DVBLink-TVMosaic Live TV Plugin
I can help. There is no such transcoder raw_http. If you need a raw stream (e.g. without any transcoding) the leave transcoder parameter out:
http://192.168.0.252:9271/stream/direct?client=e758a27e91ca4fbcb08f08f7a9299490&channel=1:12480000:133:33:51
It will also work with DVBLink.
I'm pretty sure, that with DVBLink Emby has transcoded the TV Stream, if necessary (for external access).
(That was a big advantage at that time when I compared Emby and Plex)
Will this be possible with new TV-Mosaic Plugin too?
While I'm about to ask:
@t.andre
Have you seen this thread?
https://emby.media/community/index.php?/topic/55528-channel-order/
Perhaps it could be possible to choose the favourites lists that are made within TV-Mosaic?
As I wrote in this thead:
I have channels from my DBV-S2 TV Tuner (DVBLink / Synology) and most of them identically from IPTV List as an alternative.
So most channels are shown twice (side by side) in TVGuide (Currently running) because all availlable channels are displayed alphabetically.
So I made a new favourites list "SAT" with only the DVB-S2 channels.
TV-Mosaic has created a new list automatically only for IPTV channels, but not for DVB-S2 channels, there is only a list "TV" with all TV channels which must be used by the Emby TV plugin (I think).
If TV-Mosaic plugin could read out the availlable favourites lists and you could deselect some, this would be great.
@@Luke
Another question:
In view "Currently running" I only see a picture of the show (I use xmltv as EPG source from epg.koditvepg.com) with name of the show and time.
I miss the channel name and/or channel icon and perhaps the channel number too.
Is it possible to add these infos?
Thanks.
dvblogic
As far as I can see Emby TVMosaic plugin starts ffmpeg to do that.
If transcoded stream is required from TVMosaic itself, it ca be done by supplying properly formatted transcoder parameters as described here:
https://forum.tv-mosaic.com/viewtopic.php?f=12&t=246
t.andre
The transcode option is included in the plugin, but for now I have disabled because emby can already transcode
t.andre
I have updated the plugin to correct the stream url
Yes, that's OK, because my Synology NAS on which TV-Mosaic (and DVBLink before) is running hasn't enough power to transcode 1080p.
My HTPC on which Emby is running (together with Kodi) has more power and can transcode 1080p and I was surpised at the time I compared Emby and Plex, that Emby could transcode TV streams too (which plex didi not, only media files).
Sorry, but still no luck, not via https (external access) and not via http (internal access).
Here the ffmpeg log:
2018-05-18 07:41:32.136
Application version: 3.4.1.0
http://localhost:18096/emby/videos/18a39947bae2f14ff6b58c7b39151952/live.m3u8?DeviceId=47f0c60cf1f7e66605f1c9fb97b5d6815906cd51&MediaSourceId=346b7dba743449b0bf522ab2084d4108&VideoCodec=h264&AudioCodec=mp3,aac&AudioStreamIndex=-1&VideoBitrate=139808000&AudioBitrate=192000&PlaySessionId=ec9eaba00bc4421d8eb56ad0f6fe4efa&api_key=fdd74583c16e426eb6019d8ba29422d5&LiveStreamId=a17c75760a04e99b68cf766e11316e1c_ce72e8c20d5b643260b2ca5ef67f5aa3_346b7dba743449b0bf522ab2084d4108&TranscodingMaxAudioChannels=2&RequireAvc=true&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=51&h264-deinterlace=true&TranscodeReasons=ContainerNotSupported,VideoCodecNotSupported,AudioCodecNotSupported
{"Protocol":"Http","Id":"346b7dba743449b0bf522ab2084d4108","Path":"http://192.168.0.252:9271/stream/direct?client=346b7dba743449b0bf522ab2084d4108&channel=1:12148000:133:7:65","Type":"Default","Container":"mpegts","Name":"NATIVE","IsRemote":true,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":true,"RequiresOpening":true,"RequiresClosing":true,"LiveStreamId":"a17c75760a04e99b68cf766e11316e1c_ce72e8c20d5b643260b2ca5ef67f5aa3_346b7dba743449b0bf522ab2084d4108","BufferMs":0,"RequiresLooping":false,"SupportsProbing":true,"MediaStreams":[{"Codec":"mpeg2video","TimeBase":"1/90000","CodecTimeBase":"1/25","VideoRange":"SDR","DisplayTitle":"480IMPEG2VIDEO","IsInterlaced":true,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":576,"Width":544,"AverageFrameRate":25,"RealFrameRate":25,"Profile":"Main","Type":"Video","AspectRatio":"16:9","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":8,"IsAnamorphic":false},{"Codec":"mp2","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"MP2 stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"Formats":[],"Bitrate":192000,"RequiredHttpHeaders":{},"AnalyzeDurationMs":3000}
