.Thread.Abort() at TVHeadEnd.HTSP.HTSConnectionAsync.stop() at TVHeadEnd.HTSConnectionHandler.onError(Exception ex) at TVHeadEnd.HTSP.HTSConnectionAsync.SendingHandler() at System.Threading.Thread.ThreadMain_ThreadStart() at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) System.PlatformNotSupportedException at System.Threading.Thread.Abort() at TVHeadEnd.HTSP.HTSConnectionAsync.stop() at TVHeadEnd.HTSConnectionHandler.onError(Exception ex) at TVHeadEnd.HTSP.HTSConnectionAsync.SendingHandler() at System.Threading.Thread.ThreadMain_ThreadStart() at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) Ubuntu Server 16.04 Emby 3.2.70.0
Gerrit507 24 Posted February 25, 2018 Posted February 25, 2018 Apparently thread abort is not supported in net core https://stackoverflow.com/questions/39243016/cant-find-abort-method-in-thread
Luke 42241 Posted February 25, 2018 Posted February 25, 2018 That part of the plugin will need to be reworked.
fc7 123 Posted February 25, 2018 Posted February 25, 2018 They won't be, but it will be handled in the core, so its' not something the plugin should worry about. Thanks. Sorry for the late reply. Indeed they don’t work. So I’m not sure if I understand you correctly @@Luke. But what’s the point of the core handling it if it doesn’t work? Will it be fixed? Sent from my iPhone using Tapatalk
Luke 42241 Posted February 25, 2018 Posted February 25, 2018 My emby server crashes multiple times a day because of an unhandled exception in the tvheadend plugin: System.PlatformNotSupportedException: Thread abort is not supported on this platform. at System.Threading.Thread.Abort() at TVHeadEnd.HTSP.HTSConnectionAsync.stop() at TVHeadEnd.HTSConnectionHandler.onError(Exception ex) at TVHeadEnd.HTSP.HTSConnectionAsync.SendingHandler() at System.Threading.Thread.ThreadMain_ThreadStart() at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) System.PlatformNotSupportedException at System.Threading.Thread.Abort() at TVHeadEnd.HTSP.HTSConnectionAsync.stop() at TVHeadEnd.HTSConnectionHandler.onError(Exception ex) at TVHeadEnd.HTSP.HTSConnectionAsync.SendingHandler() at System.Threading.Thread.ThreadMain_ThreadStart() at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) Ubuntu Server 16.04 Emby 3.2.70.0 I've pushed an update to the plugin to catch the Thread abort errors and this will at least prevent the crashing. However, the root issue remains. the plugin is still spawning a lot of threads which will increase resource consumption. It could benefit from a rewrite. 1
Gerrit507 24 Posted February 26, 2018 Posted February 26, 2018 I've pushed an update to the plugin to catch the Thread abort errors and this will at least prevent the crashing. However, the root issue remains. the plugin is still spawning a lot of threads which will increase resource consumption. It could benefit from a rewrite. Thank you, is the update available in the catalog? I think there is something wrong with it. Before I had installed version 1.1.1.1 and I've never got any update notification. Then I deinstalled the addon and installed version 1.2.7, which I'd guess is the newer one. Now it also shows me only the versions 1.1.1.1 and 1.1.0.1. See the attached screenshot.
Luke 42241 Posted February 26, 2018 Posted February 26, 2018 Make sure you're running the latest version of emby server.
