der_lala 1 Posted August 6, 2018 Posted August 6, 2018 I have sth that sound similar ; but im not sure : can not make it listen on a httpS connection. formerly this was no problem.
Luke 42242 Posted August 6, 2018 Author Posted August 6, 2018 I have sth that sound similar ; but im not sure : can not make it listen on a httpS connection. formerly this was no problem. Hi there, please attach the information requested in how to report a problem. thanks !
s7relok 1 Posted August 6, 2018 Posted August 6, 2018 (edited) Please attach the emby server log. Thanks. Will do, Can I restore it to 3.3 if I backup settings? EDIT : Here's the log : https://zerobin.lagout.org/?c922ef3359f9cf43#iEHoVwG6nPKtAumQCFw+o9P03M2GRYbjb9H4IdlxyuQ=. The error message that I have : The SSL connection could not be established, see inner exception. at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePackagesWithoutRegistrationInfo(CancellationToken cancellationToken) at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePluginUpdates(Version applicationVersion, Boolean withAutoUpdateEnabled, CancellationToken cancellationToken) at Emby.Server.Implementations.ScheduledTasks.PluginUpdateTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) Edited August 6, 2018 by s7relok
Luke 42242 Posted August 6, 2018 Author Posted August 6, 2018 Will do, Can I restore it to 3.3 if I backup settings? EDIT : Here's the log : https://zerobin.lagout.org/?c922ef3359f9cf43#iEHoVwG6nPKtAumQCFw+o9P03M2GRYbjb9H4IdlxyuQ=. The error message that I have : The SSL connection could not be established, see inner exception. at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePackagesWithoutRegistrationInfo(CancellationToken cancellationToken) at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePluginUpdates(Version applicationVersion, Boolean withAutoUpdateEnabled, CancellationToken cancellationToken) at Emby.Server.Implementations.ScheduledTasks.PluginUpdateTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) Your issue is due to a defect in the .net core runtime version 2.1. A workaround has been discovered. I will have to see if i can locate the topic in the community here, but it's something related to permissions on the certs in your local certificate store. 1
s7relok 1 Posted August 6, 2018 Posted August 6, 2018 (edited) https://emby.media/community/index.php?/topic/59531-external-ssl-connections-crashing/page-3Is that the topic you're talking about Luke? UPDATE : Followed (adapted to my machine) So, I figured out what certs were causing the problem /etc/ssl/certs$ file * | grep broken55a10908.0: broken symbolic link to UbuntuOne-ValiCert_Class_2_VA.pem598630ad.0: broken symbolic link to UbuntuOne-Go_Daddy_CA.pem/etc/ssl/certs$ sudo rm 55a10908.0 598630ad.0/etc/ssl/certs$ sudo systemctl restart emby-server From : https://emby.media/community/index.php?/topic/59531-external-ssl-connections-crashing/page-3I can connect from the outside with https.But emby still fails to connect itself with ssl EDIT 2 : It DID THE TRICK !!!I downloaded a plugin to be sure that it worked, and I'm glad to say that this is quite a beast of a workaround, thanked the guy Edited August 6, 2018 by s7relok
Luke 42242 Posted August 6, 2018 Author Posted August 6, 2018 Yes that is it. Thanks for the feedback.
kro 4 Posted September 23, 2018 Posted September 23, 2018 bad experience : I tried to upgrade from 3.3.1.0 (opensuse repository) to emby-server-deb_3.5.3.0_amd64.deb simply following the official doc for debian : https://emby.media/linux-server.html but it failed : Failed to get D-Bus connection: unknown error -1 I read something about only systemd being handled, so I guess it might be the reason for this error since I'm on Jessie and using SysV.Then I tried to downgrade : sudo apt install emby-server=3.3.1.0+68.1 Which seemed to work fine except now emby is redirecting to the new installation Wizard ! So I guess I've lost everything ? Where could I possibly get my database back ? And why would anything have been deleted (I've just been through installation commands, and haven't uninstalled nor deleted anything...)Since this installation process seems to be able to break things when we don't use systemd (it's an old server I'm a bit lazy to upgrade) could you please specify this info with a warning on the download page ?