User policy for Siutsch: EnablePlaybackRemuxing: False EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True
C:\emby.windows\system\ffmpeg.exe -analyzeduration 3000000 -i "http://192.168.0.252:9271/stream/direct?client=346b7dba743449b0bf522ab2084d4108&channel=1:12148000:133:7:65"-map_metadata -1 -map_chapters -1 -threads 0 -sn -codec:v:0 libx264 -pix_fmt yuv420p -preset veryfast -crf 20 -maxrate 139808000 -bufsize 279616000 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:gte(t,n_forced*3)" -vf "yadif=1:-1:0" -flags -global_header -vsync cfr -codec:a:0 libmp3lame -ac 2 -ab 192000  -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3  -individual_header_trailer 0 -segment_format mpegts -segment_list_entry_prefix "hls/03cd372f64c6d920914b5bb0f156a301/" -segment_list_type m3u8 -segment_start_number 0 -segment_list "C:\emby.windows\transcoding-temp\03cd372f64c6d920914b5bb0f156a301.m3u8" -y "C:\emby.windows\transcoding-temp\03cd372f64c6d920914b5bb0f156a301%d.ts"
ffmpeg version 3.4.2 Copyright © 2000-2018 the FFmpeg developers
  built with gcc 7.3.0 (GCC)
  configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-bzlib --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libmfx --enable-cuda --enable-cuvid --enable-d3d11va --enable-nvenc --enable-dxva2 --enable-avisynth
  libavutil      55. 78.100 / 55. 78.100
  libavcodec     57.107.100 / 57.107.100
  libavformat    57. 83.100 / 57. 83.100
  libavdevice    57. 10.100 / 57. 10.100
  libavfilter     6.107.100 /  6.107.100
  libswscale      4.  8.100 /  4.  8.100
  libswresample   2.  9.100 /  2.  9.100
  libpostproc    54.  7.100 / 54.  7.100
http://192.168.0.252:9271/stream/direct?client=346b7dba743449b0bf522ab2084d4108&channel=1:12148000:133:7:65:Unknown error
And here some part of the server log:
2018-05-18 07:41:34.109 Info HttpServer: HTTP POST http://localhost:18096/emby/Sessions/Capabilities/Full. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36
2018-05-18 07:41:34.113 Info HttpServer: WS ws://localhost:18096/embywebsocket?api_key=fdd74583c16e426eb6019d8ba29422d5&deviceId=47f0c60cf1f7e66605f1c9fb97b5d6815906cd51. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36
2018-05-18 07:41:34.113 Info HttpServer: HTTP Response 204 to ::1. Time: 4ms. http://localhost:18096/emby/Sessions/Capabilities/Full
2018-05-18 07:41:34.113 Info HttpServer: HTTP GET http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36
2018-05-18 07:41:34.116 Info HttpServer: HTTP GET http://localhost:18096/emby/DisplayPreferences/usersettings?userId=aadcf3ef163a47388c810ff7b74b95ae&client=emby. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36
2018-05-18 07:41:34.116 Info HttpServer: HTTP Response 200 to ::1. Time: 3ms. http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae
2018-05-18 07:41:34.117 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:18096/emby/DisplayPreferences/usersettings?userId=aadcf3ef163a47388c810ff7b74b95ae&client=emby
2018-05-18 07:41:34.176 Info HttpServer: HTTP GET http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36
2018-05-18 07:41:34.180 Info HttpServer: HTTP GET http://localhost:18096/web/bower_components/emby-webcomponents/themes/logowhite.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36
2018-05-18 07:41:34.183 Info HttpServer: HTTP Response 304 to ::1. Time: 3ms. http://localhost:18096/web/bower_components/emby-webcomponents/themes/logowhite.png
2018-05-18 07:41:34.188 Info ImageProcessor: Getting image size for item CollectionFolder C:\emby.windows\root\default\Music_Full Album\poster.jpg
2018-05-18 07:41:34.192 Info HttpServer: HTTP Response 200 to ::1. Time: 16ms. http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Views
2018-05-18 07:41:34.256 Info HttpServer: HTTP GET http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36
2018-05-18 07:41:34.264 Info ImageProcessor: Getting image size for item CollectionFolder C:\emby.windows\root\default\Music_Full Album\poster.jpg
2018-05-18 07:41:34.267 Info HttpServer: HTTP Response 200 to ::1. Time: 11ms. http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Views
2018-05-18 07:41:34.279 Info HttpServer: HTTP GET http://localhost:18096/emby/LiveTv/Programs/Recommended?userId=aadcf3ef163a47388c810ff7b74b95ae&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36
2018-05-18 07:41:34.312 Info App: [DVBLink] - Timers from cache: 0
2018-05-18 07:41:34.312 Info HttpServer: HTTP Response 200 to ::1. Time: 33ms. http://localhost:18096/emby/LiveTv/Programs/Recommended?userId=aadcf3ef163a47388c810ff7b74b95ae&IsAiring=true&limit=1&ImageTypeLimit=1&EnableImageTypes=Primary%2CThumb%2CBackdrop&EnableTotalRecordCount=false&Fields=ChannelInfo%2CPrimaryImageAspectRatio
