robbie1407 5 Posted March 19 Posted March 19 - I have a problem with playing back recordings on my LG OLED65CS6LA. It happens on most recordings. it seems to be only this device that is affected. windows app seems okay. Using hd homerun tuner. emby server on synology nas. When i go to playback a recording it will show a still screen of the recording for about 1 second then just go blank. All you can do after this is press backup to return to previous screen. - I have tried seeking forwards and backwards but emby does not respond. I have tried restarting emby server and synology nas. i have played back on windows app and LGOLED55BV7 and all recordings play back okay. - I have not seen any error messages. - I have attached server log - I have attached 2 videos, one of the LG and one of the windows app to show playback issue on the LG many thanks Robbie embyserver.txt
robbie1407 5 Posted March 19 Author Posted March 19 video of playback issue on LG OLED65CS6LA lgtv.MOV
robbie1407 5 Posted March 19 Author Posted March 19 video of playback working on emby windows app windows.MOV
robbie1407 5 Posted March 25 Author Posted March 25 Hi there, i take it there is no fix for this issue, can you please let me know where i can seek a refund for emby premiere? thanks
visproduction 338 Posted March 25 Posted March 25 Your log: line 5 Quote 2026-03-17 16:36:27.262 Error PortMapper: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>402</errorCode><errorDescription>Invalid Args</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope> Emby menu visible but streaming fails - LG OLED. Apparently this may be resolved with LG setup options. Often different brands and models require permissions and settings. Viewing an Emby page on a TV app does not mean that all streaming should be working. Video streaming may be blocked by a TV setting, as well. see: https://www.reddit.com/r/LGOLED/comments/1did7lk/lg_smart_tv_shows_connected_but_does_not_load/ And https://duckduckgo.com/?q=LG+Oled+video+streaming+Invalid+Args+error&ia=web 1
Luke 42287 Posted March 26 Posted March 26 On 3/19/2026 at 4:12 PM, robbie1407 said: - I have a problem with playing back recordings on my LG OLED65CS6LA. It happens on most recordings. it seems to be only this device that is affected. windows app seems okay. Using hd homerun tuner. emby server on synology nas. When i go to playback a recording it will show a still screen of the recording for about 1 second then just go blank. All you can do after this is press backup to return to previous screen. - I have tried seeking forwards and backwards but emby does not respond. I have tried restarting emby server and synology nas. i have played back on windows app and LGOLED55BV7 and all recordings play back okay. - I have not seen any error messages. - I have attached server log - I have attached 2 videos, one of the LG and one of the windows app to show playback issue on the LG many thanks Robbie embyserver.txt 10.12 kB · 1 download Hi , can you please attach the complete Emby server log? Also are you able to update to Emby server 4.9.3?
robbie1407 5 Posted March 26 Author Posted March 26 i try to play bullseye s10:e8 which will not play on lg but plays on windows emby. bullseye s10:e6 plays ok on all. both where recorded on emby pvr ive attached full log thanks embyserver.txt
robbie1407 5 Posted March 26 Author Posted March 26 also i updated to 4.9.3 before i sent the log, thanks
visproduction 338 Posted March 26 Posted March 26 In latest log Error in GetSpecificMappingAsync occurs 119 times. Linux access rights? Emby issue? Quote 2026-03-19 00:44:27.255 Error PortMapper: Error in GetSpecificMappingAsync *** Error Report *** Version: 4.8.11.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology72_{version}_armv8.spk -noautorunwebapp Operating system: Linux version 4.4.302+ (root@build8) (gcc version 12.2.0 (GCC) ) #86009 SMP Wed Nov 26 18:28:01 CST 2025 Framework: .NET 6.0.36 OS/Process: arm64/arm64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: InternalServerError at Mono.Nat.Upnp.UpnpNatDevice.GetSpecificMappingAsync(Protocol protocol, Int32 publicPort, CancellationToken cancellationToken) at Mono.Nat.Upnp.UpnpNatDevice.CreatePortMap(Mapping mapping, CancellationToken cancellationToken) Source: Emby.PortMapper TargetSite: Void MoveNext()
Neminem 1630 Posted March 26 Posted March 26 @visproductionthat's the upnp plugin telling emby it can't configure the router. And that's not what this is about. 1
robbie1407 5 Posted March 26 Author Posted March 26 20 hours ago, visproduction said: Your log: line 5 Emby menu visible but streaming fails - LG OLED. Apparently this may be resolved with LG setup options. Often different brands and models require permissions and settings. Viewing an Emby page on a TV app does not mean that all streaming should be working. Video streaming may be blocked by a TV setting, as well. see: https://www.reddit.com/r/LGOLED/comments/1did7lk/lg_smart_tv_shows_connected_but_does_not_load/ And https://duckduckgo.com/?q=LG+Oled+video+streaming+Invalid+Args+error&ia=web i did switch locations and reverted back. although the recordings still act the same, i have set up some stuff to record to see if it acts the same. will report back. thanks 1
robbie1407 5 Posted March 26 Author Posted March 26 After recording a few more different things, i am unable to play back as the recordings are not showing up in any of the emby apps. Although i have checked the folder where they are recorded too and they have recorded.
