vincen 72 Posted October 11, 2024 Posted October 11, 2024 4 hours ago, Carlo said: 'm seeing quite a few errors being generated in your logs. Some of the worst are: SQLitePCL.pretty.SQLiteException: Constraint: FOREIGN KEY constraint failed SQLitePCL.pretty.SQLiteException: Exception of type 'SQLitePCL.pretty.SQLiteException' was thrown. This is likely corrupt or mismatched data from trying to fix your system previously. Your best bet at this point is likely to remove Emby and it's files, then re-install fresh. Hi @Carlo Thanks for confirmation that just adding a directory at an existing library killed my system ! In that case I'm going to take time to think about it and perhaps give up on Emby because that's just too bad software sorry to say Side question: it's an error in the library.db I guess ? isn't it possible to reset it ? just to avoid to have to recreate all users account ! Thanks
Carlo 4561 Posted October 13, 2024 Posted October 13, 2024 The problem is likely mis-matched data in your databases that's causing the REIGN KEY constraint errors. It would be very difficult to try and manually fix this. The best method to get you back up and running would be to uninstall the server and remove it from the file system. Then perform a new installation.
vincen 72 Posted October 13, 2024 Posted October 13, 2024 7 hours ago, Carlo said: The problem is likely mis-matched data in your databases that's causing the REIGN KEY constraint errors. It would be very difficult to try and manually fix this. The best method to get you back up and running would be to uninstall the server and remove it from the file system. Then perform a new installation. Thanks for details but how did it appear just by changing properties of a library ? there is a very serious issue/bug there no ? Well I just deleted the library.db and redid the whole indexation of medias from scratch and will see how it goes... So far it runs perfect and Emby is lot faster than before ! 2
Carlo 4561 Posted October 16, 2024 Posted October 16, 2024 Just checking in with you. Everything still working well?
vincen 72 Posted October 16, 2024 Posted October 16, 2024 19 minutes ago, Carlo said: Just checking in with you. Everything still working well? Well so far so good, it is finishing currently to reindex all medias Is there an easy way to check regularly "health" of the database to detect any problems before they become a major issue ?
Carlo 4561 Posted October 16, 2024 Posted October 16, 2024 From this Knowledge Base article: https://emby.media/support/articles/Corrupt-Database.html Check the section Run Integrity Check. Best bet is to make sure you have a good backup. https://emby.media/support/articles/Backup.html?q=backup Hope this helps, Carlo
vincen 72 Posted October 16, 2024 Posted October 16, 2024 3 hours ago, Carlo said: From this Knowledge Base article: https://emby.media/support/articles/Corrupt-Database.html Check the section Run Integrity Check. Best bet is to make sure you have a good backup. https://emby.media/support/articles/Backup.html?q=backup Hope this helps, Carlo Yeah I had seen the article already about repair/maintenance of db but unhappy it can't be done in an automated way ! The idea would be to detect db issues at begin when it's easier and without lot less loss if you restore a backup Perhaps a plugin to develop that would check regularly dbs are ok and reports if it notices any issue(s) For backup it has been setup but as it's not doing any tests on db you can backup a corrupted db without even knowing it Side note: the bug on random play in music came back with the fresh db
Carlo 4561 Posted October 16, 2024 Posted October 16, 2024 Detection maybe, but not try to fix it. When attempting to fix a database you want exclusive access to the database with nothing else using it. @LukeIt probably wouldn't be a bad idea to have a schedule task that runs "PRAGMA integrity_check" and if it doesn't receive an "OK" back to add this to the dashboard Alerts (maybe in red). A notification would be helpful as well. 1
vincen 72 Posted October 17, 2024 Posted October 17, 2024 13 hours ago, Carlo said: Detection maybe, but not try to fix it. When attempting to fix a database you want exclusive access to the database with nothing else using it. @LukeIt probably wouldn't be a bad idea to have a schedule task that runs "PRAGMA integrity_check" and if it doesn't receive an "OK" back to add this to the dashboard Alerts (maybe in red). A notification would be helpful as well. Yeah of course and detection would be already well enough so you know something goes wrong and then can take proper steps to fix the problem before db is completely messed up Your suggestion for the "PRAGMA integrity_check" would be awesome (would need to be run against all db that Emby creates/uses) 1