2018-05-18 07:41:34.351 Info HttpServer: HTTP GET http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=7a2175bccb1f1a94152cbd2b2bae8f6d. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36
2018-05-18 07:41:34.354 Info HttpServer: HTTP GET http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=d5e9ee27bc530473713097467e747964. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36
2018-05-18 07:41:34.359 Info HttpServer: HTTP GET http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=6c12298efc4a8aa41c3222867a71796a. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36
2018-05-18 07:41:34.359 Info HttpServer: HTTP GET http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=e402d6855923ab41d25a0680497b9f63. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36
2018-05-18 07:41:34.360 Info HttpServer: HTTP GET http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=43cfe12fe7d9d8d21251e0964e0232e2. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36
2018-05-18 07:41:34.361 Info HttpServer: HTTP GET http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=37a620acf0f3cc400be154be9627e099. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36
2018-05-18 07:41:34.544 Info HttpServer: HTTP Response 200 to ::1. Time: 185ms. http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=6c12298efc4a8aa41c3222867a71796a
2018-05-18 07:41:34.546 Info HttpServer: HTTP GET http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=ec85aa16f44cff5e10cdfd6f6521c662. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36
2018-05-18 07:41:34.554 Info HttpServer: HTTP Response 200 to ::1. Time: 195ms. http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=e402d6855923ab41d25a0680497b9f63
2018-05-18 07:41:34.555 Info HttpServer: HTTP GET http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=30&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=ec545c0e94e20535fbb4ec714656a7ab. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36
2018-05-18 07:41:34.583 Info HttpServer: HTTP Response 200 to ::1. Time: 224ms. http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=37a620acf0f3cc400be154be9627e099
2018-05-18 07:41:34.585 Info HttpServer: HTTP GET http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=30&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=4a46b53cf0ca6846142e6876bfe9593c. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36
2018-05-18 07:41:34.752 Info HttpServer: HTTP Response 200 to ::1. Time: 392ms. http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=43cfe12fe7d9d8d21251e0964e0232e2
2018-05-18 07:41:34.754 Info HttpServer: HTTP GET http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=16795e3accb36058bd2737dc153fc696. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36
2018-05-18 07:41:34.874 Info HttpServer: HTTP Response 200 to ::1. Time: 288ms. http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=30&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=4a46b53cf0ca6846142e6876bfe9593c
2018-05-18 07:41:34.876 Info HttpServer: HTTP GET http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=9f32ac632db4e229a70ca73977d93d16. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36
2018-05-18 07:41:34.880 Info HttpServer: HTTP Response 200 to ::1. Time: 3ms. http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=9f32ac632db4e229a70ca73977d93d16
2018-05-18 07:41:34.881 Info HttpServer: HTTP GET http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=28b5d5b8bef4bd1f1914503b5c11ac91. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36
2018-05-18 07:41:35.644 Info HttpServer: HTTP Response 200 to ::1. Time: 1098ms (slow). http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=ec85aa16f44cff5e10cdfd6f6521c662
2018-05-18 07:41:35.646 Info HttpServer: HTTP GET http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=79a2726d3c50e769a8af1e4184e4fccf. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36
2018-05-18 07:41:35.647 Info HttpServer: HTTP Response 200 to ::1. Time: 1293ms (slow). http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=d5e9ee27bc530473713097467e747964
2018-05-18 07:41:35.648 Info HttpServer: HTTP GET http://localhost:18096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=aadcf3ef163a47388c810ff7b74b95ae&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36
