medicmandan 1 Posted September 19 Posted September 19 I just switched to a new livetv provider and have been getting this error when trying to update the guide (EPG link). May be a coincidence with the new provider but I also had to reinstall the docker container in Unraid a couple of weeks ago. I restored it from a backup on Unraid. Everything else has been working fine since. Running time: 1 hour, 54 minutes and 17 seconds Exception of type 'SQLitePCL.pretty.SQLiteException' was thrown. at SQLitePCL.pretty.SQLiteException.CheckOk(sqlite3 db, Int32 rc) at SQLitePCL.pretty.StatementImpl.MoveNext() at SQLitePCL.pretty.DatabaseConnection.Execute(IDatabaseConnection This, String sql) at Emby.Sqlite.BaseSqliteRepository.ExecuteAll(IDatabaseConnection db, List`1 queries) at Emby.Server.Implementations.Data.SqliteItemRepository.DeleteItemsInTransaction(IDatabaseConnection db, Int64[] ids, Boolean containsFolders, Boolean supportsPeople, Boolean supportsChapters, Boolean supportsCollections, Boolean supportsMediaStreams, Boolean supportsListItems, Boolean supportsExternalDatabases, Boolean supportsItemExtraData, Boolean supportsUserItemShares) at Emby.Server.Implementations.Data.SqliteItemRepository.DeleteItemsInChunks(Int64[] ids, IDatabaseConnection db, Boolean containsFolders, Boolean supportsPeople, Boolean supportsChapters, Boolean supportsCollections, Boolean supportsMediaStreams, Boolean supportsListItems, Boolean supportsExternalDatabases, Boolean supportsItemExtraData, Boolean supportsUserItemShares) at Emby.Server.Implementations.Data.SqliteItemRepository.DeleteChannels(Int64[] idsToDelete) at Emby.LiveTV.LiveTvManager.CleanDeadChannels(Int64[] currentIdList, CancellationToken cancellationToken) at Emby.LiveTV.LiveTvManager.RefreshChannels(IProgress`1 progress, CancellationToken cancellationToken) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options)
Luke 43549 Posted September 20 Posted September 20 Hi there, please attach the complete emby server log file. Thanks.
medicmandan 1 Posted September 20 Author Posted September 20 Hopefully I grabbed the correct one. embyserver-63925372800.txt
Luke 43549 Posted September 21 Posted September 21 Thanks. Please see here and let us know if it helps get you squared away: Corrupt Database Thanks.
