trekflix 7 Posted May 26 Posted May 26 @Luke I'd like to inform you that the new update (Version 4.9.5.0) has resolved the subtitle issue on LG TVs. It took a while, but it's finally here. Thank you! 1
SYN01 15 Posted May 26 Posted May 26 It's not fixed for those of us running v10. We are waiting for the LG TV client to be updated. 1
fabien_m2002 27 Posted May 28 Posted May 28 On 5/26/2026 at 10:55 PM, SYN01 said: It's not fixed for those of us running v10. We are waiting for the LG TV client to be updated. v10 is the beta version? If yes why the most advanced version not include fixed issues?
SYN01 15 Posted May 28 Posted May 28 It's the client code running on the TV that needs to be updated. Not the server code. 2
bruceas 1 Posted May 28 Posted May 28 but now, with this version of LG client and an old windows server version it is working!!!!
SamES 1149 Posted May 28 Posted May 28 48 minutes ago, bruceas said: but now, with this version of LG client and an old windows server version it is working!!!! I think there was more than one issue with both server and client side issues. This is why it has taken a few goes to fully resolve, and for some the server fix is enough and others need the client fix 1 1
SeanMc 0 Posted June 3 Posted June 3 On 1/24/2026 at 4:50 AM, shafto said: Hey there, Just registered to post that I too am experiencing this. I have an LG C7 (2017) too with the same issue, subtitles in the top left, doesn't matter what language it is. Weird characters showing for non-english too. I can confirm I fixed the issue by rolling back from Emby Server 4.9.3.0 to 4.9.1.90. I am using the latest Emby client on LG TV 1.0.50 also. Could help me? How did you return to version 4.9.1.90? I also have an LG TV. Thanks!
SYN01 15 Posted June 3 Posted June 3 4 hours ago, SeanMc said: Could help me? How did you return to version 4.9.1.90? I also have an LG TV. Thanks! If you have lots of MKV files with embedded subtitles and need the subtitles a lot then it may be worth going back to the older version, but if you can put up with it a bit longer and download SRT files instead of embedded, you may save yourself a bunch of work. That's my strategy at the moment as given the developers have submitted the updated client code to LG for approval, it may not be much longer now.
SamES 1149 Posted June 3 Posted June 3 23 minutes ago, SYN01 said: If you have lots of MKV files with embedded subtitles and need the subtitles a lot then it may be worth going back to the older version, but if you can put up with it a bit longer and download SRT files instead of embedded, you may save yourself a bunch of work. That's my strategy at the moment as given the developers have submitted the updated client code to LG for approval, it may not be much longer now. I think you will likely cause more issues trying to downgrade the server. I would suggest waiting for the client update which should be soon
Wayne1801 3 Posted June 12 Posted June 12 On 05/03/2026 at 13:21, Luke said: HI, apologies for the delay. We should have a server update out soon to resolve this. Thanks. Hi Luke can you tell me if there is any progress on the issue being solved is it the LG app that's the concern or Emby App ver 4.9.5.0 I would be grateful for any information you may be able to supply. Regards Wayne
Ultroman 94 Posted June 12 Posted June 12 23 minutes ago, Wayne1801 said: Hi Luke can you tell me if there is any progress on the issue being solved is it the LG app that's the concern or Emby App ver 4.9.5.0 I would be grateful for any information you may be able to supply. Regards Wayne 4.9.5.0 fixed it for some LG TVs, while others have to wait for the next LG client update, which is currently in testing at LG. We're all just waiting now. 2
Wayne1801 3 Posted June 14 Posted June 14 On 12/06/2026 at 12:59, Ultroman said: 4.9.5.0 fixed it for some LG TVs, while others have to wait for the next LG client update, which is currently in testing at LG. We're all just waiting now. Thank you for the info I will keep an eye out for the next update.
Luke 43719 Posted June 21 Posted June 21 21 hours ago, NAA67 said: Is there an approximate date for the update in the LG store? Hi, as soon as it gets through LG review. Thanks. 2
michaelh 6 Posted July 4 Posted July 4 (edited) On 6/22/2026 at 6:29 AM, Luke said: Hi, as soon as it gets through LG review. Thanks. For those of us who run Homebrew stuff on our LG TVs already is it possible to get hold of the .IPK file to install ourselves? It doesn't appear to be part of the Emby's main GitHub. Edited July 4 by michaelh
mehargags 0 Posted July 4 Posted July 4 My Emby Server (Docker) is latest 4.10.0.17 beta --- My 55inch LG TV is 2018 MODEL : 55UJ632T-TA It is kind of old webOS and my Emby App version from LG Content store shows updated : 19-01-2026 (Jan) Version : 1.0.50 It is still showing subs in top left corner. Any remedies? @michaelhcan you guide me how I can sideload from .ipk file if that can fix this dreaded issue?
michaelh 6 Posted July 5 Posted July 5 19 hours ago, mehargags said: @michaelhcan you guide me how I can sideload from .ipk file if that can fix this dreaded issue? Check out webOS Homebrew for details. Some apps you can install without requiring full root access but you still need to enable developer mode to install anything. I don't run full root but am able to install "Ad Free Youtube" for example. 1
SamES 1149 Posted July 5 Posted July 5 On 04/07/2026 at 20:03, mehargags said: It is still showing subs in top left corner. Any remedies? You're best to wait until the LG review is complete. It's not possible to supply the IPK for this app. 1
michaelh 6 Posted July 11 Posted July 11 On 7/5/2026 at 8:57 PM, SamES said: You're best to wait until the LG review is complete. It's not possible to supply the IPK for this app. A week later and we're still waiting for the LG review to complete... The LG team must be all watching the World Cup rather than doing their jobs. Is there a technical reason why we can't be provided with an IPK? Or is it a legal/licencing reason? Cheers 1 1
NAA67 34 Posted July 12 Posted July 12 Do we even have an approximate date for when LG might review the app? It's been under review for over a month now. 1
Luke 43719 Posted July 12 Posted July 12 1 hour ago, NAA67 said: Do we even have an approximate date for when LG might review the app? It's been under review for over a month now. They are typically in the three week timeframe, but there have been some occasions when they take much longer. And that is also assuming we get through on the first try. Unfortunately they also have a tendency to reject updates for silly reasons because they don't take the time to learn how features work and end up thinking something isn't working. 1
Luke 43719 Posted July 27 Posted July 27 7 hours ago, NAA67 said: Still no news? Hi, our app update is in LG review. Thanks.
NAA67 34 Posted August 17 Posted August 17 Hello, is there any news on the LG update? I'm still using Emby 4.8.11.0, and version 4.9.5.0 is still showing subtitles in the top left corner. It's been 8 months since this bug was reported, and we still haven't heard anything?
Ultroman 94 Posted August 17 Posted August 17 22 minutes ago, NAA67 said: Hello, is there any news on the LG update? I'm still using Emby 4.8.11.0, and version 4.9.5.0 is still showing subtitles in the top left corner. It's been 8 months since this bug was reported, and we still haven't heard anything? Not that I'm happy either, but we HAVE heard something. Waiting for LG to approve it, apparently. They usually take 3 weeks, but this time it has taken 3 months so far. Have the Emby team heard anything?