2018-05-18 07:41:35.735 Info HttpServer: HTTP Response 200 to ::1. Time: 1383ms (slow). http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=7a2175bccb1f1a94152cbd2b2bae8f6d
2018-05-18 07:41:35.736 Info HttpServer: HTTP GET http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36
2018-05-18 07:41:36.101 Info HttpServer: HTTP Response 200 to ::1. Time: 1347ms (slow). http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=16795e3accb36058bd2737dc153fc696
2018-05-18 07:41:36.108 Info HttpServer: HTTP Response 200 to ::1. Time: 1227ms (slow). http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=28b5d5b8bef4bd1f1914503b5c11ac91
2018-05-18 07:41:36.134 Info HttpServer: HTTP Response 200 to ::1. Time: 488ms. http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=79a2726d3c50e769a8af1e4184e4fccf
2018-05-18 07:41:36.136 Info HttpServer: HTTP Response 200 to ::1. Time: 400ms. http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video
2018-05-18 07:41:36.173 Info HttpServer: HTTP Response 200 to ::1. Time: 525ms. http://localhost:18096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio%2CSeriesInfo%2CDateCreated%2CBasicSyncInfo&UserId=aadcf3ef163a47388c810ff7b74b95ae&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&EnableTotalRecordCount=false
2018-05-18 07:41:36.194 Info HttpServer: HTTP Response 200 to ::1. Time: 1639ms (slow). http://localhost:18096/emby/Users/aadcf3ef163a47388c810ff7b74b95ae/Items/Latest?Limit=30&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=ec545c0e94e20535fbb4ec714656a7ab
2018-05-18 07:41:37.310 Info App: C:\emby.windows\system\ffmpeg.exe -analyzeduration 3000000 -i "http://192.168.0.252:9271/stream/direct?client=346b7dba743449b0bf522ab2084d4108&channel=1:12148000:133:7:65"-map_metadata -1 -map_chapters -1 -threads 0 -sn -codec:v:0 libx264 -pix_fmt yuv420p -preset veryfast -crf 20 -maxrate 139808000 -bufsize 279616000 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:gte(t,n_forced*3)" -vf "yadif=1:-1:0" -flags -global_header -vsync cfr -codec:a:0 libmp3lame -ac 2 -ab 192000  -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3  -individual_header_trailer 0 -segment_format mpegts -segment_list_entry_prefix "hls/03cd372f64c6d920914b5bb0f156a301/" -segment_list_type m3u8 -segment_start_number 0 -segment_list "C:\emby.windows\transcoding-temp\03cd372f64c6d920914b5bb0f156a301.m3u8" -y "C:\emby.windows\transcoding-temp\03cd372f64c6d920914b5bb0f156a301%d.ts"
2018-05-18 07:41:42.539 Error HttpServer: Error processing request
    *** Error Report ***
    Version: 3.4.1.0
    Command line: C:\emby.windows\system\EmbyServer.dll C:\emby.windows\system\EmbyServer.dll -noautorunwebapp
    Operating system: Microsoft Windows NT 6.2.9200.0
    64-Bit OS: True
    64-Bit Process: True
    User Interactive: True
    Processor count: 4
    Program data path: C:\emby.windows
    Application directory: C:\emby.windows\system
    System.Exception: Error starting ffmpeg
       at Emby.Server.MediaEncoding.Api.BaseStreamingService.<StartFfMpeg>d__76.MoveNext()
    --- End of stack trace from previous location where exception was thrown ---
       at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
       at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
       at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService.<ProcessRequest>d__5.MoveNext()
       at Emby.Server.Implementations.Services.ServiceExecGeneral.<GetTaskResult>d__3.MoveNext()
       at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__13.MoveNext()
       at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__70.MoveNext()
    System.Exception
2018-05-18 07:41:42.539 Info HttpServer: HTTP Response 500 to ::1. Time: 10407ms (slow). http://localhost:18096/emby/videos/18a39947bae2f14ff6b58c7b39151952/live.m3u8?DeviceId=47f0c60cf1f7e66605f1c9fb97b5d6815906cd51&MediaSourceId=346b7dba743449b0bf522ab2084d4108&VideoCodec=h264&AudioCodec=mp3,aac&AudioStreamIndex=-1&VideoBitrate=139808000&AudioBitrate=192000&PlaySessionId=ec9eaba00bc4421d8eb56ad0f6fe4efa&LiveStreamId=a17c75760a04e99b68cf766e11316e1c_ce72e8c20d5b643260b2ca5ef67f5aa3_346b7dba743449b0bf522ab2084d4108&TranscodingMaxAudioChannels=2&RequireAvc=true&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=51&h264-deinterlace=true&TranscodeReasons=ContainerNotSupported,VideoCodecNotSupported,AudioCodecNotSupported
I hope you can find the problem.
Thanks for making this plugin! :)
Still that same unknown error coming from ffmpeg.
Between the stream passed to -i and the -map_data parameter there is no space. Can it matter?
