Briefer
Hello,
Is there a way to filter my movies in the Android app by SD, HDR or Dolby Vision like in the web interface? Or is there a way to create a collection or playlist in the server with all my DV movies?
Thank you
Seperate them at the library / folder level:  Folder Structure -
F:\Media\Movies\4K
F:\Media\Movies\SDR
F:\Media\Movies\HDR
Then you can create 3 different libraries.  One called Movies that includes all 3 paths, then 2 additional ones that only include SDR / HDR respectively.  If you name the movie folders identical and following the "Multi-Verison" naming structure, your main Movie library should include 3 different versions.
Edited by js28194
Yep, I wanted to avoid that, but I guess it is the only choice right now. Thanks