robbie1407 5 Posted March 27 Author Posted March 27 I have some information that might help. The Recordings that do not play on the LG TV will play if i start them off on the windows emby app and resume on the LGTV. The problem seems to be they recordings will not play from the beginning on the LGTV thanks
robbie1407 5 Posted March 28 Author Posted March 28 does anyone have any other ideas what this could be? thanks
visproduction 338 Posted March 28 Posted March 28 So, is LG not recognizing the media as a playable video? Can Emby be tweaked to recognize these files? Are the files perhaps created from a recording and not showing all the startup metadata at the beginning of the file. If the video is remuxed to get the video data setup correctly, will those remuxed video media then begin to play? I think it's reasonable to guess that LG does some test before accepting a media file, as playable. If you remux and try the new file and that fixes it, that would point towards this possibility. I am just guessing. Media quite often has strange metadata setup and this causes failure to playback on some apps and software all the time.
robbie1407 5 Posted March 29 Author Posted March 29 hi there, I have made 2 short recordings off the Emby tv guide. one plays back ok, the other doesn't on my LG OLED65CS6LA. They both playback ok on emby windows app and LG OLED55B7V. I have not touched the file structures meta data etc... I have zipped up both below. Hopefully somebody can unzip and put into there pvr folder to test playback, or look to see if they can figure out why it wont play back on my tv. thanks @SamES PLAYS OK.zip WONT PLAY.zip
Luke 42287 Posted March 31 Posted March 31 On 3/29/2026 at 3:53 PM, robbie1407 said: hi there, I have made 2 short recordings off the Emby tv guide. one plays back ok, the other doesn't on my LG OLED65CS6LA. They both playback ok on emby windows app and LG OLED55B7V. I have not touched the file structures meta data etc... I have zipped up both below. Hopefully somebody can unzip and put into there pvr folder to test playback, or look to see if they can figure out why it wont play back on my tv. thanks @SamES PLAYS OK.zip 9.32 MB · 1 download WONT PLAY.zip 27.84 MB · 1 download Hi, we'll do some testing on this. Thanks.
SamES 1088 Posted April 1 Posted April 1 On 30/03/2026 at 06:53, robbie1407 said: hi there, I have made 2 short recordings off the Emby tv guide. one plays back ok, the other doesn't on my LG OLED65CS6LA. They both playback ok on emby windows app and LG OLED55B7V. I have not touched the file structures meta data etc... I have zipped up both below. Hopefully somebody can unzip and put into there pvr folder to test playback, or look to see if they can figure out why it wont play back on my tv. thanks @SamES PLAYS OK.zip 9.32 MB · 1 download WONT PLAY.zip 27.84 MB · 1 download The one that won't play is interlaced, so that may be part of the problem. Can you please play them both back, and for the one works, please confirm the playback method via stats for nerds - I suspect it is DirectPlay for the container, video and audio. For the one that does not play, does it produce any ffmpeg directstream or transcode logs? If it does, can you please attach? Thanks
robbie1407 5 Posted April 1 Author Posted April 1 hi there, I have checked back and the interlaced one does not play, however there is other interlaced recordings that do play. I checked this in mediainfo. there is other recordings with scan type MBAFF, some play, some do not. so I don't think this is the problem. To confuse you even more i have recorded the same programme on the same channel, a quiz show, 1 plays 1 does not. it seems to be luck of the draw. if I start a playback on the other lg tv or emby windows app and resume on the lgtv with the issue, it will playback ok. just does not playback from the beginning. ive attached to pictures with stats for nerds, everything i watch on emby is direct play. thanks
robbie1407 5 Posted April 1 Author Posted April 1 failed playback server log attached. I do not see any direct stream separate logs thanks embyserver.txt
robbie1407 5 Posted April 1 Author Posted April 1 just a quick update, if I force mpegts to transcode. it does play okay, although it does take 30 seconds to start. so it would seem it is an issue with the direct play? thanks
SamES 1088 Posted April 1 Posted April 1 Yep, that sounds like a mixed bag. Not quite sure what to suggest. If they're all DirectPlay and sometimes work and other times don't then there possibly isn't much we can do. Not sure what country you're in, but I recall someone reporting issues a few years ago with UK recordings where commercial breaks could be played in a different format to the main program, so depending on whether you started playback during the program or the commercial you could get different results, although I'm not entirely sure this is your issue.
robbie1407 5 Posted April 1 Author Posted April 1 im uk. also one more update.. i added the video without the meta data to emby as you would with other collections and the video acts exactly the same and does not playback. I have a fairly large library of ts videos recorded from my satellite tv box and have never had an issue with playback. it just seems to be the ones recorded on emby is there nothing different with the files apart from one is interlaced? the video that does not direct play back is on a tv channel without adverts. thanks
SamES 1088 Posted April 1 Posted April 1 36 minutes ago, robbie1407 said: s there nothing different with the files apart from one is interlaced? the video that does not direct play back is on a tv channel without adverts. There are some differences, but hard to know whether they are meaningful. I use a HDHomerun in Australia and I always find the raw .ts output to be a bit buggy. Audio out of sync and random other issues, but I automatically convert recordings to mkv using Emby's built-in conversion option and they play fine, even when the same .ts file has issues. I'm not sure if it is something in the way that Emby writes the recording, or if it's on the HDHomerun end, or it's a TV issue (Samsung in my case), but either way, I've never found the raw .ts files to be overly reliable
robbie1407 5 Posted April 2 Author Posted April 2 I think it must be just an issue with that model of tv as they play back ok on other devices. did the 2 recordings playback ok on your device? So is it possible to set a automatic convert just on recordings only? I did have a look in the emby server but couldn't see it. many thanks
