Mikeanddoe 0 Posted November 14, 2025 Posted November 14, 2025 Logging in and connection issues. App on tv not seeing server.
Abobader 3491 Posted November 14, 2025 Posted November 14, 2025 Hello Mikeanddoe, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Neminem 1630 Posted November 14, 2025 Posted November 14, 2025 Check out this guide Connecting from Client Apps
Mikeanddoe 0 Posted November 14, 2025 Author Posted November 14, 2025 Thanks Neminem, I went through that process several times but I'm not successful. I have tried to delete my server and password to start all over but it doesn't work.
Neminem 1630 Posted November 14, 2025 Posted November 14, 2025 Where did you install your server ? What OS did you install on ? Can you via server os open http://localhost:8096 in a browser? Quick Start
Neminem 1630 Posted November 14, 2025 Posted November 14, 2025 1 hour ago, Neminem said: Can you via server os open http://localhost:8096 in a browser? Can you connect on your windows server via http://localhost:8096 check if the server running? Check taskmanager for embyserver.exe
Luke 42288 Posted November 15, 2025 Posted November 15, 2025 12 hours ago, Mikeanddoe said: Logging in and connection issues. App on tv not seeing server. Hi, what exactly do you mean by not seeing the server? What exactly happens?
Luke 42288 Posted November 15, 2025 Posted November 15, 2025 54 minutes ago, Mikeanddoe said: Asked to Add server manually And then?
TCLMB 0 Posted November 19, 2025 Posted November 19, 2025 Changed everything to see if that was my issue. Same issue of not see server
Luke 42288 Posted November 19, 2025 Posted November 19, 2025 33 minutes ago, TCLMB said: Changed everything to see if that was my issue. Same issue of not see server Are you sure Emby Server is running? Are you able to use the Emby web interface on the server machine?
TCLMB 0 Posted November 19, 2025 Posted November 19, 2025 Yes. Everything is running but i can't access it on my android phone or box.
TCLMB 0 Posted November 19, 2025 Posted November 19, 2025 I put in the IP address for the host but will not connect.
Luke 42288 Posted November 19, 2025 Posted November 19, 2025 12 minutes ago, TCLMB said: I put in the IP address for the host but will not connect. Are you sure the IP address that you used is correct? Where did you get it from?
Luke 42288 Posted November 21, 2025 Posted November 21, 2025 On 11/19/2025 at 3:40 PM, TCLMB said: The Ip address from the Home Lan access Are you able to use the Emby web interface on the server machine?
Lessaj 486 Posted November 21, 2025 Posted November 21, 2025 Is your network profile set to public or private for your network connection?
Lessaj 486 Posted November 22, 2025 Posted November 22, 2025 Change it to private and it should work. @sa2000This comes up a lot for Windows, is it worth adding to the KB for Connecting from Client Apps?
ebr 16354 Posted November 22, 2025 Posted November 22, 2025 13 hours ago, Lessaj said: Change it to private and it should work. @sa2000This comes up a lot for Windows, is it worth adding to the KB for Connecting from Client Apps? Yes it is - in fact, I thought we had just recently added that but I guess not. 1