kro 4 Posted September 24, 2018 Posted September 24, 2018 my new emby setup was creating and using /var/lib/emby-server while my data was in /var/lib/emby renaming the directory did the trick 2
s7relok 1 Posted November 17, 2018 Posted November 17, 2018 (edited) Hello, Emby not launching on debian 9 with yunohost. root@gopnik:/opt/emby-server/bin# ./emby-server Info Main: Application path: /opt/emby-server/system/EmbyServer.dll Info Main: Emby Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.9.0.7 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 2 Program data path: /var/lib/emby Application directory: /opt/emby-server/system Info App: Application version: 3.5.3.0 Info App: Loading assemblies Info App: File /var/lib/emby/plugins/Emby.Server.CinemaMode.dll has version 1.0.2.0 Info App: File /opt/emby-server/system/plugins/Emby.Server.CinemaMode.dll has version 1.0.2.0 Info App: File /var/lib/emby/plugins/IMVDb.dll has version 1.0.1.0 Info App: File /opt/emby-server/system/plugins/IMVDb.dll has version 1.0.1.0 Info App: File /var/lib/emby/plugins/OpenSubtitles.dll has version 1.0.2.0 Info App: File /opt/emby-server/system/plugins/OpenSubtitles.dll has version 1.0.2.0 Info App: Loading Emby.Server.CinemaMode, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/Emby.Server.CinemaMode.dll Info App: Loading IMVDb, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/IMVDb.dll Info App: Loading OpenSubtitles, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/OpenSubtitles.dll Info App: Loading MediaBrowser.Api, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null Info App: Loading MediaBrowser.WebDashboard, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null Info App: Loading MediaBrowser.Model, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null Info App: Loading MediaBrowser.Common, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null Info App: Loading MediaBrowser.Controller, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null Info App: Loading MediaBrowser.Providers, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Photos, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Server.Implementations, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Server.MediaEncoding, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Dlna, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null Info App: Loading MediaBrowser.LocalMetadata, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Notifications, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null Info App: Loading MediaBrowser.XbmcMetadata, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Server.Connect, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Server.Sync, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null Info SqliteUserRepository: Sqlite version: 3.24.0 Info SqliteUserRepository: Sqlite compiler options: COMPILER=gcc-6.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS5,ENABLE_JSON1,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1 Info SqliteUserRepository: Default journal_mode for /var/lib/emby/data/users.db is wal Info SqliteUserRepository: PRAGMA synchronous=1 Info AuthenticationRepository: Default journal_mode for /var/lib/emby/data/authentication.db is wal Info AuthenticationRepository: PRAGMA synchronous=1 Info ActivityRepository: Default journal_mode for /var/lib/emby/data/activitylog.db is wal Info ActivityRepository: PRAGMA synchronous=1 Info SqliteDisplayPreferencesRepository: Default journal_mode for /var/lib/emby/data/displaypreferences.db is wal Info SqliteDisplayPreferencesRepository: PRAGMA synchronous=1 Info SqliteItemRepository: Default journal_mode for /var/lib/emby/data/library.db is wal Info SqliteItemRepository: PRAGMA synchronous=1 Info HttpServer: Calling ServiceStack AppHost.Init Info HttpServer: Adding HttpListener prefix http://+:8096/ Info HttpServer: Adding HttpListener prefix https://+:8920/ Error App: Error starting Http Server *** Error Report *** Version: 3.5.3.