hstamas 179 Posted October 24, 2025 Posted October 24, 2025 (edited) +1 - Same issue here. Mac mini server - nothing in my configuration has changed. Comcast internet with 8096 forwarded. Recently updated to the newest beta server software but cant be sure thats when it broke. I dont use remote access very often. Edited October 24, 2025 by hstamas
Luke 42237 Posted October 24, 2025 Posted October 24, 2025 Hi @hstamasi would suggest checking out our connection troubleshooter: Connecting from Client Apps please try the steps listed there and let us know which ones succeed and which ones do not. thanks.
Solution hstamas 179 Posted October 26, 2025 Author Solution Posted October 26, 2025 (edited) Working now @Luke I discovered a phantom device on my network that was assigned the same IP address as my Emby server. That was probably messing up the port forwarding. On that note though, I was never able to get remote working using UPnP, only when I went in and specified the forwarding did it work. I’m using a Xfinity gateway with no additional networking equipment. I made sure UPnP was enabled. A note to everyone out there trying to get this set up. It will NOT work unless you forward the port. Period. Edited October 26, 2025 by hstamas 1
