Angelblue05 4132 Posted September 20, 2016 Posted September 20, 2016 (edited) Version 2.2.36Add: Repair sync can now be filtered by content type (movies, tvshows, musicvideos and/or music if enabled) Automatically download external subs with language tag for direct streaming Fix: Fix broken music artwork Fix to music direct stream (avoid transcode and adjust file extensions used) - you will need to repair your music library to apply the changes. Edited September 21, 2016 by Angelblue05 4
Angelblue05 4132 Posted September 26, 2016 Posted September 26, 2016 (edited) Version 2.2.38 Add: Support favorite episodes Update Dutch translation Fix: Specials -1 bug (you'll need to refresh problematic specials episode to correct the issue moving forward) Series pooling minor fixes (album artists, initial setup) Edited October 4, 2016 by Angelblue05 2
Angelblue05 4132 Posted October 4, 2016 Posted October 4, 2016 (edited) Version 2.2.40 Mostly stability fixes Add: Update German translationFix: the server detection in the event the connection times out the sync being run indefinitely User migration for new login system for users coming from 2.2.19(stable) Edited October 8, 2016 by Angelblue05 4
Angelblue05 4132 Posted October 9, 2016 Posted October 9, 2016 (edited) Version 2.2.42 Emergency update for people using the latest beta server (3.1.182.0) Fix: Set Subtitles and Disable Subtitles web command Playstate-Delete conflict Temp fix for server bug (missing production locations in the api) Encoding issue with playback properties Edited October 11, 2016 by Angelblue05 5
Angelblue05 4132 Posted October 11, 2016 Posted October 11, 2016 (edited) Version 2.2.45 This build is mostly about cleaning up the code so we can easily add to it in the future. Please report any issues following our How to report guidelines: https://emby.media/community/index.php?/topic/17599-how-to-report-a-problem/ Add: Catch any errors when processing content. The server api is constantly evolving, this will help prevent the add-on from crashing due to unexpected changes. Currently, it will fail silently with a log message, but eventually there will be a visual indicator, if something is wrong when adding or updating your content.Fix: Review the music import process to fix a few existing discrepancies between Kodi and the webclient. You may need to do a repair to fix existing issues. If the issue still persist, please try a reset of your local database. If all fails, please report the situation so it can be looked at immediately. Edited October 12, 2016 by Angelblue05 5
Angelblue05 4132 Posted October 20, 2016 Posted October 20, 2016 (edited) Version 2.2.52 Fix: Logging errors Rework manual sync When a video library is disabled for the user, the add-on will automatically remove content that belongs in Kodi; it replaces the need to run a manual sync to remove the content that no longer belongs Minor fixes Edited October 20, 2016 by Angelblue05 7
Angelblue05 4132 Posted October 23, 2016 Posted October 23, 2016 (edited) Version 2.2.54 Next version will be our new stable (unless new errors pop up). It's time! Please report any errors as soon as possible. Add: New setting under add-on settings > extras > display message. This control how long messages received will display for.Fix: Attempt to fix path validation when there's special characters (umlaut, etc) Other minor fixes We are always looking for people to help translate the add-on. If you are interested, please contact me by PM with your email address and languages you want to translate. We'll get you setup. Edited October 23, 2016 by Angelblue05 5
Angelblue05 4132 Posted October 27, 2016 Posted October 27, 2016 (edited) Version 2.2.57 Alright, I know I said next version, but turns out there were a few more bugs to fix. Hopefully this is it. Fix: External subtitles which are not utf-8 encoded, played via HTTP. They should now display correctly if the language tag is included in the filename, such as filename.pt.srt Other minor fixes Edited October 27, 2016 by Angelblue05 3
Angelblue05 4132 Posted October 31, 2016 Posted October 31, 2016 Version 2.3.2 Everyone is set to use the stable version until a new beta version is ready. Check the post containing the 2.3.2 build release information: https://emby.media/community/index.php?/topic/21888-emby-for-kodi-liv-stable/?p=380639 2
Angelblue05 4132 Posted November 8, 2016 Posted November 8, 2016 Version 2.3.9 We are currently looking into the database being locked issue. Attempt to resolve database being locked other minor bugs introduced in 2.3.7-2.3.8 3
Angelblue05 4132 Posted December 3, 2016 Posted December 3, 2016 (edited) Version 2.3.23 This build contains modification to the way we gather metadata from the server. Please report if you experience any issues with gathering content from your server. Adjustments to the download process. See "Maximum items requested and download threads" in our wiki docs for more info: https://github.com/MediaBrowser/plugin.video.emby/wiki/Emby-for-kodi-settings#sync-options Fix the fast sync to correctly fall back to manual sync in the event it fails (a warning prompt has been added to make you aware of this situation) Fix the emby backup not working correctly on certain devices other minor fixes to bugs that have been recently introduced Edited December 3, 2016 by Angelblue05 2
Angelblue05 4132 Posted December 6, 2016 Posted December 6, 2016 Version 2.3.24 Add Italian translation Fix bug in the manual sync process 2
im85288 1493 Posted December 29, 2016 Posted December 29, 2016 Version 2.3.26 Preparation for Krypton ratings 2
im85288 1493 Posted December 29, 2016 Posted December 29, 2016 Version 2.3.27 Further preparation for Krypton 2
im85288 1493 Posted December 31, 2016 Posted December 31, 2016 Version 2.3.28 More Krypton preparation 2
im85288 1493 Posted December 31, 2016 Posted December 31, 2016 Version 2.3.29 Further Krypton preparation, in particular for the movie/tvshow/episode ratings which have changed under the hood in the Krypton version. 2
im85288 1493 Posted December 31, 2016 Posted December 31, 2016 Version 2.3.30 Ratings should now be working correctly with this hopefully last change. 3
im85288 1493 Posted January 1, 2017 Posted January 1, 2017 Version 2.3.31 Krypton ratings should now support being updated from Emby. 2
im85288 1493 Posted January 1, 2017 Posted January 1, 2017 Version 2.3.32 Bring back Jarvis compatibility 2
im85288 1493 Posted January 1, 2017 Posted January 1, 2017 Version 2.3.33 Bring back Jarvis compatibility part 2 2