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.9.0.7 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 2 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.Net.HttpListenerException (98): Address already in use at SocketHttpListener.Net.HttpEndPointManager.GetEPListener(ILogger logger, String host, Int32 port, HttpListener listener, Boolean secure) at SocketHttpListener.Net.HttpEndPointManager.AddPrefixInternal(ILogger logger, String p, HttpListener listener) at SocketHttpListener.Net.HttpEndPointManager.AddListener(ILogger logger, HttpListener listener) at SocketHttpListener.Net.HttpListener.Start() at Emby.Server.Implementations.ApplicationHost.StartServer() System.Net.HttpListenerException at SocketHttpListener.Net.HttpEndPointManager.GetEPListener(ILogger logger, String host, Int32 port, HttpListener listener, Boolean secure) at SocketHttpListener.Net.HttpEndPointManager.AddPrefixInternal(ILogger logger, String p, HttpListener listener) at SocketHttpListener.Net.HttpEndPointManager.AddListener(ILogger logger, HttpListener listener) at SocketHttpListener.Net.HttpListener.Start() at Emby.Server.Implementations.ApplicationHost.StartServer() Info App: Disposing CoreAppHost Info App: Disposing IsoManager Info App: Disposing TaskManager Info App: Disposing InstallationManager Info App: Disposing SqliteUserRepository Info App: Disposing SqliteDisplayPreferencesRepository Info App: Disposing SqliteItemRepository Info App: Disposing AuthenticationRepository Info App: Disposing LibraryMonitor Info App: Disposing HttpListenerHost Info HttpServer: Stopping HttpListener... Info HttpServer: HttpListener stopped Info App: Disposing ImageProcessor Info App: Disposing MediaSourceManager Info App: Disposing ProviderManager Info App: Disposing SessionManager Info App: Disposing LiveTvManager Info App: Disposing MediaEncoder Info App: Disposing ActivityRepository Info App: Disposing ActivityLogWebSocketListener Info App: Disposing SessionInfoWebSocketListener Info App: Disposing ScheduledTasksWebSocketListener Info App: Disposing SessionWebSocketListener Info Main: Releasing mutex Info Main: Mutex released Error Main: UnhandledException *** Error Report *** Version: 3.5.3.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.9.0.7 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 2 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.AggregateException: One or more errors occurred. (Address already in use) ---> System.Net.HttpListenerException: Address already in use at SocketHttpListener.Net.HttpEndPointManager.GetEPListener(ILogger logger, String host, Int32 port, HttpListener listener, Boolean secure) at SocketHttpListener.Net.HttpEndPointManager.AddPrefixInternal(ILogger logger, String p, HttpListener listener) at SocketHttpListener.Net.HttpEndPointManager.AddListener(ILogger logger, HttpListener listener) at SocketHttpListener.Net.HttpListener.Start() at Emby.Server.Implementations.ApplicationHost.StartServer() at Emby.Server.Implementations.ApplicationHost.FindParts() at EmbyServer.Program.RunApplication(ServerApplicationPaths appPaths, ILogManager logManager, IEnvironmentInfo environmentInfo, StartupOptions options) --- End of inner exception stack trace --- at System.Threading.Tasks.Task.WaitAllCore(Task[] tasks, Int32 millisecondsTimeout, CancellationToken cancellationToken) at EmbyServer.Program.Main(String[] args) at EmbyServer.Program.<Main>(String[] args) ---> (Inner Exception #0) System.Net.HttpListenerException (98): Address already in use at SocketHttpListener.Net.HttpEndPointManager.GetEPListener(ILogger logger, String host, Int32 port, HttpListener listener, Boolean secure) at SocketHttpListener.Net.HttpEndPointManager.AddPrefixInternal(ILogger logger, String p, HttpListener listener) at SocketHttpListener.Net.HttpEndPointManager.AddListener(ILogger logger, HttpListener listener) at SocketHttpListener.Net.HttpListener.Start() at Emby.Server.Implementations.ApplicationHost.StartServer() at Emby.Server.Implementations.ApplicationHost.FindParts() at EmbyServer.Program.RunApplication(ServerApplicationPaths appPaths, ILogManager logManager, IEnvironmentInfo environmentInfo, StartupOptions options)<--- System.AggregateException at System.Threading.Tasks.Task.WaitAllCore(Task[] tasks, Int32 millisecondsTimeout, CancellationToken cancellationToken) at EmbyServer.Program.Main(String[] args) at EmbyServer.Program.<Main>(String[] args) InnerException: System.Net.HttpListenerException System.Net.HttpListenerException (98): Address already in use at SocketHttpListener.Net.HttpEndPointManager.GetEPListener(ILogger logger, String host, Int32 port, HttpListener listener, Boolean secure) at SocketHttpListener.Net.HttpEndPointManager.AddPrefixInternal(ILogger logger, String p, HttpListener listener) at SocketHttpListener.Net.HttpEndPointManager.AddListener(ILogger logger, HttpListener listener) at SocketHttpListener.Net.HttpListener.Start() at Emby.Server.Implementations.ApplicationHost.StartServer() at Emby.Server.Implementations.ApplicationHost.FindParts() at EmbyServer.Program.RunApplication(ServerApplicationPaths