In everycase I would try to run that command from a shell to see the behaviour.
i lost all my TV channels Logos with 1.6.3.1.... (don´t work with dvblink and tvmosaic)
with 1.5.3.0 they show with DVBlink…
i use the "emby logo mapping"
Edited by Schimi
t.andre
Can you give the log please
Envoyé de mon BLA-L29 en utilisant Tapatalk
t.andre
Hi,
A new version ha been published to correct the issue.
Can you try to see if it works ?
Thanks
seems to work :-)
With 1.6.3.2 still no streaming from Web-Interface:
2018-05-19 20:22:38.928
http://192.168.0.253:18096/emby/videos/414ce92d6c4fa3b44b90bfaf8f53e6e6/live.m3u8?DeviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NDsgcnY6NjAuMCkgR2Vja28vMjAxMDAxMDEgRmlyZWZveC82MC4wfDE1MjY2NzA1NDEzNzU1&MediaSourceId=636871b8d1c64c7e9c6a415e0f5c3973&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=-1&VideoBitrate=139808000&AudioBitrate=192000&PlaySessionId=60c7345ddfd641e885f578a9bb5fbd4b&api_key=6446699734bf452d93835162701ea35c&LiveStreamId=a17c75760a04e99b68cf766e11316e1c_ce72e8c20d5b643260b2ca5ef67f5aa3_636871b8d1c64c7e9c6a415e0f5c3973&TranscodingMaxAudioChannels=2&RequireAvc=true&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&h264-deinterlace=true&TranscodeReasons=ContainerNotSupported,VideoCodecNotSupported,AudioCodecNotSupported
{"Protocol":"Http","Id":"636871b8d1c64c7e9c6a415e0f5c3973","Path":"http://192.168.0.252:9271/stream/direct?client=636871b8d1c64c7e9c6a415e0f5c3973&channel=1:12545000:1:1107:17505","Type":"Default","Container":"mpegts","Name":"NATIVE","IsRemote":true,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":true,"RequiresOpening":true,"RequiresClosing":true,"LiveStreamId":"a17c75760a04e99b68cf766e11316e1c_ce72e8c20d5b643260b2ca5ef67f5aa3_636871b8d1c64c7e9c6a415e0f5c3973","BufferMs":0,"RequiresLooping":false,"SupportsProbing":true,"MediaStreams":[{"Codec":"mpeg2video","TimeBase":"1/90000","CodecTimeBase":"1/25","VideoRange":"SDR","DisplayTitle":"480IMPEG2VIDEO","IsInterlaced":true,"BitRate":2000000,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":576,"Width":720,"AverageFrameRate":25,"RealFrameRate":25,"Profile":"Main","Type":"Video","AspectRatio":"16:9","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":8,"IsAnamorphic":false},{"Codec":"mp2","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"MP2 stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"Formats":[],"Bitrate":2192000,"RequiredHttpHeaders":{},"AnalyzeDurationMs":3000}
C:\emby.windows\system\ffmpeg.exe -analyzeduration 3000000 -i "http://192.168.0.252:9271/stream/direct?client=636871b8d1c64c7e9c6a415e0f5c3973&channel=1:12545000:1:1107:17505"-map_metadata -1 -map_chapters -1 -threads 0 -sn -codec:v:0 libx264 -pix_fmt yuv420p -preset veryfast -crf 20 -maxrate 5000000 -bufsize 10000000 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:gte(t,n_forced*3)" -vf "yadif=1:-1:0,scale=trunc(min(max(iw\,ih*dar)\,1920)/2)*2:trunc(ow/dar/2)*2" -flags -global_header -vsync cfr -codec:a:0 aac -strict experimental -ac 2 -ab 192000  -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3  -individual_header_trailer 0 -segment_format mpegts -segment_list_entry_prefix "hls/fd932f5583424fe13f17b01f84d95594/" -segment_list_type m3u8 -segment_start_number 0 -segment_list "C:\emby.windows\transcoding-temp\fd932f5583424fe13f17b01f84d95594.m3u8" -y "C:\emby.windows\transcoding-temp\fd932f5583424fe13f17b01f84d95594%d.ts"
http://192.168.0.252:9271/stream/direct?client=636871b8d1c64c7e9c6a415e0f5c3973&channel=1:12545000:1:1107:17505:Unknown error
Can't you test that by yourself?
Don't you use DVBLink or TV-Mosaic?
Or asked differently:
Is TV stream working in your system?
I wonder, why this works if used from Android device.
Edited by Siutsch
t.andre
I use both and it works
Do you have transcoding enable in Emby ?
