BillyWok 0 Posted May 20 Posted May 20 Hello It seems that the searching process is broken. Versions tested: 4.9.3 / 4.9.5 OS: Debian 12 API: api.themoviedb.org Content: Casino Jack (2010) From the 4.9.5 logs, the issue starts here: 2026-05-20 08:47:20.222 Error App: Error in TheMovieDb From the 4.9.3 logs, the issue starts here: 2026-05-20 08:42:48.440 Error App: Error in TheMovieDb Could you please have a look, or should I report this issue on another forum (TheMovieDb app forum)? Thank you in advance. Have a good day. Regards, embyserver--4-9-5.txt embyserver--4-9-3.txt
seanbuff 1456 Posted May 20 Posted May 20 @Lukeappears there's an issue with TheMovieDB fetcher. Multiple reports: https://emby.media/community/topic/147829-person-metadata-failing-to-identify-refresh/ https://emby.media/community/topic/147798-new-emby-server-release-4950/#findComment-1521535 Also confirmed it's happening on both stable and beta server versions. 2 1
BillyWok 0 Posted May 20 Author Posted May 20 Hello @seanbuff Thank you for your answer. I will follow the others reports. Have a good day Regards
adminExitium 370 Posted May 20 Posted May 20 It's because of double compression: https://www.themoviedb.org/talk/6a0cf9a5dd8f54b8836a3750 1 1 1
Z4ng3tsu 0 Posted May 20 Posted May 20 Yeap same issue for me. We'll just have to wait for a fix I guess
