Roku Not playing live TV nor recorded shows in progress with Proxy in place.
ab123ga
I've moved to the use of a proxy (dispatcharr) to manage my streaming links etc. This way I can have failover with the use of 1 channel versus multiple in emby. Prior to this everything worked fine on roku. Now that I use a proxy,  I did not realize until one of my brothers who has Roku that its not working on that system since all but 1 of my tvs at my house is firetv. I have no issues /w FireTV and IOS but on Roku when you hit play it just spins and shows 26% then spins then spins. I have the video of that if needed. But attached are the logs. Example around 12:59PM ET I played American Hero Channel. It worked fine on Firestick. Around 1:03PM in Roku it generated many transcode files but fails every time. It seems like it does not like something about the proxy. I say that because I have 1 channel (buzzr)  in my proxy tool that I tell it to redirect; meaning send the m3u as-is and that is the one channel roku can play with no issue. I do not want to go away from what I built b/c 1) i spent too much time building it and it allows me better control than managing the streams in emby.
ffmpeg-transcode-7fad32b8-be87-4503-95dc-a8f67218d1ec_1.txtffmpeg-transcode-5aef2884-f10b-4572-9617-f3c92f0b6422_1.txtffmpeg-transcode-d44e1d4b-5053-4200-b285-796bc0e67537_1.txtffmpeg-transcode-1a7f6f7f-bfd6-471c-9d97-4010c70b1a7a_1.txtffmpeg-transcode-842c0a7d-5d21-4695-aa7d-a0309edb03dd_1.txtffmpeg-directstream-eff2aa2d-1134-4817-956b-fe0debe3d89d_1.txtembyserver (4).txt
