KDScho 0 Posted July 20 Posted July 20 Hi! I have been exploring Emby as a way to share family photos and videos with my grownup kids. It seems like a perfect solution, but we have been unable to get external access working. Here are some details about our setup: - we have a router from Optimum, our internet service provider. - we have a netgear orbi RBR750 and two satellites for home WiFi network due to size of our home - we tried to follow instructions to put the Optimum router on bridge mode so we can have the correct Universal plug and play (UPnP) set up, as instructed. This was unsuccessful and we actually lost all internet access until we reverted everything. Emby is set up on a Mac Studio 2022 with Apple M1 Max and Sequoia 15.7.3, accessing an external hard drive for the folders and data. Thanks!
Luke 43537 Posted July 20 Posted July 20 Hi there, have you taken a look at our connections guide? Connecting from Client Apps
KDScho 0 Posted July 20 Author Posted July 20 Yes, we were going through your connection guide on the "External Connections" steps because Emby works on our home network only. It seems to be an issue setting up the UPnP. We have two routers essentially and we started with the Optimum router (the one provided by our internet provider).
Luke 43537 Posted July 20 Posted July 20 13 minutes ago, KDScho said: Yes, we were going through your connection guide on the "External Connections" steps because Emby works on our home network only. It seems to be an issue setting up the UPnP. We have two routers essentially and we started with the Optimum router (the one provided by our internet provider). The most reliable way is to setup port forwarding and then skip upnp. If your router lets you do that, then I would go that route.
KDScho 0 Posted July 24 Author Posted July 24 We were able to set up port forwarding and the external connections are working now. Thank you! Is our network any more vulnerable to hackers or malware with the port forwarding?
Neminem 1981 Posted July 24 Posted July 24 2 hours ago, KDScho said: Is our network any more vulnerable to hackers or malware with the port forwarding? Yes, as soon as you open ports in your router and firewalls, you open up another attack vector. And that has nothing to do with Emby, its for any program you want to use remote.
KDScho 0 Posted July 24 Author Posted July 24 I spoke too soon: we cannot connect to Emby today from any device, including the Mac we are running Emby on. Our current network setup is pointing to an external drive attached to the Mac. Both devices are powered on and running. We plan to get a dedicated server soon (like Synology) that can house our media and always be on. Would this be a better solution?
KDScho 0 Posted July 26 Author Posted July 26 (edited) If this matters: Emby stopped working sometime shortly after I purchased Emby Premiere and put in my license key. we did just now try the option to “Restart Server” on the Mac app, and now it appears to be back. Is that all we needed to do? Edited July 26 by KDScho New information