I yes try to disable
Edited by t.andre
t.andre
2018-05-19 20:25:55.453
Application version: 3.4.1.6
http://192.168.1.4:8096/emby/videos/113256d4def0065f0e88796aeb191cf1/live.m3u8?DeviceId=a436912a3d13fa54b237358be577f5a3cb96d691&MediaSourceId=b21fb69f3ea240e5bf20ad2fccfd4203&VideoCodec=h264&AudioCodec=mp3,aac&AudioStreamIndex=-1&VideoBitrate=139808000&AudioBitrate=192000&PlaySessionId=a4388e19796749cd919bf8e1201e5935&api_key=923dc87668d74c7c9cbf2795f96ff278&LiveStreamId=a17c75760a04e99b68cf766e11316e1c_ce72e8c20d5b643260b2ca5ef67f5aa3_b21fb69f3ea240e5bf20ad2fccfd4203&TranscodingMaxAudioChannels=2&RequireAvc=true&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=51&h264-deinterlace=true&TranscodeReasons=ContainerNotSupported,VideoCodecNotSupported,AudioCodecNotSupported
{"Protocol":"Http","Id":"b21fb69f3ea240e5bf20ad2fccfd4203","Path":"http://192.168.1.2:8101/dvblink/direct?client=b21fb69f3ea240e5bf20ad2fccfd4203&channel=12360000","Type":"Default","Container":"mpegts","Name":"NATIVE","IsRemote":true,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":true,"RequiresOpening":true,"RequiresClosing":true,"LiveStreamId":"a17c75760a04e99b68cf766e11316e1c_ce72e8c20d5b643260b2ca5ef67f5aa3_b21fb69f3ea240e5bf20ad2fccfd4203","BufferMs":0,"RequiresLooping":false,"SupportsProbing":true,"MediaStreams":[{"Codec":"h264","ColorTransfer":"bt709","ColorPrimaries":"bt709","ColorSpace":"bt709","TimeBase":"1/90000","CodecTimeBase":"1/100","VideoRange":"SDR","DisplayTitle":"720PH264","NalLengthSize":"0","IsInterlaced":false,"BitRate":8000000,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":720,"Width":1280,"AverageFrameRate":50,"RealFrameRate":50,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":40,"IsAnamorphic":false},{"Codec":"mp2","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"MP2 stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"Formats":[],"Bitrate":8192000,"RequiredHttpHeaders":{},"AnalyzeDurationMs":3000}
User policy for Tavares: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True
C:\Users\HomeMedia\AppData\Roaming\Emby-Server\system\ffmpeg.exe -analyzeduration 3000000 -f mpegts -i "http://192.168.1.2:8101/dvblink/direct?client=b21fb69f3ea240e5bf20ad2fccfd4203&channel=12360000"-map_metadata -1 -map_chapters -1 -threads 0 -sn -codec:v:0 copy -flags -global_header -vsync cfr -codec:a:0 libmp3lame -ac 2 -ab 192000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_entry_prefix "hls/380d9476e7f1926bc8c55676fb3db499/" -segment_list_type m3u8 -segment_start_number 0 -segment_list "C:\Users\HomeMedia\AppData\Roaming\Emby-Server\transcoding-temp\380d9476e7f1926bc8c55676fb3db499.m3u8" -y "C:\Users\HomeMedia\AppData\Roaming\Emby-Server\transcoding-temp\380d9476e7f1926bc8c55676fb3db499%d.ts"
ffmpeg version 4.0 Copyright © 2000-2018 the FFmpeg developers
configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-bzlib --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libmfx --enable-amf --enable-ffnvcodec --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth
libavutil 56. 14.100 / 56. 14.100
libavcodec 58. 18.100 / 58. 18.100
libavformat 58. 12.100 / 58. 12.100
libavdevice 58. 3.100 / 58. 3.100
libavfilter 7. 16.100 / 7. 16.100
libswscale 5. 1.100 / 5. 1.100
libswresample 3. 1.100 / 3. 1.100
libpostproc 55. 1.100 / 55. 1.100
[h264 @ 000001a252483500] SPS unavailable in decode_picture_timing
[h264 @ 000001a252483500] non-existing PPS 0 referenced
[h264 @ 000001a252483500] decode_slice_header error
[h264 @ 000001a252483500] no frame!
Input #0, mpegts, from 'http://192.168.1.2:8101/dvblink/direct?client=b21fb69f3ea240e5bf20ad2fccfd4203&channel=12360000':
Duration: N/A, start: 10969.594233, bitrate: N/A
Program 1236
Metadata:
service_name : ?
service_provider: ?
