adrianwi 294 Posted June 15 Posted June 15 Anyone having problems upgrading from 4.9.3.0 to 4.9.5.0 on FreeBSD 13 (TrueNAS Core)? I tried a few weeks ago when I first saw the update message but emby wouldn't start after updating, so I rolled back and thought i'd just leave it. Tried again tonight and the same problem, but switching back to 3 works fine. Nothing in the server log files to even show it's trying to start 4.9.5.0, but will PM one anyway.
adrianwi 294 Posted June 22 Author Posted June 22 No because I rolled back to 4.9.3.0, but 4.9.5.0 doesn't work for me on FreeBSD13 (TrueNAS Core 13.3 U1.2)
adrianwi 294 Posted June 23 Author Posted June 23 I have a holiday to look forward to at the weekend, but will have another go when I get back. 1
Baenwort 125 Posted August 16 Posted August 16 I"m able to run 4.9.5.0 on a TrueNAS 13.3U1.2 server. Are you still having troubles? 1
adrianwi 294 Posted August 18 Author Posted August 18 I'd not tried since getting back from holiday, but I've just had another go and updating using pkg update && pkg upgrade and then updating emby with pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/4.9.5.0/emby-server-freebsd13_4.9.5.0_amd64.pkg runs but emby won't start as a service afterwards. Nothing in the emby log files as it's just failing to start. Rolled back to 4.9.3.0 which is working fine 1
Baenwort 125 Posted August 20 Posted August 20 Does it fail when you manually do the service emby-server start? I don't have any of my jail services set to Autostart as I like to manually launch them.
adrianwi 294 Posted August 24 Author Posted August 24 Yes, it fails to autostart and when I try manually
adrianwi 294 Posted September 7 Author Posted September 7 No change. emby-server won't come back up after upgrading to 4.9.5.0 from 4.9.3.0.
Luke 43719 Posted September 8 Posted September 8 OK we're actually trying to roll out a new stable today so please keep us posted on whether that resolves the issue for you. Thanks.
alucryd 345 Posted September 9 Posted September 9 @adrianwiHave you tried upgrading your jail? iocage upgrade <jail_name> Works fine on vanilla FreeBSD 13.5 here. Going to try TrueNAS when I get home.
adrianwi 294 Posted September 10 Author Posted September 10 The jail is running 13.5, and all packages are up to date. It works fine on 4.9.3.0. Is there some new dependency?
alucryd 345 Posted September 10 Posted September 10 Trying to run it manually will tell you if you're missing sth. In doubt, you can try our dep install command here, it should be exhaustive: https://emby.media/freebsd-server.html Unfortunately I can't even install a 13.5 jail on my TrueNAS Core VM because it's EOL, so I can't reproduce.
adrianwi 294 Posted September 10 Author Posted September 10 Not sure what you mean by 'run it manually', but I ran the pkg install < dependencies> from the URL, and it installed dotnet8-8.0.20, but when I checked, dotnet-9.0.14 was already installed, so I'm not sure what's going on there. Anyway, updating to 4.9.5.0 or 4.10.0.40 fails to start the emby-server service again. It does appear to be running for a few seconds, but then stops, and it's not writing anything to the embyserver.txt file Perhaps my emby journey on TrueNAS comes to an end at 4.9.3.0, which is still working just fine. I need to consider moving away from TrueNAS Core but it's too big and scary at the minute and everything I'm running is still working .
Luke 43719 Posted September 10 Posted September 10 Quote dotnet-9.0.14 was already installed we have not tested dotnet 9 so just be aware of that.
adrianwi 294 Posted September 11 Author Posted September 11 I removed dotnet-9.0.14 and dotnet-host-9.0.14, but when I reinstall dotnet8-8.0.20 it installs dotnet-host-9.0.14. 1
alucryd 345 Posted September 11 Posted September 11 (edited) It's normal that it installs dotnet-host 9, dotnet-host is usually higher than the runtime, the important part is that you have dotnet8 installed. Now, by running manually I meant running the server, here's a handy one liner, should give you some insights: LD_LIBRARY_PATH=/usr/local/lib/emby-server/lib:/usr/local/lib LIBVA_DRIVERS_PATH=/usr/local/lib/dri PATH=/usr/local/lib/emby-server/bin:"$PATH" SSL_CERT_FILE=/usr/local/lib/ca-certificates.crt NEOReadDebugKeys=1 OverrideGpuAddressSpace=48 /usr/local/bin/dotnet /usr/local/lib/emby-server/system/EmbyServer.dll -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage 'emby-server-@RELEASE@_{version}_@ARCH@.pkg' Edited September 11 by alucryd
adrianwi 294 Posted September 12 Author Posted September 12 Thanks, but way too complicated! I'm running 4.9.3.0 without any problems. I'm running the command pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/4.9.5.0/emby-server-freebsd13_4.9.5.0_amd64.pkg and then service emby-server start and it doesn't.
alucryd 345 Posted September 18 Posted September 18 @adrianwiYou just have to copy paste that command, without logs I really can't help you Your installation (FreeNAS + FreeBSD 13 jail) is officially discontinued and impossible to replicate today. My only surviving FreeBSD 13 install works just fine with our current package, so this is specific to your jail.
Baenwort 125 Posted September 20 Posted September 20 My TrueNAS Core 13.5 Emby server is running 4.10.0.40 fine so this may be something specific about your jail.
Solution adrianwi 294 Posted September 23 Author Solution Posted September 23 (edited) What's the correct way to create a new emby server on TrueNAS Core 13.3? The website instructions all refer to emby-server.json but that has a release of 14.1 which isn't going to work. UPDATE OK, so I've just rebuilt this manually, creating a new iocage 13.5-RELEASE FreeBSD Jail and installed all of the packages from the FreeBSD instructions here and then pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/4.10.0.40/emby-server-freebsd13_4.10.0.40_amd64.pkg This started just fine, so I recreated all of the mount points to my media folders and to the /var/db/emby-server folder, which I have in a separate dataset/pool outside the jail. This restarted fine too and everything looks to be working OK, although I haven't had the chance to give it a real test. Still no idea what's broken in the old jail, although it's probably been upgraded from TrueNAS 10 or 11, so a clean start probably does no harm (for at least for as long as 13 lasts) Thanks Edited September 23 by adrianwi 1
