Kyouma 53 Posted April 30 Posted April 30 (edited) Hello, the last time I watched a show was on 27.04.2026 and there were no issues using mpv. Now, when I wanted to watch something I had no audio, no matter what I started. On the dashboard it says it's direct playing without any issues shown. Using the phone or lg worked fine. Switching to the native player also works, but it's then being transcoded. Restarting the apple tv or emby server did not help. Emby version is 4.9.3 and apple tv is 2.0.5(3). I attached the log from today. Edit: A friend, also using apple tv, has no issues with audio when using mpv. What could this mean? Edit 2: Doing a full reset of the apple tv did not help either. embyserver (1).txt Edited April 30 by Kyouma
Kyouma 53 Posted May 1 Author Posted May 1 So i just saw this thread: The suggested solution did work for me. 1
alex77777 54 Posted May 1 Posted May 1 On 4/11/2026 at 2:34 PM, Luke said: Fix loss of audio when apple tv setting continuous audio is enabled This will be fixed in 2.0.6, but for now keep continuous audio connection off. 1
gswhite 0 Posted May 3 Posted May 3 (edited) With 2.0.6 audio now plays but is intermittent. I get 1-3 second silence every few minutes playing through Infuse is no problem with the same content. Edited May 3 by gswhite
alex77777 54 Posted May 4 Posted May 4 @gswhite Have you tried turning off Continuous Audio Connection in the Apple TV settings?