appPaths, ILogManager logManager, IEnvironmentInfo environmentInfo, StartupOptions options) at SocketHttpListener.Net.HttpEndPointManager.GetEPListener(ILogger logger, String host, Int32 port, HttpListener listener, Boolean secure) at SocketHttpListener.Net.HttpEndPointManager.AddPrefixInternal(ILogger logger, String p, HttpListener listener) at SocketHttpListener.Net.HttpEndPointManager.AddListener(ILogger logger, HttpListener listener) at SocketHttpListener.Net.HttpListener.Start() at Emby.Server.Implementations.ApplicationHost.StartServer() at Emby.Server.Implementations.ApplicationHost.FindParts() at EmbyServer.Program.RunApplication(ServerApplicationPaths appPaths, ILogManager logManager, IEnvironmentInfo environmentInfo, StartupOptions options) UnhandledException System.AggregateException: One or more errors occurred. (Address already in use) ---> System.Net.HttpListenerException: Address already in use at SocketHttpListener.Net.HttpEndPointManager.GetEPListener(ILogger logger, String host, Int32 port, HttpListener listener, Boolean secure) at SocketHttpListener.Net.HttpEndPointManager.AddPrefixInternal(ILogger logger, String p, HttpListener listener) at SocketHttpListener.Net.HttpEndPointManager.AddListener(ILogger logger, HttpListener listener) at SocketHttpListener.Net.HttpListener.Start() at Emby.Server.Implementations.ApplicationHost.StartServer() at Emby.Server.Implementations.ApplicationHost.FindParts() at EmbyServer.Program.RunApplication(ServerApplicationPaths appPaths, ILogManager logManager, IEnvironmentInfo environmentInfo, StartupOptions options) --- End of inner exception stack trace --- at System.Threading.Tasks.Task.WaitAllCore(Task[] tasks, Int32 millisecondsTimeout, CancellationToken cancellationToken) at EmbyServer.Program.Main(String[] args) at EmbyServer.Program.<Main>(String[] args) ---> (Inner Exception #0) System.Net.HttpListenerException (98): Address already in use at SocketHttpListener.Net.HttpEndPointManager.GetEPListener(ILogger logger, String host, Int32 port, HttpListener listener, Boolean secure) at SocketHttpListener.Net.HttpEndPointManager.AddPrefixInternal(ILogger logger, String p, HttpListener listener) at SocketHttpListener.Net.HttpEndPointManager.AddListener(ILogger logger, HttpListener listener) at SocketHttpListener.Net.HttpListener.Start() at Emby.Server.Implementations.ApplicationHost.StartServer() at Emby.Server.Implementations.ApplicationHost.FindParts() at EmbyServer.Program.RunApplication(ServerApplicationPaths appPaths, ILogManager logManager, IEnvironmentInfo environmentInfo, StartupOptions options)<--- System.AggregateException at System.Threading.Tasks.Task.WaitAllCore(Task[] tasks, Int32 millisecondsTimeout, CancellationToken cancellationToken) at EmbyServer.Program.Main(String[] args) at EmbyServer.Program.<Main>(String[] args) InnerException: System.Net.HttpListenerException System.Net.HttpListenerException (98): Address already in use at SocketHttpListener.Net.HttpEndPointManager.GetEPListener(ILogger logger, String host, Int32 port, HttpListener listener, Boolean secure) at SocketHttpListener.Net.HttpEndPointManager.AddPrefixInternal(ILogger logger, String p, HttpListener listener) at SocketHttpListener.Net.HttpEndPointManager.AddListener(ILogger logger, HttpListener listener) at SocketHttpListener.Net.HttpListener.Start() at Emby.Server.Implementations.ApplicationHost.StartServer() at Emby.Server.Implementations.ApplicationHost.FindParts() at EmbyServer.Program.RunApplication(ServerApplicationPaths appPaths, ILogManager logManager, IEnvironmentInfo environmentInfo, StartupOptions options) at SocketHttpListener.Net.HttpEndPointManager.GetEPListener(ILogger logger, String host, Int32 port, HttpListener listener, Boolean secure) at SocketHttpListener.Net.HttpEndPointManager.AddPrefixInternal(ILogger logger, String p, HttpListener listener) at SocketHttpListener.Net.HttpEndPointManager.AddListener(ILogger logger, HttpListener listener) at SocketHttpListener.Net.HttpListener.Start() at Emby.Server.Implementations.ApplicationHost.StartServer() at Emby.Server.Implementations.ApplicationHost.FindParts() at EmbyServer.Program.RunApplication(ServerApplicationPaths appPaths, ILogManager logManager, IEnvironmentInfo environmentInfo, StartupOptions options) Edit : Found the problem, edited /var/lib/emby/config/system.xml and changed the ports, running now Edited November 17, 2018 by s7relok 1
Luke 42242 Posted November 17, 2018 Author Posted November 17, 2018 Thanks for following up, glad you resolved it.