Stream #0:0[0xd0]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, progressive), 1280x720 [sAR 1:1 DAR 16:9], 50 fps, 50 tbr, 90k tbn, 100 tbc
Stream #0:1[0xd1](fra): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, fltp, 192 kb/s (clean effects)
Stream #0:2[0xd2](eng): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, fltp, 192 kb/s (clean effects)
Stream #0:3[0xdb](fra): Audio: ac3 ([6][0][0][0] / 0x0006), 48000 Hz, 5.1(side), fltp, 448 kb/s (clean effects)
Stream #0:4[0xee](fra,fra): Subtitle: dvb_teletext ([6][0][0][0] / 0x0006)
Stream mapping:
Stream #0:0 -> #0:0 (copy)
Stream #0:3 -> #0:1 (ac3 (native) -> mp3 (libmp3lame))
Press [q] to stop, [?] for help
[segment @ 000001a252f700c0] Opening 'C:\Users\HomeMedia\AppData\Roaming\Emby-Server\transcoding-temp\380d9476e7f1926bc8c55676fb3db4990.ts' for writing
Output #0, segment, to 'C:\Users\HomeMedia\AppData\Roaming\Emby-Server\transcoding-temp\380d9476e7f1926bc8c55676fb3db499%d.ts':
Metadata:
encoder : Lavf58.12.100
Stream #0:0: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, progressive), 1280x720 [sAR 1:1 DAR 16:9], q=2-31, 50 fps, 50 tbr, 90k tbn, 50 tbc
Stream #0:1: Audio: mp3 (libmp3lame), 48000 Hz, stereo, fltp, 192 kb/s (clean effects)
Metadata:
encoder : Lavc58.18.100 libmp3lame
[segment @ 000001a252f700c0] Opening 'C:\Users\HomeMedia\AppData\Roaming\Emby-Server\transcoding-temp\380d9476e7f1926bc8c55676fb3db499.m3u8.tmp' for writing
[segment @ 000001a252f700c0] Opening 'C:\Users\HomeMedia\AppData\Roaming\Emby-Server\transcoding-temp\380d9476e7f1926bc8c55676fb3db4991.ts' for writing
frame= 167 fps=0.0 q=-1.0 size=N/A time=00:00:04.45 bitrate=N/A speed=8.39x
frame= 191 fps=177 q=-1.0 size=N/A time=00:00:04.93 bitrate=N/A speed=4.58x
frame= 217 fps=134 q=-1.0 size=N/A time=00:00:05.45 bitrate=N/A speed=3.36x
frame= 243 fps=114 q=-1.0 size=N/A time=00:00:05.97 bitrate=N/A speed=2.81x
frame= 268 fps=101 q=-1.0 size=N/A time=00:00:06.47 bitrate=N/A speed=2.45x
frame= 291 fps= 92 q=-1.0 size=N/A time=00:00:06.93 bitrate=N/A speed= 2.2x
[segment @ 000001a252f700c0] Opening 'C:\Users\HomeMedia\AppData\Roaming\Emby-Server\transcoding-temp\380d9476e7f1926bc8c55676fb3db4992.ts' for writing
frame= 321 fps= 87 q=-1.0 size=N/A time=00:00:07.53 bitrate=N/A speed=2.05x
frame= 347 fps= 83 q=-1.0 size=N/A time=00:00:08.05 bitrate=N/A speed=1.92x
frame= 375 fps= 79 q=-1.0 size=N/A time=00:00:08.61 bitrate=N/A speed=1.82x
frame= 401 fps= 76 q=-1.0 size=N/A time=00:00:09.13 bitrate=N/A speed=1.74x
[segment @ 000001a252f700c0] Opening 'C:\Users\HomeMedia\AppData\Roaming\Emby-Server\transcoding-temp\380d9476e7f1926bc8c55676fb3db4993.ts' for writing
Yes.
I have selected
"Video Acceleration API (VA API0 (experimental)"
And "Activate Hardware-Encoding"
I deactivated both, but still no luck.
