jasonwilliams 37 Posted February 4, 2015 Posted February 4, 2015 Hello, I'm using NextPVR with MB3 and a Hauppauge HDPVR. I got everything working, but I notice two issues and I'm not sure if the problems are with my setup or if these are things still to be ironed out. First is a very minor one. It takes a while for the HDPVR to fire up and start streaming and the various MB clients seem to time out. When I click "Retry" they start streaming no problem. Is there a way to increase this timeout? It happens on the Windows 8.1 client. Second, I am having problems with the recording scheduler. I go through the process to setup a series recording and sometimes it works, sometimes not. I think I have it narrowed down to when you set it to record anytime on the same channel. Just want to reach out and see if anybody else is having these type of issues. Thanks, Jason
Sven 136 Posted February 5, 2015 Posted February 5, 2015 For the first question, no idea... For the second question. It doesn't do any recording at all then? Or he records only 1 show... When you browse to the nextpvr client. You also don't see any recording? Can you also post your logs? See my signature for a how-to
Luke 42239 Posted January 5, 2018 Posted January 5, 2018 @@jasonwilliams @@Sven We now have native Hauppauge support available for testing in the Emby Server beta: https://emby.media/community/index.php?/topic/54560-32609-hauppauge-support/?hl=hauppauge Thanks.
Sven 136 Posted January 15, 2018 Posted January 15, 2018 @@Luke I can't test it. The Hauppauge is installed in a different machine. Emby is installed on my Synology..
emveepee 133 Posted January 15, 2018 Posted January 15, 2018 @@jasonwilliams @@Sven We now have native Hauppauge support available for testing in the Emby Server beta: https://emby.media/community/index.php?/topic/54560-32609-hauppauge-support/?hl=hauppauge Thanks. The OP said he uses an HDPVR do you support it and allow control of blasters? Martin
Luke 42239 Posted January 15, 2018 Posted January 15, 2018 I'm guessing the blasters won't work but i'd have to review the hauppauge sdk to confirm.
emveepee 133 Posted January 18, 2018 Posted January 18, 2018 (edited) I'm guessing the blasters won't work but i'd have to review the hauppauge sdk to confirm. That would basically make the HDPVR useless since it doesn't have a tuner built in. Martin Edited January 18, 2018 by emveepee
SHSPVR 125 Posted January 19, 2018 Posted January 19, 2018 That would basically make the HDPVR useless since it doesn't have a tuner built in. Martin It not use less he just have make use of the blast.exe I think How ever I should point out you only be able to use one IR Blaster unless it the HVR-22xx model
emveepee 133 Posted January 22, 2018 Posted January 22, 2018 It not use less he just have make use of the blast.exe I think How ever I should point out you only be able to use one IR Blaster unless it the HVR-22xx model I meant useless without support for external tuning of some form. Also there are alternatives to Hauppauge too, IP tuning, firewire tuning (which i use) and blaster software that don't have Hauppauge limitations. Martin
SHSPVR 125 Posted January 22, 2018 Posted January 22, 2018 I meant useless without support for external tuning of some form. Also there are alternatives to Hauppauge too, IP tuning, firewire tuning (which i use) and blaster software that don't have Hauppauge limitations. Martin Ok Yes I know all about IP tuning that only apply the DirecTV box any way as far I know of and as for Firewire tuning it RIP with Windows 64 bit OS any way
