HanSolo 22 Posted October 11, 2025 Author Posted October 11, 2025 2 minutes ago, Luke said: Hopefully that works, otherwise you will be stuck between a rock and a hard place. 4.8 will probably require a fresh start due to the database changes. I went into one of my users and saw some sql databases errors. I think I'm just going to upgrade to 4.9.0.70, I guess it can't get worse than it already is.
HanSolo 22 Posted October 11, 2025 Author Posted October 11, 2025 I'm back to the GLIBCXX_3.4.20 error. Do you know if there's a way to load that library manually?
HanSolo 22 Posted October 11, 2025 Author Posted October 11, 2025 It's actually two errors: /usr/local/AppCentral/emby-server/system/EmbyServer: /lib64/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by /usr/local/AppCentral/emby-server/system/EmbyServer) /usr/local/AppCentral/emby-server/system/EmbyServer: /lib64/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /usr/local/AppCentral/emby-server/system/EmbyServer)
HanSolo 22 Posted October 12, 2025 Author Posted October 12, 2025 On 10/11/2025 at 4:37 PM, Luke said: Hopefully that works, otherwise you will be stuck between a rock and a hard place. 4.8 will probably require a fresh start due to the database changes. Hi Luke, I've got a lot of parental ratings in my current database. Can you think of any way I can avoid doing all that work again? HS
Solution HanSolo 22 Posted October 13, 2025 Author Solution Posted October 13, 2025 Tried pretty hard to avoid resetting the library database, but I was forced to downgrade to 4.8.11.0 and reset the library database. I was surprised; it was less painful than I thought it would be (so far.) followed these instructions to do the reset. https://emby.media/support/articles/Corrupt-Database.html Looks like it was successful but it's still scanning currently, my music collection has something like 20k tracks so it takes a few minutes. HS 1
