emby_fan 2 Posted March 11, 2017 Posted March 11, 2017 After dvblink update to build 14061 I've recognized the same issue - streaming to IPAD via emby not possible: After starting a broadcast via live TV from emby I just see the "hourglass" symbol. Steaming to IPAD via native dvblink app (without emby) works fine. After I've downgraded the dvblink server (I don't know the build number) streaming via emby app works again - but the hourglass symbol is still visible for 5 to 10 seconds. I've attached the server log file for debugging - I hope it helps. In general the plugin was working, but by nature if something changed in dvblink the plugin has to follow - we didn't have a synchronized development I assume ... best regards, emby_fan
vaise 340 Posted August 27, 2017 Posted August 27, 2017 Hi, Is this plugin working ? Still being enhanced ? Supported ? Maybe no updates since March mean it is working perfectly ? Or it is dead and no-one is using it ? I am considering moving many things to my NAS - which will mean moving back to dvblink from nextPVR. Not much point if I cant get the recording services to work with Emby though. Thanks,
muppets4 24 Posted August 28, 2017 Posted August 28, 2017 Hi, Is this plugin working ? Still being enhanced ? Supported ? Maybe no updates since March mean it is working perfectly ? Or it is dead and no-one is using it ? I am considering moving many things to my NAS - which will mean moving back to dvblink from nextPVR. Not much point if I cant get the recording services to work with Emby though. Thanks, I am using this plugin in a day to day basis and am very happy with it. Only wish I have left is faster changing of channels. The DVBlink app does that a bit faster. Verstuurd vanaf mijn SM-G930F met Tapatalk
vaise 340 Posted August 29, 2017 Posted August 29, 2017 Hi @@muppets4. Thanks for the update. I never use it for live TV. It will just be for recorded TV talking to my HDHomeruns. The emby plugin for this I may therefore not use and just have an emby library over the recorded TV. If I do use the plugin, and just for recorded TV do you see any benefits over the above ? Thanks
t.andre 69 Posted September 6, 2017 Author Posted September 6, 2017 (edited) Hi, the plugin is not dead I will publish a new version soon. Just for information I use it every day. Cheers Edited September 6, 2017 by t.andre 2
Spaceboy 2573 Posted September 6, 2017 Posted September 6, 2017 No, no its not dead. Just resting. Remarkable bird the Norwegian Blue! 1
t.andre 69 Posted September 12, 2017 Author Posted September 12, 2017 Hi, I have published a new version for Emby beta 3.2.30.2. -Updated Plugin to .NET Core Cheers.
t.andre 69 Posted October 23, 2017 Author Posted October 23, 2017 Hi, I have published a new version of the plugin for Emby beta 3.2.33.19 and greater Cheers.
muppets4 24 Posted October 23, 2017 Posted October 23, 2017 Hi t.andre. Thanks for all of your hard work. Could you tell me what has changed?
t.andre 69 Posted October 23, 2017 Author Posted October 23, 2017 Hi t.andre. Thanks for all of your hard work. Could you tell me what has changed? It's just minor changes to improve the connection to the server. Cheers.
t.andre 69 Posted October 23, 2017 Author Posted October 23, 2017 Just for info it works on qnap nas with the last version of emby server beta
QDivision 42 Posted October 24, 2017 Posted October 24, 2017 Hi, The latest updated 1.5.01 doesn't install properly in the latest stable Emby 3.2.34. It says it install but when you restart Emby it disappears from the plugins page. It's still in the catalogue and I can install it again but as soon as you restart to finish installation it gets removed.