2018-05-19 20:39:01.018
http://192.168.0.253:18096/emby/videos/414ce92d6c4fa3b44b90bfaf8f53e6e6/live.m3u8?DeviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NDsgcnY6NjAuMCkgR2Vja28vMjAxMDAxMDEgRmlyZWZveC82MC4wfDE1MjY2NzA1NDEzNzU1&MediaSourceId=59093b87028548c98cf7bafbbc21f955&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=-1&VideoBitrate=139808000&AudioBitrate=192000&PlaySessionId=f97b235905f74b19bfb59c2a10b5949d&api_key=6446699734bf452d93835162701ea35c&LiveStreamId=a17c75760a04e99b68cf766e11316e1c_ce72e8c20d5b643260b2ca5ef67f5aa3_59093b87028548c98cf7bafbbc21f955&TranscodingMaxAudioChannels=2&RequireAvc=true&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&h264-deinterlace=true&TranscodeReasons=ContainerNotSupported,VideoCodecNotSupported,AudioCodecNotSupported
{"Protocol":"Http","Id":"59093b87028548c98cf7bafbbc21f955","Path":"http://192.168.0.252:9271/stream/http_stream_17","Type":"Default","Container":"mpegts","Name":"NATIVE","IsRemote":true,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":true,"RequiresOpening":true,"RequiresClosing":true,"LiveStreamId":"a17c75760a04e99b68cf766e11316e1c_ce72e8c20d5b643260b2ca5ef67f5aa3_59093b87028548c98cf7bafbbc21f955","BufferMs":0,"RequiresLooping":false,"SupportsProbing":true,"MediaStreams":[{"Codec":"mpeg2video","TimeBase":"1/90000","CodecTimeBase":"1/25","VideoRange":"SDR","DisplayTitle":"480IMPEG2VIDEO","IsInterlaced":true,"BitRate":2000000,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":576,"Width":720,"AverageFrameRate":25,"RealFrameRate":25,"Profile":"Main","Type":"Video","AspectRatio":"16:9","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":8,"IsAnamorphic":false},{"Codec":"mp2","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"MP2 stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"Formats":[],"Bitrate":2192000,"RequiredHttpHeaders":{},"AnalyzeDurationMs":3000}
C:\emby.windows\system\ffmpeg.exe -analyzeduration 3000000 -f mpegts -i "http://192.168.0.252:9271/stream/http_stream_17"-map_metadata -1 -map_chapters -1 -threads 0 -sn -codec:v:0 libx264 -pix_fmt yuv420p -preset veryfast -crf 20 -maxrate 5000000 -bufsize 10000000 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:gte(t,n_forced*3)" -vf "yadif=1:-1:0,scale=trunc(min(max(iw\,ih*dar)\,1920)/2)*2:trunc(ow/dar/2)*2" -flags -global_header -vsync cfr -codec:a:0 aac -strict experimental -ac 2 -ab 192000  -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3  -individual_header_trailer 0 -segment_format mpegts -segment_list_entry_prefix "hls/e80deeb779dd1fe909544d8bb6c09669/" -segment_list_type m3u8 -segment_start_number 0 -segment_list "C:\emby.windows\transcoding-temp\e80deeb779dd1fe909544d8bb6c09669.m3u8" -y "C:\emby.windows\transcoding-temp\e80deeb779dd1fe909544d8bb6c09669%d.ts"
http://192.168.0.252:9271/stream/http_stream_17:Unknown error
t.andre
Is the port 9271 on your filewall is enable for dvblink or TVMosaic ?
Edited by t.andre
Yes.
I use one PC for Emby and Kodi.
TV works within Kodi with TV-Mosaic plugin and within the TV-Mosaic Windows Prg. installed on the same PC.
But I can't use TV stream if used with Chrome or Firefox and Emby Web-Interface on that PC.
ATM I test that from my Laptop and it doesn't work there too.
But I have installed TV-Mosaic Prg. on that Laptop too and TV is working there with no problem.
And all that worked in the past together with DVBLink (DVBLink and TV-Mosaic is installed on my Synology NAS).
It would be interesting to know if there are other TV-Mosaic users who use TV stream via the web interface.
for me the Webinterface works... but i use port 9270
but if i change the channel (on Android TV) sometimes i got a error... this not happen if i ue the DVBlink server....
i keep a eye on it because i use mosaic a to short time... and witched often between dvblink and mosaic….
i noticed, that if i change the port from 8100 to 9270 (and back), emby need a restart to "check it" :-)
embyserver-63662359550_Web_DVBLink.txt
embyserver-63662360189_AndroidTV and WEB_TVMosaic.txt
ffmpeg-remux-4acfa630-31b6-4598-b886-135ee3e6fdea_Web_DVBlink.txt
ffmpeg-remux-54f734ac-6505-4e26-90ff-cf389ec56bc8_WEB_TVMosaic.txt
Hmm.
Since TV works with TV-Mosaic Plugin within Kodi and from my Android devices and because it worked from Web Interface in the past with DVBLink, it has to work mit TV-Mosaic too (I think).
It's not life-critical if it don't work from Web Interface because it works within Kodi, which I use most of the time, but I hope, that t.andre finds the reaseon.
Edited by Siutsch
I noticed that if i change port from 9270 to 9271 emby show no channel...
But can't do more testing Today
t.andre
I will make more test tomorrow with DVBLink and tvmosaic
