Aleaha 0 Posted September 27 Posted September 27 For some reason, my Emby server is unable to accept remote connections all of a sudden. I’ve been able to connect to it remotely for over a year. Nothing has changed, except my ability to connect remotely… This server is running and I can connect locally. I have reset both the Emby server itself and the computer it is running on, I’ve reset the network and verified port forwarding settings, the server is up-to-date and my clients app is up-to-date. Remote connections were working yesterday, nothing has changed, but all of a sudden today they aren’t working.
Luke 43537 Posted September 28 Posted September 28 Hi there, can you show us how you've setup port forwarding? Connecting from Client Apps
Aleaha 0 Posted September 28 Author Posted September 28 I figured it out, I did change something. I started using a VPN and thought I’d set up split tunneling but SurfShark was waiting for me to click ‘allow’ in settings… my fault entirely!
Aleaha 0 Posted September 30 Author Posted September 30 I take it back! Remote connections are failing again... The server is running on ports 8080 and 8096, both forwarded at my router. I disabled the VPN even though it hadn't been an issue after I enabled the split tunneling. As I'm typing this, I'm streaming to another screen over the local network, so the server is running and the system has connectivity out. I'm at a loss.
Luke 43537 Posted October 2 Posted October 2 Hi, if you disabled the VPN then you need to use a different remote address now, right? Are you sure you're trying to connect with the correct address?
Aleaha 0 Posted October 2 Author Posted October 2 As mentioned, the server has been set up and running properly for a while. When I added the VPN, I thought I had set up split tunneling, which would allow the Emby server to bypass the VPN altogether which would mean I could still use my originally reserved ports and IP addresses. When I initially made the post on here it was because I hadn’t finished setting up the split tunneling, meaning it was looking for a different remote address. Once I discovered that Surfshark was waiting on me pressing a button, the split tunneling set up was complete and for a day the Emby server was running as it had for over a year. I checked it the next day and wasn’t able to connect remotely, so I disabled the VPN entirely but the reserved IP address and reserved ports have not changed from day one and I’m not sure that they would have to under these circumstances. My ISP provides me a dynamic IP address so the external IP doesn’t matter so much as long as it’s listening to the proper external port and communicating to my system on its reserved local IP address and port. The reason I logged into my VPN on this system was because I thought I’d be able to bypass it using split tunneling.
sa2000 880 Posted October 9 Posted October 9 On 03/10/2026 at 00:08, Aleaha said: My ISP provides me a dynamic IP address so the external IP doesn’t matter so much as long as it’s listening to the proper external port and communicating to my system on its reserved local IP address and port. If the public IP address changes then that would cause issues with the remote clients. One way round this is to have a domain and DDNS service to keep the domain attached to the right IP address and then client s can you the domain name to connect
Uncle_Frank 18 Posted October 11 Posted October 11 Or Aleaha you could close all ports on your router and use a meshnet and never have that issue again, nordvpn has that feature for free. Or if you insist port forwarding don't forget to setup a static ip on the server that has your emby on it. Have a good one