QDivision 42 Posted October 24, 2017 Posted October 24, 2017 Also, if I roll back to 1.5.0.0 it installs fine but now I have no TV data, I get the following error in the log: 2017-10-24 08:03:45.733 Info App: [DVBLink] - Initializing2017-10-24 08:03:45.733 Info App: [DVBLink] - Configuration updated2017-10-24 08:03:45.748 Info App: [DVBLink] - Connecting to server : http://10.0.0.2:8100/cs/2017-10-24 08:03:45.748 Error App: [DVBLink] - It's not possible to Ensure a connection to the Server *** Error Report *** Version: 3.2.34.0 Command line: C:\Users\Neo\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe C:\Users\Neo\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe C:\Users\Neo\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe C:\Users\Neo\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 8 Program data path: C:\Users\Neo\AppData\Roaming\Emby-Server Application directory: C:\Users\Neo\AppData\Roaming\Emby-Server\System System.FormatException: Index (zero based) must be greater than or equal to zero and less than the size of the argument list. at System.Text.StringBuilder.AppendFormatHelper(IFormatProvider provider, String format, ParamsArray args) at System.String.FormatHelper(IFormatProvider provider, String format, ParamsArray args) at System.String.Format(String format, Object[] args) at Emby.Plugins.DVBLink.Helpers.PluginLogger.ErrorException(String message, Exception exception, Object[] paramList) at TSoft.DVBLinkServices.HttpClientBase.<GetResponseObjectAsync>d__26`2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at TSoft.DVBLinkServices.DVBLinkClient.<EnsureConnectionAsync>d__82.MoveNext() System.FormatException at System.Text.StringBuilder.AppendFormatHelper(IFormatProvider provider, String format, ParamsArray args) at System.String.FormatHelper(IFormatProvider provider, String format, ParamsArray args) at System.String.Format(String format, Object[] args) at Emby.Plugins.DVBLink.Helpers.PluginLogger.ErrorException(String message, Exception exception, Object[] paramList) at TSoft.DVBLinkServices.HttpClientBase.<GetResponseObjectAsync>d__26`2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at TSoft.DVBLinkServices.DVBLinkClient.<EnsureConnectionAsync>d__82.MoveNext()
t.andre 69 Posted October 24, 2017 Author Posted October 24, 2017 I, sorry for the inconvenience. The plugin has been updated. Cheers.
QDivision 42 Posted October 25, 2017 Posted October 25, 2017 Thanks for the quick response. Works great now! One question though. Using RAW transport stream works better but in the configuration it says it doesn't support timeshift but timeshift still works. Is that old information?
QDivision 42 Posted October 25, 2017 Posted October 25, 2017 Please can you look at the following thread, this is about the movie names not displaying correctly: https://emby.media/community/index.php?/topic/49647-image-white-space-and-aspect-ratio-problems/?p=503257"there's something hacky going on in the plugin from what i can see. If i had to guess, it's setting IsSeries=true, leaving the Name blank and filling the movie title into the EpisodeTitle field. If that's true then that needs to be cleaned up." Would be great to get this sorted. Many Thanks!
Senna 368 Posted November 1, 2017 Posted November 1, 2017 (edited) @@t.andre, I have an issue with the DVBLink plugin where my Apple TV 4K doesn't play channels or recordings on tvOS11.1. My iPad (ios11.0.3) doesn't have this problem. Could you please take a look here: https://emby.media/community/index.php?/topic/52480-live-tv-not-working-apple-tv-4k-dvblink-plugin/ Thanks ! Edited November 3, 2017 by Senna
Luke 42243 Posted January 5, 2018 Posted January 5, 2018 We now have native Hauppauge support available for testing in the Emby Server beta: https://emby.media/community/index.php?/topic/54560-32609-hauppauge-support/?hl=hauppauge No plugin required. Thanks !
QDivision 42 Posted February 24, 2018 Posted February 24, 2018 Hi, Latest update seems to work well except the images no longer display correctly through the Live TV Recording section and there is a new home screen tile called DVBLink Recordings. If I go to that the images appear correctly but then clicking on a recording opens a new page with a single tile of the recording with no image that I have to click again to bring up the actual recording page which again has no image. see screenshots. Also would it be possible to change the new tile DVBLink Recordings to just 'Recordings' or make it an editable option?
Luke 42243 Posted February 24, 2018 Posted February 24, 2018 @ can you please attach the emby server log? thanks.
muppets4 24 Posted March 18, 2018 Posted March 18, 2018 @t.andre there is an update for this plugin (1.5.3). What has changed?
Senna 368 Posted March 18, 2018 Posted March 18, 2018 @@muppets4 Can you tell us something about your loading times of HD channels with this update ? Because I ditched the DVBLink plugin in Emby after I tested this for countless hours, when I started with Emby. Are HD channel loading times, when probing is already done, still around 7-10 seconds ?
muppets4 24 Posted March 18, 2018 Posted March 18, 2018 I don't know. I did not install it yet. Until now I am using 1.5.2 and that still has the slow loading times. The viewer from dvblink is much faster. But Emby is better in almost every other way. Better picture quality and low CPU usage for example. Verstuurd vanaf mijn SM-G930F met Tapatalk