Luke 42242 Posted November 19, 2018 Author Posted November 19, 2018 Emby Server for Arm64 is now available ! https://emby.media/community/index.php?/topic/65476-emby-server-for-arm64-now-available/ Thanks.
Luke 42242 Posted January 4, 2019 Author Posted January 4, 2019 Not at this time, but it's something we'd like to add in the future. Thanks.
der_lala 1 Posted January 10, 2019 Posted January 10, 2019 Hi there. How do i debug convert function? Whether it s an access right or anything else. I want to create a smaller Copy of a really big movie that has trouble to start playing. Conversion finishes as the gui says but there is no additional file next to the original. Regards Christoph Gesendet von meinem SM-A520F mit Tapatalk
Luke 42242 Posted January 10, 2019 Author Posted January 10, 2019 Hi there. How do i debug convert function? Whether it s an access right or anything else. I want to create a smaller Copy of a really big movie that has trouble to start playing. Conversion finishes as the gui says but there is no additional file next to the original. Regards Christoph Gesendet von meinem SM-A520F mit Tapatalk Best thing to do is see how to report a problem. thanks !
der_lala 1 Posted January 11, 2019 Posted January 11, 2019 ok, got it from /var/lib/emby/logs/embyserver.txt : System.UnauthorizedAccessException: Access to the path '/media/.../Movies/MovieA/MovieA - tv.mp4' is denied. ---> System.IO.IOException: Permission denied i ll try to figure permissions out
Luke 42242 Posted January 11, 2019 Author Posted January 11, 2019 ok, got it from /var/lib/emby/logs/embyserver.txt : System.UnauthorizedAccessException: Access to the path '/media/.../Movies/MovieA/MovieA - tv.mp4' is denied. ---> System.IO.IOException: Permission denied i ll try to figure permissions out Yea sounds like after the conversion is complete, there is no write access to move the output to it's destination folder.
der_lala 1 Posted February 17, 2019 Posted February 17, 2019 Yea, that was is. Shame on me for not seeing this.I guess i need to see the faq for linux rights again.Or what did u guys set @@mastrmind11? Chmod - R 777 and chown emby? Works, but obviously not best solution, right?Gesendet von meinem SM-A520F mit Tapatalk
mastrmind11 722 Posted February 17, 2019 Posted February 17, 2019 Yea, that was is. Shame on me for not seeing this. I guess i need to see the faq for linux rights again. Or what did u guys set @@mastrmind11? Chmod - R 777 and chown emby? Works, but obviously not best solution, right? Gesendet von meinem SM-A520F mit Tapatalk just make sure that whatever app is trying to move stuff around has w access to the drive/folder. i use a separate user for all my stuff, but they all belong to the same "media" group which has r/w. that'd be what i suggest, as well as the recommended set up in the linux world.
Cyber_ballz 0 Posted May 12, 2019 Posted May 12, 2019 Ok. I'm fascinated. Debian running emby, connected to internet, ps3 connected on same network, connected to internet, sees emby, sees shares, and plays. I setup a cross over cable, because wifi is garbage compared to gigabit, and the emby box can see the ps3, ping the ps3, but seems the ps3 cannot find the emby server... Only thing changed, internet connection removed . Does emby require one?
Luke 42242 Posted May 12, 2019 Author Posted May 12, 2019 Hi, no an internet connection is not required.
Cyber_ballz 0 Posted May 12, 2019 Posted May 12, 2019 Well, it doesn't work unless there's a route to a gateway. I switched back and it works. Kinda. Im having difficulty playing 50gb isos over wifi..
Luke 42242 Posted May 13, 2019 Author Posted May 13, 2019 Well, it doesn't work unless there's a route to a gateway. I switched back and it works. Kinda. Im having difficulty playing 50gb isos over wifi.. Correct, you will need that.
Cyber_ballz 0 Posted May 13, 2019 Posted May 13, 2019 Why do I need a gateway? You confirmed internet isn't required? I'm confused.
Luke 42242 Posted May 13, 2019 Author Posted May 13, 2019 Why do I need a gateway? You confirmed internet isn't required? I'm confused. I should correct myself. You need a local network setup. I am not sure if using a crossover cable will work, it's not something we've tested with our dlna features. Thanks.
